  2. Software Development
  3. Ublox zed f9p GPS not connecting
8 Posts 3 Posters 3.6k Views 1 Watching
  • Karteek GandiboyinaK Offline
    Karteek Gandiboyina
    HI,
    Im trying to connect ublox zed f9p 15b(https://www.u-blox.com/en/product/zed-f9p-module). im using voxl2 dev kit.
    i connected the gps to j19 pin (uart at pin 2,3) there seems to be no issue with the connection. but im not getting any gps message published
    tarling-px4-dev-kit (D0011):/$ journalctl -b -u voxl-px4
    -- Logs begin at Mon 2025-11-17 07:25:30 UTC, end at Thu 2026-02-26 20:09:53 UTC. --
    Feb 23 22:58:05 m0054 systemd[1]: Starting px4...
    Feb 23 22:58:07 m0054 systemd[1]: Started px4.
    Feb 23 22:58:07 m0054 voxl-px4[2203]: [INFO] Reading from /etc/modalai/voxl-px4.conf
    Feb 23 22:58:07 m0054 voxl-px4[2203]: Found DSP signature file
    Feb 23 22:58:07 m0054 voxl-px4[2203]: [INFO] Daemon mode enabled
    Feb 23 22:58:07 m0054 voxl-px4[2203]: *************************
    Feb 23 22:58:07 m0054 voxl-px4[2203]: AIRFRAME=MULTICOPTER
    Feb 23 22:58:07 m0054 voxl-px4[2203]: GPS=AUTODETECT
    Feb 23 22:58:07 m0054 voxl-px4[2203]: RC=SPEKTRUM
    Feb 23 22:58:07 m0054 voxl-px4[2203]: ESC=VOXL_ESC
    Feb 23 22:58:07 m0054 voxl-px4[2203]: POWER MANAGER=VOXLPM
    Feb 23 22:58:07 m0054 voxl-px4[2203]: AIRSPEED SENSOR=NONE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: DISTANCE SENSOR=NONE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: OSD=DISABLE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: DAEMON_MODE=ENABLE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: SENSOR_CAL=ACTUAL
    Feb 23 22:58:07 m0054 voxl-px4[2203]: ARTIFACT_MODE=DISABLE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: EXTRA STEPS:
    Feb 23 22:58:07 m0054 voxl-px4[2203]: INFO  [px4] mlockall() enabled. PX4's virtual address space is lock
    Feb 23 22:58:07 m0054 voxl-px4[2203]: INFO  [px4] assuming working directory is rootfs, no symlinks neede
    Feb 23 22:58:07 m0054 voxl-px4[2203]: INFO  [muorb] Got muorb init command
    Feb 23 22:58:07 m0054 voxl-px4[2203]: Sending initialization request
    Feb 23 22:58:07 m0054 voxl-px4[2203]: Got topic data before configuration complete
    Feb 23 22:58:08 m0054 voxl-px4[2203]: *************************
    Feb 23 22:58:08 m0054 voxl-px4[2203]: AIRFRAME: MULTICOPTER
    Feb 23 22:58:08 m0054 voxl-px4[2203]: GPS: AUTODETECT
    Feb 23 22:58:08 m0054 voxl-px4[2203]: RC: SPEKTRUM
    Feb 23 22:58:08 m0054 voxl-px4[2203]: ESC: VOXL_ESC
    Feb 23 22:58:08 m0054 voxl-px4[2203]: POWER MANAGER: VOXLPM
    Feb 23 22:58:08 m0054 voxl-px4[2203]: AIRSPEED SENSOR: NONE
    Feb 23 22:58:08 m0054 voxl-px4[2203]: DISTANCE SENSOR: NONE
    Feb 23 22:58:08 m0054 voxl-px4[2203]: OSD: DISABLE
    Feb 23 22:58:08 m0054 voxl-px4[2203]: ARTIFACT_MODE: DISABLE
    Feb 23 22:58:08 m0054 voxl-px4[2203]: EXTRA STEPS:
    Feb 23 22:58:08 m0054 voxl-px4[2203]: Running on M0054
    Feb 23 22:58:09 m0054 voxl-px4[2203]: INFO  [param] selected parameter default file /data/px4/param/param
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [parameters] BSON document size 2241 bytes, decoded 2241 byte
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Starting IMU driver with no rotation
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'icm42688p start -s'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13807556, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13847307, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [modules__muorb__slpi] muorb aggregator thread runnin
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] muorb protobuf initalize method succeeded
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did ADVERTISE_TEST_TYPE
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread test_MUORB
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did SUBSCRIBE_TEST_TYPE
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did TOPIC_TEST_TYPE
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] muorb test passed
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ______  __   __    ___
    Feb 23 22:58:10 m0054 voxl-px4[2203]: | ___ \ \ \ / /   /   |
    Feb 23 22:58:10 m0054 voxl-px4[2203]: | |_/ /  \ V /   / /| |
    Feb 23 22:58:10 m0054 voxl-px4[2203]: |  __/   /   \  / /_| |
    Feb 23 22:58:10 m0054 voxl-px4[2203]: | |     / /^\ \ \___  |
    Feb 23 22:58:10 m0054 voxl-px4[2203]: \_|     \/   \/     |_/
    Feb 23 22:58:10 m0054 voxl-px4[2203]: px4 starting.
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic log_message
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [parameters] Starting param sync THREAD
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [parameters] Starting param sync THREAD
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] before starting the qshell_entry task
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread qshell
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_qshell with
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell entry.....
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] after starting the qshell_entry task
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Init app map initialized
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_reset_requ
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(parameter_client_reset_response) as
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic parameter_update
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(parameter_server_set_used_request)
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_r
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(parameter_client_set_value_response
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised i
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: icm42688p start -s
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'icm42688p'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg1 = 'start'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-s'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_accel
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_gyro
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [icm42688p] ICM42688P::probe successful!
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] on SPI bus 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] icm42688p #0 on SPI bus 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [icm42688p] >>> ICM42688P this: b26012d8
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: icm42688p start -s
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic qshell_retval
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] Register interrupt b214ec48 e61ebf5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_gyro_fifo
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_accel_fifo
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic imu_server
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'icp101xx'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-I'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '-b'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg4 = '5'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] icp101xx #0 on I2C bus 5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb]  address 0x63
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceINFO  [qshell] Send cmd: 'temper
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13882130, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for qmc5883l magnetometer
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] cmd returned with: -1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13922352, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [qshell] Command failed
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for ist8310 magnetometer
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13958469, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for ist8308 magnetometer
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13998516, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'gps start -d 6 -b 115200'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 14028093, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for ncp5623c RGB LED
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Node(qshell_req) as advertised in process_remote_topic
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: temperature_compensation star
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'temperature_compensation'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_correction
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: temperature_compensati
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'qmc5883l'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-R'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '10'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg4 = '-X'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg5 = '-b'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg6 = '1'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [drivers__device] i2c probe failed
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [SPI_I2C] PX4_qshell: no instance started (no device
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [qshell] Failed to execute command: qmc5883l start -R
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'ist8310'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'ist8308'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '12'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: gps start -d 6 -b 115200
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'gps'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-d'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '6'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg4 = '-b'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg5 = '115200'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread gps
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_gps with ti
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: gps start -d 6 -b 1152
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: land_detector start mu
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_land_detected
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox protocol version: 27.40
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox module: ZED-F9P
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised i
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: manual_control start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'manual_control'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg1 = 'start'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: manual_control start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic manual_control_setpoint
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: control_allocator start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'control_allocator'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic control_allocator_status
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(control_allocator_status) as advert
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_motors
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_servos
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_servos_trim
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: control_allocator star
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: load_mon start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'load_mon'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: load_mon start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic cpuload
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: rc_update start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'rc_update'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: rc_update start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: commander start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'commander'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread commander
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_commander w
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic led_control
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [commaINFO  [qshell] Send cmd: 'commander start'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 16635298, local time:
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'flight_mode_manager start'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 16765888, local time:
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADC
    Feb 23 22:58:19 m0054 voxl-px4[2203]: nder] LED: open /dev/led0 failed (22)
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic tune_control
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: commander start
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic event
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic mavlink_log
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [health_and_arming_checks] Preflight Fail: Accel 0 un
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [health_and_arming_checks] Preflight Fail: Compass Se
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic health_report
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic failsafe_flags
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_armed
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_control_mode
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_status
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic failure_detector_status
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised i
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: flight_mode_manager start
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'flight_mode_manager'
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg1 = 'start'
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_command
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: flight_mode_manager st
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [dataman] data manager file '/data/px4/dataman' size is 78666
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic transponder_report
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic rtl_time_estimate
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic position_setpoint_tri
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic telemetry_status
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [mavlink] partner IP: 127.0.0.1
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic obstacle_distance
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic offboard_control_mode
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic timesync_status
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_controls_status_0
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(vehicle_command_ack) as adv
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 145
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(telemetry_status) as advert
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [px4] Startup script returned successfully
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [logger] logger started (mode=all)
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox protocol version: 27.40
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox module: ZED-F9P
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [health_and_arming_checks] Preflight Fail: Attitude f
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox protocol version: 27.40
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox module: ZED-F9P
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!
    this is the log, i see that the gps is recognized by the voxl but it resets for some reason.
    #!/bin/sh
    # PX4 commands need the 'px4-' prefix in bash.
    # (px4-alias.sh is expected to be in the PATH)
    . px4-alias.sh
    echo -e "\n*************************"
    echo "AIRFRAME: $AIRFRAME"
    echo "GPS: $GPS"
    echo "RC: $RC"
    echo "ESC: $ESC"
    echo "POWER MANAGER: $POWER_MANAGER"
    echo "AIRSPEED SENSOR: $AIRSPEED_SENSOR"
    echo "DISTANCE SENSOR: $DISTANCE_SENSOR"
    echo "OSD: $OSD"
    echo "ARTIFACT_MODE: $ARTIFACT_MODE"
    echo "EXTRA STEPS:"
    for i in "${EXTRA_STEPS[@]}"
    do
            echo -e "\t$i"
    done
    echo -e "*************************\n"
    # In order to just exit after starting the uorb / muorb modules define
    # the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
    # This is useful for testing / debug where you may want to start drivers
    # and modules manually from the px4 command shell
    if [ ! -z $MINIMAL_PX4 ]; then
        /bin/echo "Running minimal script"
        exit 0
    fi
    # Figure out what platform we are running on.
    PLATFORM=`/usr/bin/voxl-platform 2> /dev/null`
    RETURNCODE=$?
    if [ $RETURNCODE -ne 0 ]; then
        # If we couldn't get the platform from the voxl-platform utility then check
        # /etc/version to see if there is an M0052 substring in the version string. If so,
        # then we assume that we are on M0052.
        VERSIONSTRING=$(</etc/version)
        M0052SUBSTRING="M0052"
        if [[ "$VERSIONSTRING" == *"$M0052SUBSTRING"* ]]; then
            PLATFORM="M0052"
        fi
    fi
    # We can only run on M0052, M0054, or M0104 so exit with error if that is not the case
    if [ $PLATFORM = "M0052" ]; then
        /bin/echo "Running on M0052"
    elif [ $PLATFORM = "M0054" ]; then
        /bin/echo "Running on M0054"
    elif [ $PLATFORM = "M0104" ]; then
        /bin/echo "Running on M0104"
    else
        /bin/echo "Error, cannot determine platform!"
        exit 0
    fi
    # Sleep a little here. A lot happens when the uorb and muorb start
    # and we need to make sure that it all completes successfully to avoid
    # any possible race conditions.
    /bin/sleep 1
    param select /data/px4/param/parameters
    # Load in all of the parameters that have been saved in the file
    param load
    # IMU (accelerometer / gyroscope)
    if [ "$PLATFORM" == "M0104" ]; then
        /bin/echo "Starting IMU driver with rotation 12"
        qshell icm42688p start -s -R 12
    else
        /bin/echo "Starting IMU driver with no rotation"
    fi
    # Start Invensense ICP 101xx barometer built on to VOXL 2
    qshell icp101xx start -I -b 5
    qshell temperature_compensation start
    # Auto detect the magnetometer. If one or both of these devices
    # are not connected it will fail but not cause any harm.
    # Rotation 10 = ROLL_180_YAW_90
    /bin/echo "Looking for qmc5883l magnetometer"
    qshell qmc5883l start -R 10 -X -b 1
    /bin/echo "Looking for ist8310 magnetometer"
    qshell ist8310 start -R 10 -X -b 1
    /bin/echo "Looking for ist8308 magnetometer"
    # Rotation 12 = PITCH_180
    qshell ist8308 start -R 12 -X -b 1
    # GPS and magnetometer
    if [ "$GPS" != "NONE" ]; then
            # On M0052 the GPS driver runs on the apps processor
                gps start -d /dev/ttyHS2 -b 115200
            # On M0054 and M0104 the GPS driver runs on SLPI DSP
            else
                qshell gps start -d 6 -b 115200
            fi
    fi
    starling-px4-dev-kit (D0011):/$ px4-listener vehicle_gps_position
    TOPIC: vehicle_gps_position
    starling-px4-dev-kit (D0011):/$ px4-listener sensor_gps
    never published
    this is usr/bin/voxl-px4-start i updated the baudrate to match with my gps ublox baud rate but the problem remains same. Please help
    Karteek GandiboyinaK 1 Reply Last reply
    • Karteek GandiboyinaK Karteek Gandiboyina
      HI,
      #!/bin/sh
      . px4-alias.sh
      echo "GPS: $GPS"
      echo "RC: $RC"
      echo "ESC: $ESC"
      echo "OSD: $OSD"
      echo "EXTRA STEPS:"
      do
              echo -e "\t$i"
      done
          exit 0
      fi
      RETURNCODE=$?
              PLATFORM="M0052"
          fi
      fi
      else
          exit 0
      fi
      /bin/sleep 1
      param load
      else
      fi
              else
              fi
      fi
      never published
      Karteek Gandiboyina
      I used this "https://forum.modalai.com/topic/3257/voxl2-gps-taking-long-time-to-connect-sometimes-never-connects" but it did not help. @Alex-Kushleyev @Eric-Katzfey
        @Karteek-Gandiboyina Unfortunately, we don't have any experience with that unit. It looks like it is hooked up correctly since you get a response from it. What baud rate did you change it to? You can try running the latest version of px4 but we have spent very little time testing it so use with extreme caution: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mainline-px4_1.17.0-1.0.2-202602240859_arm64.deb. Perhaps load that, remove the propellers, and just verify that it can properly see the GPS? And what if you just remove the baud rate option on the start command, does that change anything?
          @Karteek-Gandiboyina Also, for reference: https://forum.modalai.com/topic/4403/starling-2-max-with-ublox-f9p-ultralight/7?_=1772217162290
            Karteek Gandiboyina
            @Eric-Katzfey
                    else
                    fi
            fi
            Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [logger] logger started (mode=all)
            Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] GPS UART baudrate set to 115200
            Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] Got ack to initial CFG_VALSET!
            Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
            Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] u-blox protocol version: 27.40
            Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] u-blox module: ZED-F9P
            Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [health_and_arming_checks] Preflight Fail: Accel
            Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [health_and_arming_checks] Preflight Fail: Attitu
            Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [health_and_arming_checks] Preflight Fail: Compas
            Its the same even without the baudrate. I will try the PX4-mainline option.
            E 1 Reply Last reply
              @Eric-Katzfey
                      else
                      fi
              fi
              E Offline
              E Offline
              emarcphera
              @Karteek-Gandiboyina the gps drivers on px4 1.14 don't support that gps, it fails some configuration step if I remember correctly and that's why it gets stuck in a detected loop. Switching to mainline px4 worked for me.
                Karteek Gandiboyina
                • E emarcphera
                  Karteek Gandiboyina
                  @emarcphera @Eric-Katzfey thank you so much after upgrading to voxl-mainline im getting GPS readingScreenshot from 2026-02-28 01-45-10.png
