  3. Seeker MPA to ROS Pointcloud Topic
seeker
1 Posts 1 Posters 611 Views
  • T Offline
    T Offline
    tholmes17
    I'm trying to use rviz to view the pointcloud made by the seeker. I'm using these instructions: https://docs.modalai.com/seeker-user-guide-vio/
    Upon running roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch, I get this output:
    ... logging to /home/root/.ros/log/7c7e0f0e-1dda-11b2-a220-18473db1c84b/roslaunch-apq8096-21073.log
    Checking log directory for disk usage. This may take awhile.
    Press Ctrl-C to interrupt
    started roslaunch server http://192.168.8.1:39686/
    SUMMARY
    PARAMETERS
    /rosdistro: indigo
    /rosversion: 1.11.21
    NODES
    voxl_mpa_to_ros_node (voxl_mpa_to_ros/voxl_mpa_to_ros_node)
    auto-starting new master
    process[master]: started with pid [21092]
    ROS_MASTER_URI=http://192.168.8.1:11311/
    setting /run_id to 7c7e0f0e-1dda-11b2-a220-18473db1c84b
    process[rosout-1]: started with pid [21105]
    process[voxl_mpa_to_ros_node-2]: started with pid [21112]
    MPA to ROS app is now running
    Found new interface: qvio_overlay
    Found new interface: stereo
    Found new interface: tracking
    Found new interface: imu0
    Found new interface: imu1
    Found new interface: voa_pc_out
    No tof topic is produced by the node when running. What am I missing? Thanks in advance!
