  3. Setting up network interfaces
7 Posts 4 Posters 2.0k Views 4 Watching
  • ryan_meagherR Offline
    ryan_meagher
    So I am trying to find the place where I can setup network interfaces in order to assign a static ip address for eth0. On the rb5 I can do this via modifying the /etc/dhcpcd.conf file; however, this isn't present on the voxl. I see all the interfaces via ifconfig -a and the corresponding sys/class/net but there doesn't seem to be .network of ifcfg files there.
    I would have thought that the interfaces would either be in /etc/sysconfig/network-scripts/ifcfg-eth* or in /etc/network/interfaces where I could modify files that could be brought up via ifconfig eth0 up but this doesn't seem to be the case.
    Right now I am doing this via enabling a systemd service
    set -e
    ETH_ADD=192.168.2.120
    ifconfig eth0 up || (echo " failed to open eth0" && exit 1)
    ip addr add ${ETH_ADD}/24 dev eth0 || (echo " failed to add ip link eth0" && exit 1)
    I see that this can be done in the poky_build but any suggestions as to where this can be done on the voxl in a more Linux-esque way?
    Ryan Meagher
    • tomT Offline
      @ryan_meagher You should be able to do this using the /etc/network/interfaces approach you mentioned. voxl-modem uses that approach in order to set a static IP for Microhard on eth0. This is what the /etc/network/interfaces file looks like in that case:
      # This file describes the network interfaces available on your system
      # The primary network interface
      auto eth0
      iface eth0 inet static
      	address 192.168.168.100
      	netmask 255.255.255.0
      	gateway 192.168.168.1
      NirgeN 1 Reply Last reply
        ryan_meagher
        @tom Thanks for the info, my voxl didn't have a default /etc/network directory which is what threw me off.
        Ryan Meagher
          auto eth0
          NirgeN Offline
          NirgeN Offline
          Nirge
          Hi @tom
          I tried this for wlan0 and it doesn't work for me, am I missing a configuration for out-of-the-box VOXL before I can add /etc/network/interfaces? or is it overriden by voxl-wifi?
          • tomT Offline
            @Nirge Are you using WiFi in Station mode or in SoftAP mode?
              NirgeN Offline
              NirgeN Offline
              Nirge
              @tom Originaly configured it station, did not change it when tried to configure it to static.
              • NirgeN Nirge
                @Nirge You should use voxl-wifi for wlan0.
