  3. GPS Denied Environment with VIO
8 Posts 4 Posters 2.1k Views 3 Watching
  • K Offline
    K Offline
    Karl_Wright
    I have a Flight Deck controlling motors through the ModalAI ESC (v2). The drone is updated with firmware v1.11.3-0.0.5 and has parameters loaded from this repository as follows:
    platforms --> v1.11 --> m500_4s_config
    helpers --> m500 --> collision_prevention, ekf2_indoor_vio, and enable_uart_esc
    I am able to actuate the motors through voxl-px4-shell, but cannot arm the drone because of a GPS error.
    My goal is to get the drone flying indoors with VIO position mode.
    Is there a way to diagnose the GPS error to determine the source of the problem?
    Here's the output from nsh> gps status.
    INFO [gps] Main GPS
    INFO [gps] protocol: UBX
    INFO [gps] status: OK, port: /dev/ttyS0, baudrate: 115200
    INFO [gps] sat info: disabled
    INFO [gps] rate position: 5.00 Hz
    INFO [gps] rate velocity: 5.00 Hz
    INFO [gps] rate publication: 5.00 Hz
    INFO [gps] rate RTCM injection: 0.00 Hz
    vehicle_gps_position_s
    timestamp: 37432344 (0.001194 seconds ago)
    time_utc_usec: 0
    lat: 0
    lon: 0
    alt: -17000
    alt_ellipsoid: 0
    s_variance_m_s: 33.4660
    c_variance_rad: 3.1416
    eph: 4294967.5000
    epv: 3750018.5000
    hdop: 99.9900
    vdop: 99.9900
    noise_per_ms: 104
    jamming_indicator: 33
    vel_m_s: 0.0000
    vel_n_m_s: 0.0000
    vel_e_m_s: 0.0000
    vel_d_m_s: 0.0000
    cog_rad: 0.0000
    timestamp_time_relative: 0
    heading: nan
    heading_offset: 0.0000
    fix_type: 0
    vel_ned_valid: False
    satellites_used: 0
    Thanks in advance!
    Karl
    • M Offline
      M Offline
      mohammednaveed
      Dear @Karl_Wright
      After powering on your drone go to mavlink inspector and check at odometry tab whether X and Y data is non zero. if it's non zero then VIO is working.
      Please refer to this document
      Regards,
      Mohammed Naveed
      • K Offline
        K Offline
        Karl_Wright
        Hi @mohammednaveed, thanks for your response! The VIO is working properly and sends data to the mavlink inspector.
        The main issue I'm having is that the drone won't arm because of a gps error. Other than that, everything else seems to be working correctly. Any advice on troubleshooting the gps error would be greatly appreciated.
        Karl
        G 1 Reply Last reply
        • K Karl_Wright
          Karl
          G Offline
          G Offline
          Gordon8
          @Karl_Wright
          You have:
          Try adding in:
          sensors_disable_gps_mag.params
          "Turns off GPS and barometer. Use this is you have no gps/mag attached or have a gps/mag attached and just want them disabled in software. Use this with ekf2_indoor_vio.params
          This is not included with ekf2_indoo_vio.params since you may still want these sensors enabled for logging even when not using in EKF2."
          • K Offline
            K Offline
            Karl_Wright
            Hello @Gordon8,
            Thanks so much for your advice. I reset all the parameters in QGC and reloaded ekf2_indoor_vio and sensors_disable_gps_mag.
            I am unfortunately still running into the same issue as before. Arming is denied because of a generic gps error. I have disabled gps and edited other parameters that are supposed to allow arming without gps.
            Thanks again @Gordon8 for your response, I'm open to trying any other suggestions that you or others may have.
            Karl
            • K Offline
              K Offline
              Karl_Wright
              After much more time trying to troubleshoot this issue, I am still unable to arm my drone. QGC shows that everything is operating correctly except that there are failures for GPS and Pre-Arm Check. Does anyone else have any suggestions on other procedures I could try? My current software setup is the same that I have described above.
                How did you update your firmware? Did you use a ModalAI image or QGC?
                Check out https://docs.modalai.com/flight-core-firmware/ and try starting with the latest on that page.
                K 1 Reply Last reply
                • Chad SweetC Chad Sweet
                  K Offline
                  K Offline
                  Karl_Wright
                  wrote on last edited by Karl_Wright
                  @Chad-Sweet Thanks for your reply.
                  I am currently running firmware FCv1 - v1.11.3-0.2.3 from that link. I downloaded the image and then uploaded it through QGC as a custom firmware.
                  Karl
