    1. Home
    2. 黄充
    • Profile
    • Following 0
    • Followers 0
    • Topics 1
    • Posts 1
    • Best 0
    • Controversial 0
    • Groups 0
    Posts made by 黄充
    • Frame size mismatch: got 43200 bytes from pipe, expected 38528
      Hi, I want to record tof_depth/hires_large_color data simultaneously without using ROS.
      When I try to record tof_depth data in this way::
      First, I launch voxl-stream for tof_depth:
      voxl-camera-server
      voxl-streamer -i tof_depth -p 8901
      Then I use ffmpeg to write the stream
      ffmpeg -i rtsp://192.168.1.16:8901/live \
             -f rawvideo -pix_fmt gray \
             -s 224x172 -r 10 \
             output.raw
      I run into error in two terminals:
      $ voxl-streamer -i tof_depth -p 8901
      Waiting for pipe tof_depth to appear
      Found Pipe
      detected following stats from pipe:
      w: 224 h: 172 fps: 10 format: RAW8
      Stream available at rtsp://127.0.0.1:8901/live
      A new client rtsp://192.168.1.2:55293(null) has connected, total clients: 1
      Camera server Connected
      ERROR:   Frame size mismatch: got 43200 bytes from pipe, expected 38528
      ERROR:   Most Likely the publisher of the camera data made a mistake
      ERROR:   Shutting down voxl-streamer
      Trying to quit g main loop due to program shutdown
      cleaning up gstreamer
      Exited Cleanly
      [in#0 @ 0x6000014d0000] Error opening input: Invalid data found when processing input
      Error opening input file rtsp://192.168.1.16:8901/live.
      Error opening input files: Invalid data found when processing input
      Any idea? Is there a better way to record tof_depth/hires_large_color stream simultaneously? Thank you!
      黄充黄
      黄充
