  3. VOXL as usb2 host not working via j8
voxl
3 Posts 2 Posters 828 Views 1 Watching
  • NirgeN Offline
    NirgeN Offline
    Nirge
    Connecting my laptop to voxl via adb works on j8 connecter.
    However, an STM based device is not recognized when connecting a client device to voxl using micro-usb to micro-usb cable.
    The same device is recognized when connecting via the usb expander (https://docs.modalai.com/usb-expander-and-debug-datasheet/)
    Bus 001 Device 002: ID 0483:5740 STMicroelectronics STM32F407
    https://docs.modalai.com/voxl-as-usb-host/ does not specify any special requirements.
    Am I missing something? is the micro-usb cable needs to be an OTG cable with ID pin?
    Best regards,
    Nir
      Hi @Nirge ,
      A standard cable won't work.
      Some info here:
      https://docs.modalai.com/voxl-datasheets-connectors/#notes-3
      From here: https://docs.modalai.com/voxl-as-usb-host/#background
      Because the USB3.0 SS pins on the VOXL (Snapdragon 821) cannot support TX/RX swapping, they were set to peripheral mode since the 821 is used mainly in phones and peripheral mode is way more commonly used in a phone configuration.
      In order for systems to use the standard micro-b to type A female OTG cables, they need to do TX/RX swapping.
      Since VOXL can't do this, it needs to use a non-standard pinout as its default configuration is peripheral mode in order to get the SS.
      NirgeN 1 Reply Last reply
      • modaltbM modaltb
        Hi @Nirge ,
        Some info here:
        NirgeN Offline
        NirgeN Offline
        Nirge
        @modaltb Using USB 2.
        Got my hands on an OTG adapter, seems to be doing the trick.
