  3. vvhub_body_wrt_local missing
2 Posts 1 Posters 314 Views
  • Михаил ОдинцовМ Offline
    Михаил Одинцов
    wrote on last edited by Михаил Одинцов
    What could be the reason for vvhub_body_wrt_local disappearance? I had it working before, but since the last week it's not in the list of pipes, running
    voxl-inspect-pose -l
    shows
    waiting for server at /run/mpa/vvhub_body_wrt_local/
    and running almost any command except the manual mode flying errors with reason being no good local pose estimate (can't use global one for my use case, no GPS signal available)
    What hardware are you using?
    Starling 2 (TOF + 3 tracking)
    What version of software are you using?
    voxl2:~$ voxl-version
    dpkg-query: package 'voxl-suite' is not installed and no information is available
    Use dpkg --info (= dpkg-deb --info) to examine archive files,
    and dpkg --contents (= dpkg-deb --contents) to list their contents.
    system-image: 1.7.8-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Sat May 18 00:10:25 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    voxl-suite:
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.3/binary-arm64/
    Last Updated: 2024-09-02 07:28:20
    List:
    libmodal-exposure                         0.1.0
    libmodal-pipe                             2.10.1
    libqrb5165-io                             0.4.6
    libvoxl-cci-direct                        0.2.3
    modalai-slpi                              1.1.19
    qrb5165-imu-server                        1.0.1
    qrb5165-rangefinder-server                0.1.3
    qrb5165-system-tweaks                     0.3.0
    voxl-camera-server                        1.9.8
    voxl-configurator                         0.7.8
    voxl-cpu-monitor                          0.4.8
    voxl-elrs                                 0.2.1
    voxl-esc                                  1.4.5
    voxl-lepton-server                        1.2.2
    voxl-logger                               0.4.3
    voxl-mapper                               0.2.2
    voxl-mavcam-manager                       0.5.6
    voxl-mavlink-server                       1.4.2
    voxl-microdds-agent                       2.4.1-0
    voxl-modem                                1.1.3
    voxl-mpa-to-ros2                          0.0.4
    voxl-mpa-tools                            1.1.9
    voxl-neopixel-manager                     0.0.3
    voxl-nlopt                                2.5.0-4
    voxl-portal                               0.6.9
    voxl-px4                                  1.14.0-2.0.79
    voxl-px4-params                           0.4.7
    voxl-qvio-server                          1.0.4
    voxl-ros2-foxy                            0.0.1
    voxl-streamer                             0.7.4
    voxl-utils                                1.4.2
    voxl-voxblox                              1.1.5
    voxl-vtx                                  1.0.3
    voxl2-system-image                        1.7.8-r0
    How have you configured the software?
    voxl2:~$ voxl-inspect-services
    Scanning services...
     voxl-camera-server       |  Enabled  |   Running   |   102.0%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.3%
     voxl-imu-server          |  Enabled  |   Running   |     3.6%
     voxl-mapper              |  Enabled  |   Running   |     1.1%
     voxl-mavlink-server      |  Enabled  |   Running   |     1.7%
     voxl-microdds-agent      | Disabled  | Not Running |
     voxl-neopixel-manager    | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.1%
     voxl-px4-imu-server      | Disabled  | Not Running |
     voxl-px4                 |  Enabled  |   Running   |    19.1%
     voxl-qvio-server         |  Enabled  |   Running   |    36.1%
     voxl-rangefinder-server  |  Enabled  |   Running   |     0.0%
     voxl-streamer            |  Enabled  |   Running   |     0.0%
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
      Михаил Одинцов
      Nvm, solved, for some reason the voxl-vision-hub disappeared from the list, reinstall helped.
      Now I wonder why the ... it disappeared, but at least I'm unblocked.
