  3. Flash Flat Build Fails During sahara_run on M0054-1 (VOXL 2)
1 Posts 1 Posters 279 Views
  • E Offline
    E Offline
    eranceder
    Hi ModalAI Team,
    I'm trying to flash the following flat build to my VOXL 2:
    Build: 2024-06-17-1.7.4-M0054-1
    Board: M0054-1
    Tool: QDL Tool (GUI version)
    Status: Device is detected – QDL device connected: Qualcomm Gobi Wireless Modem
    However, the flashing process fails during the sahara_run step. Here's the output from the log:
    Flashing Flat Build…
    {"message": "modal hello\n[MODALAI] test log\n\n[MODALAI] Executing usb_open\n[MODALAI] Completed usb_open\n[MODALAI] Executing sahara_run\n\n\nFlash flat build failed\n"}
    Despite the GUI showing “Flash flat build succeeded” in green at the bottom, the log clearly indicates a failure in sahara_run.
    What I’ve tried so far:
    Multiple USB ports and cables
    Power cycling the board
    Re-downloading the build
    Running as root / with permissions
    Ensuring no other process is using the USB port
    Any suggestions on how to resolve this or what might be going wrong?
