  3. how to stop wlan0 mac address randomization
rb5
8 Posts 6 Posters 2.4k Views 2 Watching
  • shane_langhansS Offline
    shane_langhans
    I've noticed that every time the rb5 boots, the mac address for wlan0 interface changes. This is inconvenient, because I can't set the network router to reserve an IP address for it. Every time it boots, i have to use the adb shell to check what IP address ended up being assigned if i want to stream video or ssh to use vio and voa clients.
    I saw some forums like this one that said to change /etc/NetworkManager/NetworkManager.conf, but there's is no network manager directory in /etc directory.
    I tried creating /etc/NetworkManager/conf.d directory and adding a file there with the contents:
    [device]
    match-device=interface-name:wlan0
    wifi.scan-rand-mac-address=no
    but that didn't help.
    Any ideas for how to use a constant mac address?
    • shane_langhansS shane_langhans
      [device]
      @shane_langhans Yes, this is a known issue. We have opened a support ticket with Qualcomm and are awaiting a solution.
      Bo ZhangB 1 Reply Last reply
        Hey @shane_langhans ,
        Yeah, this has been a pet peeve for me too. To officially fix it, we're waiting on QCOM for a proper fix.
        As a work around, do you have a range of IPs that are not being used in the router's DHCP pool? If so, maybe you can statically assign an IP within that range? For instance, you can setup service script that calls a script like this to set the IP:
        #!/bin/bash
        drone_IP='192.168.168.101'
        microhard_radio_gw='192.168.168.1'
        ifconfig eth0 down
        ifconfig eth0 $drone_IP netmask 255.255.255.0 up
        ip route add default via $microhard_radio_gw dev eth0
        See if this works, then we can drop it into a service like this in /etc/systemd/system:
        [Unit]
        After=sdsprpcd.service
        Requires=sdsprpcd.service
        [Service]
        Type=oneshot
        ExecStartPre=/bin/sleep 10
        ExecStart=/home/root/microhard_radio_config_iface.sh
        [Install]
        WantedBy=default.target
        RobertoR 1 Reply Last reply
        • ? A Former User
          #!/bin/bash
          ifconfig eth0 down
          [Unit]
          [Service]
          Type=oneshot
          [Install]
          RobertoR Offline
          RobertoR Offline
          Roberto
            Bo ZhangB Offline
            Bo ZhangB Offline
            Bo Zhang
            @Eric-Katzfey Hi, how is this ticket going now?
            @Eric-Katzfey said in how to stop wlan0 mac address randomization:
            • Bo ZhangB Bo Zhang
              @Bo-Zhang Unfortunately, we have not received a solution.
              • Bo ZhangB Offline
                Bo ZhangB Offline
                Bo Zhang
                wrote on last edited by Bo Zhang
                I just managed to set ethernet MAC with rc.local by writing the following into /etc/rc.local,
                #!/bin/sh
                ifconfig eth0 down
                ifconfig eth0 hw ether 00:xx:xx:xx:xx:xx
                ifconfig eth0 up
                Remember to replace with your MAC to be fixed and to make sure rc.local service is up with the commands below.
                chmod +x /etc/rc.local
                systemctl start rc.local
                systemctl enable rc.local
                systemctl status rc.local
                reboot
                If it doesn't work, check the service status with systemctl to see what went wrong.
                • M mbahrami referenced this topic on
                • Amin BassiriA Offline
                  Amin Bassiri
                  follow this
                  adb shell
                  sudo nano /etc/dhcpcd.conf
                  copy your ip in the page like this:
                  interface wlan0
                  static ip_address=192.168.1.35/24
                  static routers=192.168.1.7
                  static domain_name_servers=192.168.1.7
                  have look at this link also. https://www.makeuseof.com/raspberry-pi-set-static-ip/
