  3. How to Fuse VL53L1X Rangefinder for Height-Above-Ground (HAGL) Estimation with PX4 on VOXL2
1 Posts 1 Posters 250 Views
  • S Offline
    S Offline
    Sarika Sharma
    Hi ModalAI Team,
    I am working with a VOXL2 Mini test fixture (TF-M0104) and trying to integrate a VL53L1X ToF rangefinder with PX4 for altitude hold / height-above-ground estimation.
    My goal is for PX4 EKF2 to fuse the rangefinder data so that the drone can use the sensor for altitude estimation (dist_bottom / HAGL).
    Sensor configuration:
    /etc/modalai/voxl-rangefinder-server.conf
    "i2c_bus": 0,
    "vl53l1x_timing_budget_ms": 50,
    "id_for_mavlink": 0,
    "sensors": [{
    "enabled": true,
    "sensor_id": 0,
    "type": "TOF_VL53L1X",
    "fov_deg": 15,
    "range_max_m": 3,
    "location_wrt_body": [0,0,0],
    "direction_wrt_body": [0,0,1],
    "is_on_mux": false
    PX4 parameters
    EKF2_HGT_REF = 2
    EKF2_RNG_CTRL = 1
    EKF2_RNG_A_HMAX = 11.5 ft
    SENS_EN_VL53L1X : 1
    Sensor data received in PX4
    px4-listener distance_sensor
    current_distance: 0.62
    signal_quality: 100
    orientation: 25
    So PX4 is receiving the rangefinder data correctly.
    However, when I check:
    voxl2-mini-test-fixture (TF-M0104):/etc/modalai$ px4-listener vehicle_local_position
    TOPIC: vehicle_local_position
    timestamp: 1258315007 (0.002534 seconds ago)
    timestamp_sample: 1258313140 (1867 us before timestamp)
    ref_timestamp: 0
    ref_lat: nan
    ref_lon: nan
    x: -58.15529
    y: -29.38294
    z: -43.47373
    delta_xy: [-8.27161, 3.48610]
    delta_z: 0.00000
    vx: -5.77044
    vy: -8.23159
    vz: 0.09748
    z_deriv: 0.09754
    delta_vxy: [-0.89175, 1.40937]
    delta_vz: 0.65828
    ax: 1.33592
    ay: -1.74908
    az: 0.01860
    heading: 2.12604
    delta_heading: 1.62808
    ref_alt: nan
    dist_bottom: 0.10000
    eph: 0.61074
    epv: 0.20321
    evh: 0.41361
    evv: 0.11114
    vxy_max: inf
    vz_max: inf
    hagl_min: inf
    hagl_max: inf
    xy_valid: True
    z_valid: True
    v_xy_valid: True
    v_z_valid: True
    xy_reset_counter: 32
    z_reset_counter: 6
    vxy_reset_counter: 37
    vz_reset_counter: 26
    heading_reset_counter: 17
    heading_good_for_control: False
    xy_global: False
    z_global: False
    dist_bottom_valid: False
    dist_bottom_sensor_bitfield: 0
    dead_reckoning: True
    which means EKF2 is not fusing the rangefinder measurement.
    Am I missing any configuration steps to enable rangefinder fusion for altitude hold on VOXL2?
