  3. Bricked VOXL2
Bricked VOXL2
3 Posts 2 Posters 481 Views 1 Watching
  • R Offline
    R Offline
    roy.crosthwaite
    wrote on last edited by roy.crosthwaite
    Greetings,
    I have a fully bricked VOXL2 on a Starling 2 Max. I have gone through the forum and documents processes without success and have concluded that there is way more wrong than a typical unbricking can fix. Give you a little history here... This thing has bricked a couple of times and I was able to easily make a full recovery. I updated the SDK to 1.5.0 after the first bricking and everything seemed to be OK. I was going to test a new GPS module (issue submitted under a different forum topic) and had the WiFi set to AP mode so I could connect wirelessly. I powered everything up on the bench, connected via ADB and ran voxl-inspect-gps to see if the new module was detected, and it was. Thinking everything was GTG, I powered down and took the drone outside to verify that it could see satellites. Powered it up and waited for the SSID to become visible and it never did, even after a couple of power cycles. So, back to the bench with it.
    I attempted to do yet another unbricking only to discover that I couldn't communicate with it via USB. adb shell returns no device found and putting it into fastboot (presumably) and fastboot doesn't detect a device either. The only way I see the device is with lsusb or the web interface shown below.Screenshot from 2025-11-06 15-11-45.png
    I find it interesting that it can be detected but not respond to external commands - the lights are on but nobody is home.
    So, where do I go from here?
    Current configuration:
    system-image: 1.8.04-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
    hw platform: M0054
    mach.var: 1.0.1
    SKU: MRB-D0012-4-V2-C29-T9-M24-X0
    voxl-suite: 1.5.0
    N. ChenN 1 Reply Last reply
    • R roy.crosthwaite
      Greetings,
      hw platform: M0054
      mach.var: 1.0.1
      voxl-suite: 1.5.0
      N. ChenN Offline
      N. ChenN Offline
      N. Chen
      @roy-crosthwaite said in Bricked VOXL2:
      I've just received the voxl2, so not a lot of experience with it. Just for me to understand-- why not try to unbrick it with the qdl webUI, as it is the only tool that detects it? I'm asking since I have the my board at the same exact state, but this webUI tool failed, so I'm wondering if you know something that I don't (like whether seeing the device via fastboot is a prerequisite for the unbricking).
      R 1 Reply Last reply
      • N. ChenN N. Chen
        R Offline
        R Offline
        roy.crosthwaite
        @N-Chen I tried the webUI and the command line and as near as I can tell the webUI uses lsusb (or something along those lines) to detect the presence of the board. The install.sh uses adb or fastboot to detect the board and will sit waiting until the board is detected or CTL C is sent. My guess is the usb controller interface is alive and reporting but everything beyond it is dead.
