Creating a new client to read from voxl-tflite-server pipe
I see that there is example code for creating a server and client (https://gitlab.com/voxl-public/modal-pipe-architecture/libmodal_pipe/-/tree/master/examples). This is helpful as I am trying to create a client that reads the detection outputs from voxl-tflite-server (https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-tflite-server/-/blob/master/server/models.cpp#L240). However, I'm not sure on how to proceed. Do I need to make my own MPA service and run the client there? Can I add my client in libmodal_pipe and run it there? Do I need to add my client in voxl-tflite-server and run it there?
Hi Steve,
You would likely want your own separate project that uses libmodal_pipe to create the client interface. That can be a systemd service if you want it on boot. MPA encourages lots of separate microservices and projects to all be compiled and run independently to avoid monolithic programs that grow too big and become hard to maintain. Examples such as all the voxl-inspect-*** tools in voxl-mpa-tools also serve as good starting points along with the modal-hello-client example you already found.
I hope this helps,
James
