  3. TfLite - Multiple Models Simultaneously
sentinel
1 Posts 1 Posters 681 Views
  • J Offline
    jasote
    Hello all,
    I am trying to deploy more than 1 deep learning models, mainly to understand how things work. So, i.e. I am trying to deploy both mobilenet and deeplab.
    I do follow the docs (https://docs.modalai.com/voxl-tflite-server/), however I am unable to make both of models to work in the same time.
    These are my approaches:
    Approach 1:
    Changed the file /etc/modalai/voxl-tflite-server.conf and set
    'allow_multiple': true and changed the output_pipe_prefix.
    I run the command voxl-confure-tflite. I selected:
    No factory reset,
    enable voxl-tfliteserver and
    camera front stereo and
    selected the mobilenet.
    The service is running and I can see it through portal.
    Consequently, I edited again the /etc/modalai/voxl-tflite-server.conf, to change the prefix. Did the same, but selected the deeplab model. Regarding cameras, I tried both the same (stereo front) and different (hires,tracking).
    The deeplab is running, by replacing the mobilenet, every time.
    Approach 2:
    I created distinct /etc/modalai/voxl-tflite-server.conf files, named
    /etc/modalai/voxl-tflite-server-mobilenet.conf and /etc/modalai/voxl-tflite-server-deeplab.conf,
    each one with relevant configurations (allow multiple, different prefix, correct model path for each model, and input_pipe /run/mpa/tracking and /run/mpa/stereo/ accordingly).
    I created a service for each, by copying and altering the file /etc/systemd/system/voxl-tflite-server.service, by adding the corresponding path to each conf.
    Changed the description, the PIDFile (i.e. /run/voxl-tflite-server-mobilenet.pid) and the ExecStart line to point the corresponding file
    (i.e. /bin/bach -c "/usr/bin/voxl-tflite-server --config /etc/modalai/voxl-tflite-server-mobilenet.conf").
    I enabled and started the service. Same for both.
    Still they are not working simultaneously. To be precise, although I was able to run via this way a service, now they are failing no matter what I do.
    Our goal is to finally run multiple models simultaneously both pre-installed and custom models.
    Could someone please help me on how to make it run multiple models, what I am doing wrong, or what is the correct actions?
