  3. VOXL2 dual tracking
VOXL2 dual tracking
fps 30name hiresname toffps 10
1 Posts 1 Posters 776 Views
  • tkddnjs825T Offline
    tkddnjs825T Offline
    tkddnjs825
    Hello
    I'm using voxl2 is using voxing.Currently, GPS has three-ups to do not use it.
    But there are errors such as photos in the bottom of the picture, but there is a solution?
    Additionally, camera calibration is completed.The camera is used to use m0173 by using m0173 and the rest of the restoration.Additionally, in voxl-server, I wanted to use only dimensions, but I don't want to use a dacking.How can I do it?![KakaoTalk_20250226_101114153.jpg](Request Entity Too Large)
     * voxl-camera-server Configuration File
     * Each camera has configurations for up to 4 HAL3 streams:
     *    - `preview` stream for raw unprocessed images from CV cameras
     *    - `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
     *    - `large_video` 4k (ish) h264/h265 for onboard video recording to disk
     *    - `snapshot` ISP-processed JPG snapshots that get saved to disk
     * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
     * This file is generated from default values by voxl-configure-cameras.
     * Do not expect arbitrary resolutions to work, the ISP and video compression
     * pipelines only support very specific resolutions.
     * The default video compression mode is cqp or Constant Quantization Parameter
            "version":      0.1,
            "fsync_en":     true,
            "fsync_gpio":   109,
            "cameras":      [{
                            "type": "ar0144",
                            "name": "tracking_front",
                            "enabled":      true,
                            "camera_id":    0,
                            "fps":  30,
                            "en_rotate":    true,
                            "en_preview":   true,
                            "preview_width":        1280,
                            "preview_height":       800,
                            "en_raw_preview":       true,
                            "en_misp":      true,
                            "misp_width":   1280,
                            "misp_height":  800,
                            "misp_venc_enable":     false,
                            "misp_venc_mode":       "h264",
                            "misp_venc_br_ctrl":    "cqp",
                            "misp_venc_Qfixed":     30,
                            "misp_venc_Qmin":       15,
                            "misp_venc_Qmax":       50,
                            "misp_venc_nPframes":   29,
                            "misp_venc_mbps":       2,
                            "misp_venc_osd":        false,
                            "misp_awb":     "auto",
                            "ae_mode":      "lme_msv",
                            "gain_min":     54,
                            "gain_max":     8000,
                            "ae_desired_msv":       60,
                            "exposure_min_us":      20,
                            "exposure_max_us":      12000,
                            "exposure_soft_min_us": 5000,
                            "ae_filter_alpha":      0.600000023841858,
                            "ae_ignore_fraction":   0.20000000298023224,
                            "ae_slope":     0.05000000074505806,
                            "ae_exposure_period":   1,
                            "ae_gain_period":       1
                            "type": "imx412",
                            "name": "hires",
                            "enabled":      false,
                            "camera_id":    1,
                            "fps":  30,
                            "en_preview":   false,
                            "preview_width":        640,
                            "preview_height":       480,
                            "en_raw_preview":       false,
                            "en_small_video":       true,
                            "small_video_width":    1024,
                            "small_video_height":   768,
                            "small_venc_mode":      "h264",
                            "small_venc_br_ctrl":   "cqp",
                            "small_venc_Qfixed":    30,
                            "small_venc_Qmin":      15,
                            "small_venc_Qmax":      40,
                            "small_venc_nPframes":  9,
                            "small_venc_mbps":      2,
                            "small_venc_osd":       false,
                            "en_large_video":       true,
                            "large_video_width":    4056,
                            "large_video_height":   3040,
                            "large_venc_mode":      "h264",
                            "large_venc_br_ctrl":   "cqp",
                            "large_venc_Qfixed":    40,
                            "large_venc_Qmin":      15,
                            "large_venc_Qmax":      50,
                            "large_venc_nPframes":  29,
                            "large_venc_mbps":      40,
                            "large_venc_osd":       false,
                            "en_snapshot":  true,
                            "en_snapshot_width":    4056,
                            "en_snapshot_height":   3040,
                            "exif_focal_length":    3.0999999046325684,
                            "exif_focal_length_in_35mm_format":     17,
                            "exif_fnumber": 1.2400000095367432,
                            "ae_mode":      "isp",
                            "gain_min":     54,
                            "gain_max":     8000
                            "type": "pmd-tof-liow2",
                            "name": "tof",
                            "enabled":      true,
                            "camera_id":    2,
                            "fps":  10,
                            "en_rotate":    true,
                            "ae_mode":      "off",
                            "gain_min":     0,
                            "gain_max":     0,
                            "exposure_max_us":      6000,
                            "standby_enabled":      false,
                            "decimator":    5
                            "type": "ar0144",
                            "name": "tracking_down",
                            "enabled":      true,
                            "camera_id":    3,
                            "fps":  30,
                            "en_rotate":    false,
                            "en_preview":   true,
                            "en_misp":      true,
                            "misp_width":   1280,
                            "misp_height":  800,
                            "misp_awb":     "auto",
                            "gain_min":     54,
                            "gain_max":     8000,
                            "ae_gain_period":       1
