  2. VOXL SDK and Software
  3. Low Mavros Data Rates
1 Posts 1 Posters 463 Views
  • M Offline
    M Offline
    m1baldwin
    I have been testing running mavros in the provided ros kinetic docker container from modalai. I have noticed that when I run mavros, and everything connects properly, the update rate of the topics from mavros are quite low. For example, /mavros/local_position/odom is publishing at 1Hz, which I would have expected much higher, like 30-50Hz. Has anyone else seen this problem or found a fix?
