    voxl-emulator won't start
    • J
      jaredjohansen
      I have an Ubuntu 20.04 machine with docker installed.
      I have followed these instructions to install voxl-docker.
      I have downloaded the latest voxl-cross, voxl-emulator, and voxl-hexagon from here. I have used docker load to create docker images from each of these tar.gz files.
      When I try to run the emulator, it gives me the error below:
      jared@jared-ubuntu:~/voxl-docker$ docker images
      REPOSITORY          TAG       IMAGE ID       CREATED          SIZE
      voxl-hexagon        v1.1      f5790a3358ca   19 minutes ago   6.38GB
      voxl-emulator       v1.7      c0709663abe6   20 minutes ago   3.4GB
      voxl-cross          v1.1      77eda1fa0a0e   21 minutes ago   1.06GB
      roskinetic-xenial   v1.0      bfb82886c74f   21 months ago    1.63GB
      registry            0.9.1     56cfd79a53f5   5 years ago      423MB
      jared@jared-ubuntu:~/voxl-docker$ voxl-docker -i voxl-emulator:v1.7 -e "/bin/bash"
      launching image: voxl-emulator:v1.7 with the following command:
      docker run --rm -it --net=host --privileged -w /home/jared --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/jared/voxl-docker:/home/root:rw -w /home/root voxl-emulator:v1.7 /bin/bash
      docker: Error response from daemon: OCI runtime create failed: container_linux.go:380: starting container process caused: exec: "/bin/bash": stat /bin/bash: no such file or directory: unknown.
      As I understand it, It's telling me that there is no such thing as /bin/bash in the container. I don't really believe that is true, because this webpage uses the bash command: voxl-docker -i voxl-emulator -e "/bin/bash build.sh".
      Can you help me understand what I am doing wrong (and why this is not working)?
      What I am trying to (eventually) do is to build my own docker image (in Ubuntu) that I can adb push to my VOXL and run it there. As I understand it, if I docker build <path_to_my_own_dockerfile> on my Ubuntu machine, once I transfer it to the VOXL, it won't work because the architecture is not the same.
      If I want to docker build on my Ubuntu machine and have it work on the VOXL, I believe I will need to run the voxl-emulator and docker build inside of that. Is that correct?
      • J
        jaredjohansen
        • J
          jaredjohansen
          Update: I completely removed docker and voxl-docker from my system.
          I rebooted, reinstalled docker, and followed these steps to install voxl-docker.
          Now, I get a different error (same as here) :
          jared@jared-ubuntu:~/voxl-docker$ voxl-docker -i voxl-emulator -e "/bin/bash"
          launching image: voxl-emulator with the following command:
          docker run --rm -it --net=host --privileged -w /home/jared --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/jared/voxl-docker:/home/root:rw -w /home/root voxl-emulator /bin/bash
          standard_init_linux.go:228: exec user process caused: exec format error
          I followed the instructions at the link. The first two commands ran without any issues. I had to modify the last one to fit my architecture:
          sudo apt-get install qemu binfmt-support qemu-user-static
          docker run --rm --privileged multiarch/qemu-user-static --reset -p yes
          jared@jared-ubuntu:~/voxl-docker$ docker run --rm -t amd64/ubuntu uname -m
          Unable to find image 'amd64/ubuntu:latest' locally
          latest: Pulling from amd64/ubuntu
          7b1a6ab2e44d: Pull complete
          Digest: sha256:7cc0576c7c0ec2384de5cbf245f41567e922aab1b075f3e8ad565f508032df17
          Status: Downloaded newer image for amd64/ubuntu:latest
          x86_64
          That worked. Now the voxl-emulator appears to work too:
          + USER_ID=0
          + USER_NAME=root
          + GID=0
          + getent group 0
          root:x:0:
          + echo 'Starting with UID : 0'
          + useradd --shell /bin/bash -u 0 -g 0 -o -c '' -M root
          useradd: user 'root' already exists
          + addgroup root users
          + export HOME=/home/root
          + HOME=/home/root
          + ls -ld /home/root
          drwxrwxr-x 8 james host_group 4096 Nov  1 21:45 /home/root
          + echo 'root ALL=(ALL) NOPASSWD: ALL'
          + ls -l /etc/sudoers.d/
          total 8
          -rw-r--r-- 1 root root 30 Nov 23  2020 james
          -rw-r--r-- 1 root root 29 Nov  1 22:26 root
          + cat /etc/sudoers.d/root
          + chmod 777 /tmp
          + chmod 711 /usr/bin/sudo
          + chmod +s /usr/bin/sudo
          + ls -l /usr/local/bin/su-exec
          -rwxr-xr-x 1 root root 7660 Aug 14  2018 /usr/local/bin/su-exec
          + ls -l /bin/bash
          -rwxrwxrwx 1 root root 959344 Aug 12  2018 /bin/bash
          + echo 'exec /usr/local/bin/su-exec root /bin/bash'
          + exec /usr/local/bin/su-exec root /bin/bash
          bash-4.3#
