  3. HITL voxl2 from docker image
3 Posts 2 Posters 731 Views 1 Watching
  • Shivam SehgalS Offline
    Shivam Sehgal
    wrote on last edited by Shivam Sehgal
    I am trying to do HITL using voxl2
    Below is output of vol-services and voxl-version
    voxl2:~$ voxl-inspect-services
    Scanning services...
     voxl-camera-server       |  Enabled  | Not Running |
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-imu-server          | Disabled  | Not Running |
     voxl-mavcam-manager      | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     0.5%
     voxl-microdds-agent      |  Enabled  |   Running   |     0.4%
     voxl-neopixel-manager    | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.1%
     voxl-px4-imu-server      | Disabled  | Not Running |
     voxl-px4                 | Disabled  | Not Running |
     voxl-qvio-server         | Disabled  | Not Running |
     voxl-streamer            |  Enabled  |   Running   |     0.1%
     voxl-tag-detector        |  Enabled  |   Running   |     0.0%
     voxl-tflite-server       |  Enabled  |   Running   |     0.1%
     voxl-vision-hub          |  Enabled  |   Running   |     0.4%
    voxl2:~$ voxl-version
    system-image: 1.7.1-M0054-14.1a-perf-nightly-20231025
    kernel:       #1 SMP PREEMPT Thu Oct 26 03:25:38 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:   1.1.2
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/
    Last Updated: 2024-05-07 06:01:21
    List:
    	libmodal-cv                 0.4.0
    	libmodal-exposure           0.1.0
    	libmodal-journal            0.2.2
    	libmodal-json               0.4.3
    	libmodal-pipe               2.9.2
    	libqrb5165-io               0.4.2
    	libvoxl-cci-direct          0.2.1
    	libvoxl-cutils              0.1.1
    	mv-voxl                     0.1-r0
    	qrb5165-bind                0.1-r0
    	qrb5165-dfs-server          0.2.0
    	qrb5165-imu-server          1.0.1
    	qrb5165-rangefinder-server  0.1.1
    	qrb5165-slpi-test-sig       01-r0
    	qrb5165-system-tweaks       0.2.3
    	qrb5165-tflite              2.8.0-2
    	voxl-bind-spektrum          0.1.0
    	voxl-camera-calibration     0.5.3
    	voxl-camera-server          1.8.9.1
    	voxl-configurator           0.4.8
    	voxl-cpu-monitor            0.4.7
    	voxl-docker-support         1.3.0
    	voxl-elrs                   0.1.3
    	voxl-esc                    1.3.7
    	voxl-feature-tracker        0.3.2
    	voxl-flow-server            0.3.3
    	voxl-jpeg-turbo             2.1.3-5
    	voxl-lepton-server          1.2.0
    	voxl-logger                 0.3.5
    	voxl-mavcam-manager         0.5.3
    	voxl-mavlink                0.1.1
    	voxl-mavlink-server         1.3.2
    	voxl-microdds-agent         2.4.1-0
    	voxl-modem                  1.0.8
    	voxl-mongoose               7.7.0-1
    	voxl-mpa-to-ros             0.3.7
    	voxl-mpa-to-ros2            0.0.2
    	voxl-mpa-tools              1.1.3
    	voxl-neopixel-manager       0.0.3
    	voxl-opencv                 4.5.5-2
    	voxl-portal                 0.6.3
    	voxl-px4                    1.14.0-2.0.63
    	voxl-px4-imu-server         0.1.2
    	voxl-px4-params             0.3.3
    	voxl-qvio-server            1.0.0
    	voxl-ros2-foxy              0.0.1
    	voxl-streamer               0.7.4
    	voxl-suite                  1.1.2
    	voxl-tag-detector           0.0.4
    	voxl-tflite-server          0.3.2
    	voxl-utils                  1.3.3
    	voxl-uvc-server             0.1.6
    	voxl-vision-hub             1.7.3
    	voxl2-system-image          1.7.1-r0
    	voxl2-wlan                  1.0-r0
    I followed the docker setup, ran the docker. Gazebo launches with this output.
    (base) swarm_researchers@swarm-Alienware-Aurora-R16:~$ docker run --rm -it --net=host --privileged -e DISPLAY=$DISPLAY -v /dev/input:/dev/input:rw -v /tmp/.X11-unix:/tmp/.X11-unix:ro voxl-gazebo-docker ./run_gazebo.bash
    GAZEBO_PLUGIN_PATH :/usr/workspace/voxl2_hitl_gazebo
    GAZEBO_MODEL_PATH :/usr/workspace/voxl2_hitl_gazebo/models
    LD_LIBRARY_PATH :/usr/workspace/voxl2_hitl_gazebo/build
    Warning [parser.cc:833] XML Attribute[version] in element[sdf] not defined in SDF, ignoring.
    Opened serial device /dev/ttyUSB0
    I adb shell onto voxl2 and run voxl-px4-hitl.
    voxl2:/$ voxl-px4-hitl
    Found DSP signature file
    INFO  [muorb] SLPI: muorb aggregator thread running
    INFO  [muorb] SLPI: Creating pthread test_MUORB
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-hitl-start 0
    INFO  [muorb] SLPI: Advertising remote topic log_message
    Running on M0054
    INFO  [muorb] SLPI: Starting param sync THREAD
    INFO  [muorb] SLPI: before starting the qshell_entry task
    INFO  [muorb] SLPI: Creating pthread qshell
    INFO  [muorb] SLPI: qshell entry.....
    INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
    INFO  [muorb] SLPI: Init app map initialized
    INFO  [muorb] SLPI: after starting the qshell_entry task
    INFO  [param] selected parameter default file /data/px4/param/hitl_parameters
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Advertising remote topic parameter_update
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
    INFO  [parameters] BSON document size 1620 bytes, decoded 1620 bytes (INT32:41, FLOAT:36)
    INFO  [logger] logger started (mode=all)
    INFO  [logger] Start file log (type: full)
    INFO  [logger] [logger] /data/px4/log/2024-10-23/16_58_03.ulg
    INFO  [muorb] SLPI: Advertising remote topic mavlink_log
    INFO  [logger] Opened full log file: /data/px4/log/2024-10-23/16_58_03.ulg
    INFO  [muorb] SLPI: Advertising remote topic event
    INFO  [muorb] SLPI: Advertising remote topic logger_status
    INFO  [qshell] Send cmd: 'sensors start -h'
    INFO  [muorb] SLPI: qshell gotten: sensors start -h
    INFO  [muorb] SLPI:   arg0 = 'sensors'
    INFO  [muorb] SLPI:   arg1 = 'start'
    INFO  [muorb] SLPI:   arg2 = '-h'
    INFO  [uORB] Advertising remote topic sensor_selection
    INFO  [uORB] Advertising remote topic sensors_status_imu
    INFO  [uORB] Advertising remote topic vehicle_acceleration
    INFO  [uORB] Advertising remote topic vehicle_angular_velocity
    INFO  [uORB] Advertising remote topic sensor_combined
    INFO  [uORB] Advertising remote topic vehicle_air_data
    INFO  [uORB] Advertising remote topic vehicle_gps_position
    INFO  [uORB] Advertising remote topic vehicle_magnetometer
    INFO  [uORB] Advertising remote topic sensor_preflight_mag
    INFO  [muorb] SLPI: Ok executing command: sensors start -h
    INFO  [qshell] qshell return value timestamp: 3280312226, local time: 3280315844
    INFO  [muorb] SLPI: qshell gotten: ekf2 start
    INFO  [muorb] SLPI:   arg0 = 'ekf2'
    INFO  [qshell] Send cmd: 'ekf2 start'
    INFO  [uORB] Advertising remote topic vehicle_attitude
    INFO  [uORB] Advertising remote topic vehicle_local_position
    INFO  [uORB] Advertising remote topic estimator_event_flags
    INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
    INFO  [uORB] Advertising remote topic estimator_innovation_variances
    INFO  [uORB] Advertising remote topic estimator_innovations
    INFO  [uORB] Advertising remote topic estimator_sensor_bias
    INFO  [uORB] Advertising remote topic estimator_states
    INFO  [uORB] Advertising remote topic estimator_status_flags
    INFO  [muorb] SLPI: Ok executing command: ekf2 start
    INFO  [qshell] qshell return value timestamp: 3280586205, local time: 3280590513
    INFO  [qshell] Send cmd: 'mc_pos_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_pos_control'
    INFO  [uORB] Advertising remote topic takeoff_status
    INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
    INFO  [qshell] qshell return value timestamp: 3280705576, local time: 3280706809
    INFO  [qshell] Send cmd: 'mc_att_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_att_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_att_control'
    INFO  [muorb] SLPI: Ok executing command: mc_att_control start
    INFO  [qshell] qshell return value timestamp: 3280759599, local time: 3280761703
    INFO  [qshell] Send cmd: 'mc_rate_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_rate_control'
    INFO  [uORB] Advertising remote topic rate_ctrl_status
    INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
    INFO  [qshell] qshell return value timestamp: 3280865439, local time: 3280867108
    INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
    INFO  [muorb] SLPI:   arg0 = 'mc_hover_thrust_estimator'
    INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
    INFO  [qshell] qshell return value timestamp: 3280906031, local time: 3280907747
    INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_autotune_attitude_control'
    INFO  [uORB] Advertising remote topic autotune_attitude_control_status
    INFO  [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
    INFO  [qshell] qshell return value timestamp: 3280944959, local time: 3280946333
    INFO  [qshell] Send cmd: 'land_detector start multicopter'
    INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
    INFO  [muorb] SLPI:   arg0 = 'land_detector'
    INFO  [muorb] SLPI:   arg2 = 'multicopter'
    INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
    INFO  [qshell] qshell return value timestamp: 3280986143, local time: 3280988769
    INFO  [qshell] Send cmd: 'manual_control start'
    INFO  [muorb] SLPI: qshell gotten: manual_control start
    INFO  [muorb] SLPI:   arg0 = 'manual_control'
    INFO  [uORB] Advertising remote topic vehicle_land_detected
    INFO  [muorb] SLPI: Ok executing command: manual_control start
    INFO  [uORB] Advertising remote topic manual_control_setpoint
    INFO  [qshell] qshell return value timestamp: 3281037294, local time: 3281039572
    INFO  [muorb] SLPI: qshell gotten: control_allocator start
    INFO  [muorb] SLPI:   arg0 = 'control_allocator'
    INFO  [qshell] Send cmd: 'control_allocator start'
    INFO  [uORB] Advertising remote topic control_allocator_status
    INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    INFO  [uORB] Advertising remote topic actuator_motors
    INFO  [uORB] Advertising remote topic actuator_servos
    INFO  [uORB] Advertising remote topic actuator_servos_trim
    INFO  [muorb] SLPI: Ok executing command: control_allocator start
    INFO  [qshell] qshell return value timestamp: 3281289624, local time: 3281291468
    INFO  [qshell] Send cmd: 'rc_update start'
    INFO  [muorb] SLPI: qshell gotten: rc_update start
    INFO  [muorb] SLPI:   arg0 = 'rc_update'
    INFO  [muorb] SLPI: Ok executing command: rc_update start
    INFO  [qshell] qshell return value timestamp: 3281573754, local time: 3281575359
    INFO  [muorb] SLPI: qshell gotten: commander start -h
    INFO  [muorb] SLPI:   arg0 = 'commander'
    INFO  [muorb] SLPI: Creating pthread commander
    INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097647
    INFO  [qshell] Send cmd: 'commander start -h'
    INFO  [uORB] Advertising remote topic led_control
    INFO  [muorb] SLPI: Ok executing command: commander start -h
    INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
    INFO  [uORB] Advertising remote topic tune_control
    INFO  [qshell] qshell return value timestamp: 3281758211, local time: 3281760473
    INFO  [muorb] SLPI: orb_advertise_multi: failed to set queue size
    INFO  [muorb] SLPI: Preflight Fail: Accel Sensor 0 missing
    INFO  [muorb] SLPI: Preflight Fail: barometer 0 missing
    INFO  [muorb] SLPI: Preflight Fail: ekf2 missing data
    INFO  [muorb] SLPI: Preflight Fail: Gyro Sensor 0 missing
    INFO  [muorb] SLPI: Preflight Fail: Compass Sensor 0 missing
    INFO  [uORB] Advertising remote topic health_report
    INFO  [uORB] Advertising remote topic failsafe_flags
    INFO  [uORB] Advertising remote topic actuator_armed
    INFO  [uORB] Advertising remote topic vehicle_control_mode
    INFO  [uORB] Advertising remote topic vehicle_status
    INFO  [uORB] Advertising remote topic failure_detector_status
    INFO  [qshell] Send cmd: 'commander mode posctl'
    INFO  [muorb] SLPI: qshell gotten: commander mode posctl
    INFO  [muorb] SLPI:   arg1 = 'mode'
    INFO  [muorb] SLPI:   arg2 = 'posctl'
    INFO  [uORB] Advertising remote topic vehicle_command
    INFO  [muorb] SLPI: Ok executing command: commander mode posctl
    INFO  [qshell] qshell return value timestamp: 3281789206, local time: 3281789998
    INFO  [uORB] Advertising remote topic vehicle_command_ack
    INFO  [qshell] Send cmd: 'load_mon start'
    INFO  [muorb] SLPI: qshell gotten: load_mon start
    INFO  [muorb] SLPI:   arg0 = 'load_mon'
    INFO  [muorb] SLPI: Ok executing command: load_mon start
    INFO  [uORB] Advertising remote topic cpuload
    INFO  [qshell] qshell return value timestamp: 3281817661, local time: 3281818749
    INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
    INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
    INFO  [qshell] Send cmd: 'flight_mode_manager start'
    INFO  [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
    INFO  [qshell] qshell return value timestamp: 3281917546, local time: 3281919416
    INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    INFO  [muorb] SLPI: Advertising remote topic transponder_report
    INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
    INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
    INFO  [qshell] Send cmd: 'pwm_out_sim start -m hil'
    INFO  [muorb] SLPI: qshell gotten: pwm_out_sim start -m hil
    INFO  [muorb] SLPI:   arg0 = 'pwm_out_sim'
    INFO  [muorb] SLPI:   arg2 = '-m'
    INFO  [muorb] SLPI:   arg3 = 'hil'
    INFO  [uORB] Advertising remote topic actuator_outputs
    INFO  [muorb] SLPI: Ok executing command: pwm_out_sim start -m hil
    INFO  [uORB] Advertising remote topic actuator_outputs_sim
    INFO  [qshell] qshell return value timestamp: 3283106378, local time: 3283108095
    INFO  [qshell] Send cmd: 'dsp_hitl start -g -m'
    INFO  [muorb] SLPI: qshell gotten: dsp_hitl start -g -m
    INFO  [muorb] SLPI:   arg0 = 'dsp_hitl'
    INFO  [muorb] SLPI:   arg2 = '-g'
    INFO  [muorb] SLPI:   arg3 = '-m'
    INFO  [muorb] SLPI: Creating pthread dsp_hitl__main
    INFO  [muorb] SLPI: Successfully created px4 task PX4_dsp_hitl__main with tid 2097645
    INFO  [muorb] SLPI: Ok executing command: dsp_hitl start -g -m
    ERROR [muorb] SLPI: Port is open: 0
    INFO  [muorb] SLPI: Got 5 from orb_subscribe
    INFO  [qshell] qshell return value timestamp: 3283136557, local time: 3283138431
    INFO  [uORB] Advertising remote topic esc_status
    INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    INFO  [mavlink] partner IP: 127.0.0.1
    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    INFO  [muorb] SLPI: Advertising remote topic timesync_status
    INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO  [uORB] Advertising remote topic vehicle_imu
    INFO  [uORB] Advertising remote topic vehicle_imu_status
    INFO  [muorb] SLPI: Too many arming check events (1, 14 > 14). Not reporting all
    INFO  [muorb] SLPI: Preflight Fail: No valid data from Accel 0
    INFO  [muorb] SLPI: Preflight Fail: No valid data from Gyro 0
    INFO  [microdds_client] synchronized with time offset 1729699404643157us
    INFO  [muorb] SLPI: Marking DeviceNode(timesync_status) as advertised in process_remote_topic
    INFO  [microdds_client] successfully created rt/fmu/out/failsafe_flags data writer, topic id: 80
    INFO  [microdds_client] successfully created rt/fmu/out/position_setpoint_triplet data writer, topic id: 159
    INFO  [microdds_client] successfully created rt/fmu/out/timesync_status data writer, topic id: 200
    INFO  [microdds_client] successfully created rt/fmu/out/vehicle_control_mode data writer, topic id: 223
    INFO  [microdds_client] successfully created rt/fmu/out/vehicle_status data writer, topic id: 240
    INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    pxh>
    **Also, when I run voxl-px-hitl the drone model sinks under asphalt, am I doing something wrong, do I need to change the model inside run_gazebo.bash.
    I think am using the correct cable, mentioned in one of the post. Is there a way to check the cable.**
    Shivam SehgalS 1 Reply Last reply
    • Shivam SehgalS Shivam Sehgal
      hw version:   M0054
      voxl-suite:   1.1.2
      Packages:
      List:
      	libmodal-cv                 0.4.0
      	libmodal-json               0.4.3
      	libmodal-pipe               2.9.2
      	libqrb5165-io               0.4.2
      	mv-voxl                     0.1-r0
      	qrb5165-bind                0.1-r0
      	voxl-elrs                   0.1.3
      	voxl-esc                    1.3.7
      	voxl-logger                 0.3.5
      	voxl-mavlink                0.1.1
      	voxl-modem                  1.0.8
      	voxl-opencv                 4.5.5-2
      	voxl-portal                 0.6.3
      	voxl-streamer               0.7.4
      	voxl-suite                  1.1.2
      	voxl-utils                  1.3.3
      	voxl2-wlan                  1.0-r0
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      Running on M0054
      pxh>
      Shivam Sehgal
      @Shivam-Sehgal Never mind I was able to make it work by interchanging the tx - rx wires.
      Is there a specific implementation of starling drone with all it's sensors?
        Eric KatzfeyE Online
        @Shivam-Sehgal No, there is no Starling model in Gazebo.
