Pictures from Stereo Camera
I want to take pictures from the stereo cameras. Is there a way to do this through voxl-send-command or any other terminal command?
@Samuel-Bryan , you can use a tool
voxl-record-raw-imagewhich can save the monochrome stereo images in RAW8 format (8 bits per pixel).voxl2:~/$ voxl-record-raw-image -h Record a raw image from an MPA pipe to disk This is typically used for inspecting raw or YUV image data formatting or for loading into something like MATLAB or OpenCV for post-processing. Optional arguments are: -d, --dir {dir} directory to save output files in (default: /data/raw-images/) -h, --help print this help message -n, --num-images {n} number of images to save from the pipe (default 1) typical usage: /# voxl-record-video tracking /# voxl-record-video tracking -d /data/tracking_test_1/ -n 10 -
voxl-record-raw-imagewhich can save the monochrome stereo images in RAW8 format (8 bits per pixel).voxl2:~/$ voxl-record-raw-image -h Record a raw image from an MPA pipe to disk This is typically used for inspecting raw or YUV image data formatting or for loading into something like MATLAB or OpenCV for post-processing. Optional arguments are: -d, --dir {dir} directory to save output files in (default: /data/raw-images/) -h, --help print this help message -n, --num-images {n} number of images to save from the pipe (default 1) typical usage: /# voxl-record-video tracking /# voxl-record-video tracking -d /data/tracking_test_1/ -n 10@Alex-Kushleyev Thanks for the reply. We tried this on our voxl1, but it didn't work. We get an error saying "Invalid option -- "d"". Is there a way to get this working on voxl1 on the m500?
@Samuel-Bryan , you may have an older version of the
voxl-mpa-toolspackage. You can try upgrading it from here (you may also need to upgrade libmodal-pipe to 2.10.1).Alex
