  3. Starling 2: No climb above ~20 cm at 2400 m ASL (high altitude), suspect thrust limit
starling
1 Posts 1 Posters 232 Views 1 Watching
  • J Offline
    j-angel
    wrote on last edited by j-angel
    We have a Starling 2 that normally flies at approximately 1000-1300 m above sea level. It starts struggling around 1800 m, and at approximately 2400 m above sea level, it only climbs about 20 cm. Even in manual/PostCtrl mode, it does not climb.
    Observations:
    • Battery charge: 7.3-8 V.
    • Rotor speed: 12,000 RPM.
    • Takeoff is detected, but the drone cannot climb.
    • Geofence and altitude parameter limits were checked (no strict limits were found).
    • The drone's position is estimated using VIO (OpenVins). GPS is disabled, and a barometer is not used to aid in altitude estimation.
    Hypothesis:
    • At high altitude (2400 m), air density reduces thrust; the hover throttle is likely saturated. We increased MPC_THR_MAX and adjusted MPC_THR_HOVER, pending testing.
    Request: Are any adjustments to the PX4 (acceleration/hover/air density) or propeller/motor modifications recommended so that the Starling 2 can maintain flight at approximately 2600 m above sea level?
    Attachment: PX4 Flight log from 2400 meters above sea level.
    https://review.px4.io/plot_app?log=45254900-3c62-4bc8-bcb3-6cf669b0e9e2
