  2. Software Development
  3. ROS
  4. Trouble in running the mavros_test Project (simple-example)
7 Posts 2 Posters 2.1k Views
  • Captain 7thC Offline
    Captain 7th
    I have trouble running the mavros_test Project (simple-example) (https://docs.modalai.com/mavros/#mavros_test-project-simple-example).
    I followed all the instructions carefully, and when I ran:
    cd /home/mavros_test
    ./run_mavros_test.sh
    I got this on the terminal:
    voxl2:/home/mavros_test(simple-example)$ ./run_mavros_test.sh
    ... logging to /home/root/.ros/log/740b46ce-42c4-11ef-b08e-00c0cab5abe5/roslaunch-m0054-5058.log
    Checking log directory for disk usage. This may take a while.
    Press Ctrl-C to interrupt
    started roslaunch server http://192.168.1.45:39563/
    SUMMARY
    CLEAR PARAMETERS
     * /mavros/
    PARAMETERS
     * /mavros/camera/frame_id: base_link
     * /mavros/cmd/use_comp_id_system_control: False
     * /mavros/conn/heartbeat_rate: 1.0
     * /mavros/conn/system_time_rate: 1.0
     * /mavros/conn/timeout: 10.0
     * /mavros/conn/timesync_rate: 10.0
     * /mavros/distance_sensor/hrlv_ez4_pub/field_of_view: 0.0
     * /mavros/distance_sensor/hrlv_ez4_pub/frame_id: hrlv_ez4_sonar
     * /mavros/distance_sensor/hrlv_ez4_pub/id: 0
     * /mavros/distance_sensor/hrlv_ez4_pub/orientation: PITCH_270
     * /mavros/distance_sensor/hrlv_ez4_pub/send_tf: True
     * /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/x: 0.0
     * /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/y: 0.0
     * /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/z: -0.1
     * /mavros/distance_sensor/laser_1_sub/id: 3
     * /mavros/distance_sensor/laser_1_sub/orientation: PITCH_270
     * /mavros/distance_sensor/laser_1_sub/subscriber: True
     * /mavros/distance_sensor/lidarlite_pub/field_of_view: 0.0
     * /mavros/distance_sensor/lidarlite_pub/frame_id: lidarlite_laser
     * /mavros/distance_sensor/lidarlite_pub/id: 1
     * /mavros/distance_sensor/lidarlite_pub/orientation: PITCH_270
     * /mavros/distance_sensor/lidarlite_pub/send_tf: True
     * /mavros/distance_sensor/lidarlite_pub/sensor_position/x: 0.0
     * /mavros/distance_sensor/lidarlite_pub/sensor_position/y: 0.0
     * /mavros/distance_sensor/lidarlite_pub/sensor_position/z: -0.1
     * /mavros/distance_sensor/sonar_1_sub/horizontal_fov_ratio: 1.0
     * /mavros/distance_sensor/sonar_1_sub/id: 2
     * /mavros/distance_sensor/sonar_1_sub/orientation: PITCH_270
     * /mavros/distance_sensor/sonar_1_sub/subscriber: True
     * /mavros/distance_sensor/sonar_1_sub/vertical_fov_ratio: 1.0
     * /mavros/fake_gps/eph: 2.0
     * /mavros/fake_gps/epv: 2.0
     * /mavros/fake_gps/fix_type: 3
     * /mavros/fake_gps/geo_origin/alt: 408.0
     * /mavros/fake_gps/geo_origin/lat: 47.3667
     * /mavros/fake_gps/geo_origin/lon: 8.55
     * /mavros/fake_gps/gps_rate: 5.0
     * /mavros/fake_gps/mocap_transform: True
     * /mavros/fake_gps/satellites_visible: 5
     * /mavros/fake_gps/tf/child_frame_id: fix
     * /mavros/fake_gps/tf/frame_id: map
     * /mavros/fake_gps/tf/listen: False
     * /mavros/fake_gps/tf/rate_limit: 10.0
     * /mavros/fake_gps/tf/send: False
     * /mavros/fake_gps/use_mocap: True
     * /mavros/fake_gps/use_vision: False
     * /mavros/fcu_protocol: v2.0
     * /mavros/fcu_url: udp://127.0.0.1:1...
     * /mavros/gcs_url:
     * /mavros/global_position/child_frame_id: base_link
     * /mavros/global_position/frame_id: map
     * /mavros/global_position/gps_uere: 1.0
     * /mavros/global_position/rot_covariance: 99999.0
     * /mavros/global_position/tf/child_frame_id: base_link
     * /mavros/global_position/tf/frame_id: map
     * /mavros/global_position/tf/global_frame_id: earth
     * /mavros/global_position/tf/send: False
     * /mavros/global_position/use_relative_alt: True
     * /mavros/image/frame_id: px4flow
     * /mavros/imu/angular_velocity_stdev: 0.0003490659 // 0...
     * /mavros/imu/frame_id: base_link
     * /mavros/imu/linear_acceleration_stdev: 0.0003
     * /mavros/imu/magnetic_stdev: 0.0
     * /mavros/imu/orientation_stdev: 1.0
     * /mavros/landing_target/camera/fov_x: 2.0071286398
     * /mavros/landing_target/camera/fov_y: 2.0071286398
     * /mavros/landing_target/image/height: 480
     * /mavros/landing_target/image/width: 640
     * /mavros/landing_target/land_target_type: VISION_FIDUCIAL
     * /mavros/landing_target/listen_lt: False
     * /mavros/landing_target/mav_frame: LOCAL_NED
     * /mavros/landing_target/target_size/x: 0.3
     * /mavros/landing_target/target_size/y: 0.3
     * /mavros/landing_target/tf/child_frame_id: camera_center
     * /mavros/landing_target/tf/frame_id: landing_target
     * /mavros/landing_target/tf/listen: False
     * /mavros/landing_target/tf/rate_limit: 10.0
     * /mavros/landing_target/tf/send: True
     * /mavros/local_position/frame_id: map
     * /mavros/local_position/tf/child_frame_id: base_link
     * /mavros/local_position/tf/frame_id: map
     * /mavros/local_position/tf/send: False
     * /mavros/local_position/tf/send_fcu: False
     * /mavros/mission/pull_after_gcs: True
     * /mavros/mission/use_mission_item_int: True
     * /mavros/mocap/use_pose: True
     * /mavros/mocap/use_tf: False
     * /mavros/mount/debounce_s: 4.0
     * /mavros/mount/err_threshold_deg: 10.0
     * /mavros/mount/negate_measured_pitch: False
     * /mavros/mount/negate_measured_roll: False
     * /mavros/mount/negate_measured_yaw: False
     * /mavros/odometry/fcu/odom_child_id_des: base_link
     * /mavros/odometry/fcu/odom_parent_id_des: map
     * /mavros/plugin_blacklist: ['safety_area', '...
     * /mavros/plugin_whitelist: []
     * /mavros/px4flow/frame_id: px4flow
     * /mavros/px4flow/ranger_fov: 0.118682
     * /mavros/px4flow/ranger_max_range: 5.0
     * /mavros/px4flow/ranger_min_range: 0.3
     * /mavros/safety_area/p1/x: 1.0
     * /mavros/safety_area/p1/y: 1.0
     * /mavros/safety_area/p1/z: 1.0
     * /mavros/safety_area/p2/x: -1.0
     * /mavros/safety_area/p2/y: -1.0
     * /mavros/safety_area/p2/z: -1.0
     * /mavros/setpoint_accel/send_force: False
     * /mavros/setpoint_attitude/reverse_thrust: False
     * /mavros/setpoint_attitude/tf/child_frame_id: target_attitude
     * /mavros/setpoint_attitude/tf/frame_id: map
     * /mavros/setpoint_attitude/tf/listen: False
     * /mavros/setpoint_attitude/tf/rate_limit: 50.0
     * /mavros/setpoint_attitude/use_quaternion: False
     * /mavros/setpoint_position/mav_frame: LOCAL_NED
     * /mavros/setpoint_position/tf/child_frame_id: target_position
     * /mavros/setpoint_position/tf/frame_id: map
     * /mavros/setpoint_position/tf/listen: False
     * /mavros/setpoint_position/tf/rate_limit: 50.0
     * /mavros/setpoint_raw/thrust_scaling: 1.0
     * /mavros/setpoint_velocity/mav_frame: LOCAL_NED
     * /mavros/startup_px4_usb_quirk: False
     * /mavros/sys/disable_diag: False
     * /mavros/sys/min_voltage: 10.0
     * /mavros/target_component_id: 1
     * /mavros/target_system_id: 1
     * /mavros/tdr_radio/low_rssi: 40
     * /mavros/time/time_ref_source: fcu
     * /mavros/time/timesync_avg_alpha: 0.6
     * /mavros/time/timesync_mode: MAVLINK
     * /mavros/vibration/frame_id: base_link
     * /mavros/vision_pose/tf/child_frame_id: vision_estimate
     * /mavros/vision_pose/tf/frame_id: odom
     * /mavros/vision_pose/tf/listen: False
     * /mavros/vision_pose/tf/rate_limit: 10.0
     * /mavros/vision_speed/listen_twist: True
     * /mavros/vision_speed/twist_cov: True
     * /mavros/wheel_odometry/child_frame_id: base_link
     * /mavros/wheel_odometry/count: 2
     * /mavros/wheel_odometry/frame_id: odom
     * /mavros/wheel_odometry/send_raw: True
     * /mavros/wheel_odometry/send_twist: False
     * /mavros/wheel_odometry/tf/child_frame_id: base_link
     * /mavros/wheel_odometry/tf/frame_id: odom
     * /mavros/wheel_odometry/tf/send: False
     * /mavros/wheel_odometry/use_rpm: False
     * /mavros/wheel_odometry/vel_error: 0.1
     * /mavros/wheel_odometry/wheel0/radius: 0.05
     * /mavros/wheel_odometry/wheel0/x: 0.0
     * /mavros/wheel_odometry/wheel0/y: -0.15
     * /mavros/wheel_odometry/wheel1/radius: 0.05
     * /mavros/wheel_odometry/wheel1/x: 0.0
     * /mavros/wheel_odometry/wheel1/y: 0.15
     * /rosdistro: melodic
     * /rosversion: 1.14.13
    NODES
        mavros (mavros/mavros_node)
        mavros_test_node (mavros_test/mavros_test_node)
    auto-starting new master
    process[master]: started with pid [5072]
    ROS_MASTER_URI=http://127.0.0.1:11311/
    setting /run_id to 740b46ce-42c4-11ef-b08e-00c0cab5abe5
    process[rosout-1]: started with pid [5083]
    process[mavros-2]: started with pid [5091]
    process[mavros_test_node-3]: started with pid [5092]
    [ INFO] [1721059701.053944604]: simple_demo
    [ INFO] [1721059701.184390643]: FCU URL: udp://127.0.0.1:14551@:14551
    [ INFO] [1721059701.186887064]: udp0: Bind address: 127.0.0.1:14551
    [ INFO] [1721059701.186984362]: GCS bridge disabled
    [ INFO] [1721059701.198153822]: Plugin 3dr_radio loaded
    [ INFO] [1721059701.206209164]: Plugin 3dr_radio initialized
    [ INFO] [1721059701.206311202]: Plugin actuator_control loaded
    [ INFO] [1721059701.209795450]: Plugin actuator_control initialized
    [ INFO] [1721059701.215531831]: Plugin adsb loaded
    [ INFO] [1721059701.220162824]: Plugin adsb initialized
    [ INFO] [1721059701.220375235]: Plugin altitude loaded
    [ INFO] [1721059701.223591756]: Plugin altitude initialized
    [ INFO] [1721059701.224009285]: Plugin cam_imu_sync loaded
    [ INFO] [1721059701.224724230]: Plugin cam_imu_sync initialized
    [ INFO] [1721059701.224842050]: Plugin camera loaded
    [ INFO] [1721059701.225575017]: Plugin camera initialized
    [ INFO] [1721059701.225867745]: Plugin cellular_status loaded
    [ INFO] [1721059701.228871335]: Plugin cellular_status initialized
    [ INFO] [1721059701.229033274]: Plugin command loaded
    [ INFO] [1721059701.234510887]: Plugin command initialized
    [ INFO] [1721059701.234635114]: Plugin companion_process_status loaded
    [ INFO] [1721059701.236884851]: Plugin companion_process_status initialized
    [ INFO] [1721059701.237013975]: Plugin debug_value loaded
    [ INFO] [1721059701.240331753]: Plugin debug_value initialized
    [ INFO] [1721059701.240368943]: Plugin distance_sensor blacklisted
    [ INFO] [1721059701.240454939]: Plugin esc_status loaded
    [ INFO] [1721059701.241189572]: Plugin esc_status initialized
    [ INFO] [1721059701.241286818]: Plugin esc_telemetry loaded
    [ INFO] [1721059701.242087394]: Plugin esc_telemetry initialized
    [ INFO] [1721059701.242218392]: Plugin fake_gps loaded
    [ INFO] [1721059701.255931099]: Plugin fake_gps initialized
    [ INFO] [1721059701.256196169]: Plugin ftp loaded
    [ INFO] [1721059701.262559781]: Plugin ftp initialized
    [ INFO] [1721059701.262688435]: Plugin geofence loaded
    [ INFO] [1721059701.264421262]: Plugin geofence initialized
    [ INFO] [1721059701.264509289]: Plugin global_position loaded
    [ INFO] [1721059701.274271205]: Plugin global_position initialized
    [ INFO] [1721059701.274368920]: Plugin gps_input loaded
    [ INFO] [1721059701.276500941]: Plugin gps_input initialized
    [ INFO] [1721059701.276609125]: Plugin gps_rtk loaded
    [ INFO] [1721059701.278799535]: Plugin gps_rtk initialized
    [ INFO] [1721059701.278885739]: Plugin gps_status loaded
    [ INFO] [1721059701.280354224]: Plugin gps_status initialized
    [ INFO] [1721059701.280445950]: Plugin guided_target loaded
    [ INFO] [1721059701.282821528]: Plugin guided_target initialized
    [ INFO] [1721059701.282942057]: Plugin hil loaded
    [ INFO] [1721059701.291681143]: Plugin hil initialized
    [ INFO] [1721059701.291835894]: Plugin home_position loaded
    [ INFO] [1721059701.294077349]: Plugin home_position initialized
    [ INFO] [1721059701.294178085]: Plugin imu loaded
    [ INFO] [1721059701.300978601]: Plugin imu initialized
    [ INFO] [1721059701.301082046]: Plugin landing_target loaded
    [ INFO] [1721059701.319874526]: Plugin landing_target initialized
    [ INFO] [1721059701.320027037]: Plugin local_position loaded
    [ INFO] [1721059701.324364728]: Plugin local_position initialized
    [ INFO] [1721059701.324495102]: Plugin log_transfer loaded
    [ INFO] [1721059701.329005201]: Plugin log_transfer initialized
    [ INFO] [1721059701.329123543]: Plugin mag_calibration_status loaded
    [ INFO] [1721059701.329793693]: Plugin mag_calibration_status initialized
    [ INFO] [1721059701.329883803]: Plugin manual_control loaded
    [ INFO] [1721059701.331578919]: Plugin manual_control initialized
    [ INFO] [1721059701.331655799]: Plugin mocap_pose_estimate loaded
    [ INFO] [1721059701.333844907]: Plugin mocap_pose_estimate initialized
    [ INFO] [1721059701.333922933]: Plugin mount_control loaded
    [ WARN] [1721059701.336751772]: Could not retrive negate_measured_roll parameter value, using default (0)
    [ WARN] [1721059701.336996216]: Could not retrive negate_measured_pitch parameter value, using default (0)
    [ WARN] [1721059701.337240659]: Could not retrive negate_measured_yaw parameter value, using default (0)
    [ WARN] [1721059701.338031234]: Could not retrive debounce_s parameter value, using default (4.000000)
    [ WARN] [1721059701.338254374]: Could not retrive err_threshold_deg parameter value, using default (10.000000)
    [ INFO] [1721059701.338292658]: Plugin mount_control initialized
    [ INFO] [1721059701.338385269]: Plugin nav_controller_output loaded
    [ INFO] [1721059701.338699821]: Plugin nav_controller_output initialized
    [ INFO] [1721059701.338771649]: Plugin obstacle_distance loaded
    [ INFO] [1721059701.340162109]: Plugin obstacle_distance initialized
    [ INFO] [1721059701.340228520]: Plugin odom loaded
    [ INFO] [1721059701.342990427]: Plugin odom initialized
    [ INFO] [1721059701.343101841]: Plugin onboard_computer_status loaded
    [ INFO] [1721059701.344622934]: Plugin onboard_computer_status initialized
    [ INFO] [1721059701.344730337]: Plugin param loaded
    [ INFO] [1721059701.347169931]: Plugin param initialized
    [ INFO] [1721059701.347327546]: Plugin play_tune loaded
    [ INFO] [1721059701.349693801]: Plugin play_tune initialized
    [ INFO] [1721059701.349777765]: Plugin px4flow loaded
    [ INFO] [1721059701.354768887]: Plugin px4flow initialized
    [ INFO] [1721059701.355008018]: Plugin rallypoint loaded
    [ INFO] [1721059701.357594340]: Plugin rallypoint initialized
    [ INFO] [1721059701.357646896]: Plugin rangefinder blacklisted
    [ INFO] [1721059701.357734819]: Plugin rc_io loaded
    [ INFO] [1721059701.360371405]: Plugin rc_io initialized
    [ INFO] [1721059701.360420887]: Plugin safety_area blacklisted
    [ INFO] [1721059701.360521363]: Plugin setpoint_accel loaded
    [ INFO] [1721059701.362749275]: Plugin setpoint_accel initialized
    [ INFO] [1721059701.362888295]: Plugin setpoint_attitude loaded
    [ INFO] [1721059701.369753920]: Plugin setpoint_attitude initialized
    [ INFO] [1721059701.369872991]: Plugin setpoint_position loaded
    [ INFO] [1721059701.379478126]: Plugin setpoint_position initialized
    [ INFO] [1721059701.379646210]: Plugin setpoint_raw loaded
    [ INFO] [1721059701.385296127]: Plugin setpoint_raw initialized
    [ INFO] [1721059701.385406291]: Plugin setpoint_trajectory loaded
    [ INFO] [1721059701.390939481]: Plugin setpoint_trajectory initialized
    [ INFO] [1721059701.391086262]: Plugin setpoint_velocity loaded
    [ INFO] [1721059701.394824486]: Plugin setpoint_velocity initialized
    [ INFO] [1721059701.394964912]: Plugin sys_status loaded
    [ INFO] [1721059701.408650950]: Plugin sys_status initialized
    [ INFO] [1721059701.408896332]: Plugin sys_time loaded
    [ INFO] [1721059701.414709801]: TM: Timesync mode: MAVLINK
    [ INFO] [1721059701.415076233]: TM: Not publishing sim time
    [ INFO] [1721059701.416871928]: Plugin sys_time initialized
    [ INFO] [1721059701.416999020]: Plugin terrain loaded
    [ INFO] [1721059701.419657066]: Plugin terrain initialized
    [ INFO] [1721059701.419786294]: Plugin trajectory loaded
    [ INFO] [1721059701.426208555]: Plugin trajectory initialized
    [ INFO] [1721059701.426340699]: Plugin tunnel loaded
    [ INFO] [1721059701.428138166]: Plugin tunnel initialized
    [ INFO] [1721059701.428232912]: Plugin vfr_hud loaded
    [ INFO] [1721059701.428621063]: Plugin vfr_hud initialized
    [ INFO] [1721059701.428662681]: Plugin vibration blacklisted
    [ INFO] [1721059701.428737113]: Plugin vision_pose_estimate loaded
    [ INFO] [1721059701.435602217]: Plugin vision_pose_estimate initialized
    [ INFO] [1721059701.435714933]: Plugin vision_speed_estimate loaded
    [ INFO] [1721059701.437805857]: Plugin vision_speed_estimate initialized
    [ INFO] [1721059701.437895342]: Plugin waypoint loaded
    [ INFO] [1721059701.440488800]: Plugin waypoint initialized
    [ INFO] [1721059701.440527449]: Plugin wheel_odometry blacklisted
    [ INFO] [1721059701.440773507]: Plugin wind_estimation loaded
    [ INFO] [1721059701.442031249]: Plugin wind_estimation initialized
    [ INFO] [1721059701.442183187]: Built-in SIMD instructions: ARM NEON
    [ INFO] [1721059701.442203397]: Built-in MAVLink package version: 2022.12.30
    [ INFO] [1721059701.442223242]: Known MAVLink dialects: common ardupilotmega ASLUAV AVSSUAS all cubepilot development icarous matrixpilot paparazzi standard storm32 uAvionix ualberta
    [ INFO] [1721059701.442239128]: MAVROS started. MY ID 1.240, TARGET ID 1.1
    [ INFO] [1721059706.087746519]: waiting for offboard mode
    . The problem is here: When I switch between manual and offboard, the drone does not arm/disarm as expected in the video tutorial and instructions!
    Note 1: Here is my IP address, and detail of the config files:
    amirmahdi@amirmahdi:~$ ifconfig
    docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
            ether 02:42:72:03:47:05  txqueuelen 0  (Ethernet)
            RX packets 0  bytes 0 (0.0 B)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 0  bytes 0 (0.0 B)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    enp45s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            ether b4:45:06:94:a8:b6  txqueuelen 1000  (Ethernet)
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 14480  bytes 1380176 (1.3 MB)
            TX packets 14480  bytes 1380176 (1.3 MB)
    wlp0s20f3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 192.168.1.5  netmask 255.255.255.0  broadcast 192.168.1.255
            inet6 fe80::e9cf:ce9f:8897:56e4  prefixlen 64  scopeid 0x20<link>
            ether cc:15:31:2b:bc:95  txqueuelen 1000  (Ethernet)
            RX packets 4029202  bytes 3659491459 (3.6 GB)
            TX packets 318206  bytes 62215059 (62.2 MB)
    amirmahdi@amirmahdi:~$ ssh -X root@192.168.1.45
    root@192.168.1.45's password:
    Welcome to Ubuntu 18.04.6 LTS (GNU/Linux 4.19.125 aarch64)
     * Documentation:  https://help.ubuntu.com
     * Management:     https://landscape.canonical.com
     * Support:        https://ubuntu.com/pro
    This system has been minimized by removing packages and content that are
    not required on a system that users do not log into.
    To restore this content, you can run the 'unminimize' command.
    Last login: Mon Jul 15 15:58:42 2024 from 192.168.1.5
    system-image: 1.7.8-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri May 17 23:29:23 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0.0
    voxl-suite:   1.3.1~beta1
    current IP:   wlan0: 192.168.1.45
    voxl2:~$ more /home/mavros_test/ros_environment.sh
    #!/bin/bash
    # load main ros environment
    if [ -f /opt/ros/melodic/setup.bash ]; then
        source /opt/ros/melodic/setup.bash
    elif [ -f /opt/ros/kinetic/setup.bash ]; then
        source /opt/ros/kinetic/setup.bash
    elif [ -f /opt/ros/indigo/setup.bash ]; then
        source /opt/ros/indigo/setup.bash
    fi
    source catkin_ws/install/setup.bash
    unset ROS_HOSTNAME
    # configure ROS IPs here
    export ROS_MASTER_IP=127.0.0.1
    export ROS_IP=192.168.1.45
    export ROS_MASTER_URI=http://${ROS_MASTER_IP}:11311/
    # mavros needs to know what PX4's system id is
    export PX4_SYS_ID=1
    And here is the voxl-vision-hub.conf:
    voxl2:~$ more /etc/modalai/voxl-vision-hub.conf
    	"config_file_version":	1,
    	"qgc_ip":                     "192.168.1.5",
    	"en_localhost_mavlink_udp":	true,
    	"localhost_udp_port_number":	14551,
    	"en_vio":	true,
    	"vio_pipe":	"qvio",
    	"secondary_vio_pipe":	"ov",
    	"en_reset_vio_if_initialized_inverted":	true,
    	"vio_warmup_s":	3,
    	"send_odom_while_failed":	true,
    	"horizon_cal_tolerance":	0.5,
    	"offboard_mode":	"off",
    	"follow_tag_id":	0,
    	"figure_eight_move_home":	true,
    	"robot_radius":	0.300000011920929,
    	"collision_sampling_dt":	0.1,
    	"max_lookahead_distance":	1,
    	"backtrack_seconds":	5,
    	"wps_move_home":	true,
    	"wps_stride":	0,
    	"wps_timeout":	0,
    	"wps_damp":	1,
    	"en_tag_fixed_frame":	false,
    	"fixed_frame_filter_len":	5,
    	"en_transform_mavlink_pos_setpoints_from_fixed_frame":	false,
    	"en_voa":	true,
    	"voa_upper_bound_m":	-0.15000000596046448,
    	"voa_lower_bound_m":	0.15000000596046448,
    	"voa_voa_memory_s":	1,
    	"voa_max_pc_per_fusion":	100,
    	"voa_pie_max_dist_m":	20,
    	"voa_pie_min_dist_m":	0.25,
    	"voa_pie_under_trim_m":	1,
    	"voa_pie_threshold":	3,
    	"voa_send_rate_hz":	20,
    	"voa_pie_slices":	36,
    	"voa_pie_bin_depth_m":	0.15000000596046448,
    	"voa_inputs":	[{
    			"enabled":	true,
    			"type":	"point_cloud",
    			"input_pipe":	"dfs_point_cloud",
    			"frame":	"stereo_l",
    			"max_depth":	8,
    			"min_depth":	0.300000011920929,
    			"cell_size":	0.079999998211860657,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    			"enabled":	true,
    			"input_pipe":	"stereo_front_pc",
    			"frame":	"stereo_front_l",
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    			"enabled":	true,
    			"input_pipe":	"stereo_rear_pc",
    			"frame":	"stereo_rear_l",
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    			"enabled":	true,
    			"type":	"tof",
    			"input_pipe":	"tof",
    			"frame":	"tof",
    			"max_depth":	6,
    			"min_depth":	0.15000000596046448,
    			"threshold":	3,
    			"x_fov_deg":	106.5,
    			"y_fov_deg":	85.0999984741211,
    			"conf_cutoff":	125
    			"enabled":	true,
    			"type":	"rangefinder",
    			"input_pipe":	"rangefinders",
    			"frame":	"body",
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    Note 2: I could manually arm/disarm the Sentinel drone with QGC and RC. The motors are working properly. But this ros example is not working here! Can anyone help me?
    Note 3: I also tried to change the mode channel to 5 and 6, but still not working!
    This is a photo for QGC. As you can see, I could manually arm the drone and have a connection to the drone.
    Captain 7thC 1 Reply Last reply
    • Captain 7thC Captain 7th
      SUMMARY
      CLEAR PARAMETERS
       * /mavros/
      PARAMETERS
       * /mavros/gcs_url:
      NODES
      hw platform:  M0054
      mach.var:     1.0.0
      #!/bin/bash
      fi
      unset ROS_HOSTNAME
      export PX4_SYS_ID=1
      	"en_vio":	true,
      	"vio_pipe":	"qvio",
      	"vio_warmup_s":	3,
      	"follow_tag_id":	0,
      	"wps_stride":	0,
      	"wps_timeout":	0,
      	"wps_damp":	1,
      	"en_voa":	true,
      	"voa_inputs":	[{
      			"enabled":	true,
      			"max_depth":	8,
      			"threshold":	4,
      			"x_fov_deg":	68,
      			"y_fov_deg":	56,
      			"conf_cutoff":	0
      			"enabled":	true,
      			"max_depth":	8,
      			"threshold":	4,
      			"x_fov_deg":	68,
      			"y_fov_deg":	56,
      			"conf_cutoff":	0
      			"enabled":	true,
      			"max_depth":	8,
      			"threshold":	4,
      			"x_fov_deg":	68,
      			"y_fov_deg":	56,
      			"conf_cutoff":	0
      			"enabled":	true,
      			"type":	"tof",
      			"frame":	"tof",
      			"max_depth":	6,
      			"threshold":	3,
      			"x_fov_deg":	106.5,
      			"conf_cutoff":	125
      			"enabled":	true,
      			"frame":	"body",
      			"max_depth":	8,
      			"threshold":	4,
      			"x_fov_deg":	68,
      			"y_fov_deg":	56,
      			"conf_cutoff":	0
      Captain 7th
      @Captain-7th . The problem is here: When I switch between manual and offboard, the drone does not arm/disarm as expected in the video tutorial and instructions!
      B 1 Reply Last reply
      • Captain 7thC Captain 7th referenced this topic on
        B Offline
        B Offline
        brahim
        wrote on last edited by brahim
        @Captain-7th Can you do a rostopic echo of
        /mavros/state
        You should be able to see info printed if the autopilot is connected or disconnected.
        • B brahim
          /mavros/state
          Captain 7th
          @brahim
          Thank you for your reply. Here is the info from ros topic:
          header:
            seq: 72
            stamp:
              secs: 1726594638
              nsecs: 117869663
            frame_id: ''
          connected: True
          armed: False
          guided: False
          manual_input: False
          mode: "OFFBOARD"
          system_status: 3
          header:
            seq: 73
            stamp:
              secs: 1726594639
              nsecs: 117602864
            frame_id: ''
          connected: True
          armed: False
          guided: False
          manual_input: True
          mode: "MANUAL"
          system_status: 3
          When I run the simple-example, and then I switch between the "offboard" and "manual", the drone is not able to get armed! Here is the message on the terminal:
          ... logging to /home/root/.ros/log/d9e22bd2-751b-11ef-bd2d-00c0cab5abe5/roslaunch-m0054-2796.log
          started roslaunch server http://192.168.1.45:46595/
          SUMMARY
          CLEAR PARAMETERS
           * /mavros/
          PARAMETERS
           * /mavros/gcs_url:
          NODES
          process[master]: started with pid [2810]
          setting /run_id to d9e22bd2-751b-11ef-bd2d-00c0cab5abe5
          process[rosout-1]: started with pid [2821]
          process[mavros-2]: started with pid [2829]
          process[mavros_test_node-3]: started with pid [2830]
          [ INFO] [1726594796.214120407]: simple_demo
          [ INFO] [1726594796.314832807]: FCU URL: udp://127.0.0.1:14551@:14551
          [ INFO] [1726594796.317305328]: udp0: Bind address: 127.0.0.1:14551
          [ INFO] [1726594796.319478270]: GCS bridge disabled
          [ INFO] [1726594796.330857244]: Plugin 3dr_radio loaded
          [ INFO] [1726594796.332309413]: Plugin 3dr_radio initialized
          [ INFO] [1726594796.332392694]: Plugin actuator_control loaded
          [ INFO] [1726594796.334354336]: Plugin actuator_control initialized
          [ INFO] [1726594796.338348870]: Plugin adsb loaded
          [ INFO] [1726594796.340326814]: Plugin adsb initialized
          [ INFO] [1726594796.340427021]: Plugin altitude loaded
          [ INFO] [1726594796.341168262]: Plugin altitude initialized
          [ INFO] [1726594796.341253834]: Plugin cam_imu_sync loaded
          [ INFO] [1726594796.342251790]: Plugin cam_imu_sync initialized
          [ INFO] [1726594796.342400851]: Plugin camera loaded
          [ INFO] [1726594796.342852200]: Plugin camera initialized
          [ INFO] [1726594796.342942459]: Plugin cellular_status loaded
          [ INFO] [1726594796.344562803]: Plugin cellular_status initialized
          [ INFO] [1726594796.344652281]: Plugin command loaded
          [ INFO] [1726594796.348940405]: Plugin command initialized
          [ INFO] [1726594796.349052644]: Plugin companion_process_status loaded
          [ INFO] [1726594796.350713196]: Plugin companion_process_status initialized
          [ INFO] [1726594796.350805330]: Plugin debug_value loaded
          [ INFO] [1726594796.354203569]: Plugin debug_value initialized
          [ INFO] [1726594796.354248621]: Plugin distance_sensor blacklisted
          [ INFO] [1726594796.354333360]: Plugin esc_status loaded
          [ INFO] [1726594796.355075121]: Plugin esc_status initialized
          [ INFO] [1726594796.355161578]: Plugin esc_telemetry loaded
          [ INFO] [1726594796.355564230]: Plugin esc_telemetry initialized
          [ INFO] [1726594796.355666156]: Plugin fake_gps loaded
          [ INFO] [1726594796.366434304]: Plugin fake_gps initialized
          [ INFO] [1726594796.366559198]: Plugin ftp loaded
          [ INFO] [1726594796.370116029]: Plugin ftp initialized
          [ INFO] [1726594796.370203996]: Plugin geofence loaded
          [ INFO] [1726594796.371933715]: Plugin geofence initialized
          [ INFO] [1726594796.372017203]: Plugin global_position loaded
          [ INFO] [1726594796.383542581]: Plugin global_position initialized
          [ INFO] [1726594796.383671538]: Plugin gps_input loaded
          [ INFO] [1726594796.385748387]: Plugin gps_input initialized
          [ INFO] [1726594796.385841147]: Plugin gps_rtk loaded
          [ INFO] [1726594796.387900705]: Plugin gps_rtk initialized
          [ INFO] [1726594796.387991224]: Plugin gps_status loaded
          [ INFO] [1726594796.389556830]: Plugin gps_status initialized
          [ INFO] [1726594796.389657506]: Plugin guided_target loaded
          [ INFO] [1726594796.393238243]: Plugin guided_target initialized
          [ INFO] [1726594796.393468448]: Plugin hil loaded
          [ INFO] [1726594796.400807732]: Plugin hil initialized
          [ INFO] [1726594796.401154134]: Plugin home_position loaded
          [ INFO] [1726594796.404127952]: Plugin home_position initialized
          [ INFO] [1726594796.404220503]: Plugin imu loaded
          [ INFO] [1726594796.408209828]: Plugin imu initialized
          [ INFO] [1726594796.408310504]: Plugin landing_target loaded
          [ INFO] [1726594796.419679895]: Plugin landing_target initialized
          [ INFO] [1726594796.419817497]: Plugin local_position loaded
          [ INFO] [1726594796.424506762]: Plugin local_position initialized
          [ INFO] [1726594796.424627073]: Plugin log_transfer loaded
          [ INFO] [1726594796.428045208]: Plugin log_transfer initialized
          [ INFO] [1726594796.428182810]: Plugin mag_calibration_status loaded
          [ INFO] [1726594796.429988205]: Plugin mag_calibration_status initialized
          [ INFO] [1726594796.430065079]: Plugin manual_control loaded
          [ INFO] [1726594796.431586987]: Plugin manual_control initialized
          [ INFO] [1726594796.431664694]: Plugin mocap_pose_estimate loaded
          [ INFO] [1726594796.435245379]: Plugin mocap_pose_estimate initialized
          [ INFO] [1726594796.435333190]: Plugin mount_control loaded
          [ WARN] [1726594796.438282841]: Could not retrive negate_measured_roll parameter value, using default (0)
          [ WARN] [1726594796.438520651]: Could not retrive negate_measured_pitch parameter value, using default (0)
          [ WARN] [1726594796.438761690]: Could not retrive negate_measured_yaw parameter value, using default (0)
          [ WARN] [1726594796.439565846]: Could not retrive debounce_s parameter value, using default (4.000000)
          [ WARN] [1726594796.439798239]: Could not retrive err_threshold_deg parameter value, using default (10.000000)
          [ INFO] [1726594796.439838343]: Plugin mount_control initialized
          [ INFO] [1726594796.439924592]: Plugin nav_controller_output loaded
          [ INFO] [1726594796.442058888]: Plugin nav_controller_output initialized
          [ INFO] [1726594796.442160293]: Plugin obstacle_distance loaded
          [ INFO] [1726594796.444083603]: Plugin obstacle_distance initialized
          [ INFO] [1726594796.444191518]: Plugin odom loaded
          [ INFO] [1726594796.446595187]: Plugin odom initialized
          [ INFO] [1726594796.446678050]: Plugin onboard_computer_status loaded
          [ INFO] [1726594796.450546440]: Plugin onboard_computer_status initialized
          [ INFO] [1726594796.450646543]: Plugin param loaded
          [ INFO] [1726594796.452225794]: Plugin param initialized
          [ INFO] [1726594796.452388136]: Plugin play_tune loaded
          [ INFO] [1726594796.454038167]: Plugin play_tune initialized
          [ INFO] [1726594796.454121812]: Plugin px4flow loaded
          [ INFO] [1726594796.457780725]: Plugin px4flow initialized
          [ INFO] [1726594796.457911140]: Plugin rallypoint loaded
          [ INFO] [1726594796.459707316]: Plugin rallypoint initialized
          [ INFO] [1726594796.459784294]: Plugin rangefinder blacklisted
          [ INFO] [1726594796.460000750]: Plugin rc_io loaded
          [ INFO] [1726594796.461943694]: Plugin rc_io initialized
          [ INFO] [1726594796.461972548]: Plugin safety_area blacklisted
          [ INFO] [1726594796.462042808]: Plugin setpoint_accel loaded
          [ INFO] [1726594796.463607736]: Plugin setpoint_accel initialized
          [ INFO] [1726594796.463691017]: Plugin setpoint_attitude loaded
          [ INFO] [1726594796.468460645]: Plugin setpoint_attitude initialized
          [ INFO] [1726594796.468569081]: Plugin setpoint_position loaded
          [ INFO] [1726594796.477376837]: Plugin setpoint_position initialized
          [ INFO] [1726594796.477515898]: Plugin setpoint_raw loaded
          [ INFO] [1726594796.482752291]: Plugin setpoint_raw initialized
          [ INFO] [1726594796.482866248]: Plugin setpoint_trajectory loaded
          [ INFO] [1726594796.492653679]: Plugin setpoint_trajectory initialized
          [ INFO] [1726594796.492846750]: Plugin setpoint_velocity loaded
          [ INFO] [1726594796.497461849]: Plugin setpoint_velocity initialized
          [ INFO] [1726594796.497638149]: Plugin sys_status loaded
          [ INFO] [1726594796.504055413]: Plugin sys_status initialized
          [ INFO] [1726594796.504612906]: Plugin sys_time loaded
          [ INFO] [1726594796.508017864]: TM: Timesync mode: MAVLINK
          [ INFO] [1726594796.508257809]: TM: Not publishing sim time
          [ INFO] [1726594796.511214751]: Plugin sys_time initialized
          [ INFO] [1726594796.511329490]: Plugin terrain loaded
          [ INFO] [1726594796.511699329]: Plugin terrain initialized
          [ INFO] [1726594796.511778703]: Plugin trajectory loaded
          [ INFO] [1726594796.515814330]: Plugin trajectory initialized
          [ INFO] [1726594796.516015682]: Plugin tunnel loaded
          [ INFO] [1726594796.518193207]: Plugin tunnel initialized
          [ INFO] [1726594796.518302685]: Plugin vfr_hud loaded
          [ INFO] [1726594796.518638514]: Plugin vfr_hud initialized
          [ INFO] [1726594796.518673565]: Plugin vibration blacklisted
          [ INFO] [1726594796.518738512]: Plugin vision_pose_estimate loaded
          [ INFO] [1726594796.522767890]: Plugin vision_pose_estimate initialized
          [ INFO] [1726594796.522845337]: Plugin vision_speed_estimate loaded
          [ INFO] [1726594796.527713297]: Plugin vision_speed_estimate initialized
          [ INFO] [1726594796.527866004]: Plugin waypoint loaded
          [ INFO] [1726594796.530877112]: Plugin waypoint initialized
          [ INFO] [1726594796.530930341]: Plugin wheel_odometry blacklisted
          [ INFO] [1726594796.531022006]: Plugin wind_estimation loaded
          [ INFO] [1726594796.533300989]: Plugin wind_estimation initialized
          [ INFO] [1726594796.533477028]: Built-in SIMD instructions: ARM NEON
          [ INFO] [1726594796.533580933]: Built-in MAVLink package version: 2022.12.30
          [ INFO] [1726594796.533718275]: Known MAVLink dialects: common ardupilotmega ASLUAV AVSSUAS all cubepilot development icarous matrixpilot paparazzi standard storm32 uAvionix ualberta
          [ INFO] [1726594796.533843221]: MAVROS started. MY ID 1.240, TARGET ID 1.1
          [ INFO] [1726594796.534121030]: udp0: Remote address: 127.0.0.1:48652
          [ INFO] [1726594796.537097921]: RC_CHANNELS message detected!
          [ INFO] [1726594796.537972285]: IMU: High resolution IMU detected!
          [ INFO] [1726594796.538613787]: IMU: Attitude quaternion IMU detected!
          [ WARN] [1726594796.539202009]: GP: No GPS fix
          [ INFO] [1726594797.117976826]: CON: Got HEARTBEAT, connected. FCU: PX4 Autopilot
          [ INFO] [1726594797.134853701]: RC_CHANNELS message detected!
          [ INFO] [1726594797.139449112]: IMU: High resolution IMU detected!
          [ INFO] [1726594797.177394945]: IMU: Attitude quaternion IMU detected!
          [ INFO] [1726594798.137137651]: GF: Using MISSION_ITEM_INT
          [ INFO] [1726594798.137605771]: RP: Using MISSION_ITEM_INT
          [ INFO] [1726594798.137778321]: WP: Using MISSION_ITEM_INT
          [ INFO] [1726594798.138168680]: VER: 1.1: Capabilities         0x000000000000ecff
          [ INFO] [1726594798.138370188]: VER: 1.1: Flight software:     010e0000 (636ffefcb102004d)
          [ INFO] [1726594798.138766017]: VER: 1.1: Middleware software: 010e0000 (636ffefcb1000000)
          [ INFO] [1726594798.138908619]: VER: 1.1: OS software:         04137dff (3f77354c0dc88793)
          [ INFO] [1726594798.139093200]: VER: 1.1: Board hardware:      00000001
          [ INFO] [1726594798.139228511]: VER: 1.1: VID/PID:             0000:0000
          [ INFO] [1726594798.139464446]: VER: 1.1: UID:                 5649414c324c584f
          [ WARN] [1726594798.139942200]: CMD: Unexpected command 520, result 0
          [ INFO] [1726594801.249404137]: waiting for offboard mode
          [ INFO] [1726594807.120839499]: HP: requesting home position
          [ INFO] [1726594809.199350808]: arming
          **[ INFO] [1726594809.213191783]: Vehicle failed to arm**
          [mavros_test_node-3] process has finished cleanly
          log file: /home/root/.ros/log/d9e22bd2-751b-11ef-bd2d-00c0cab5abe5/mavros_test_node-3*.log
          [ INFO] [1726594812.119727325]: GF: mission received
          [ INFO] [1726594812.123151814]: RP: mission received
          [ INFO] [1726594812.123413165]: WP: mission received
          The only way that I can arm the drone is when I am using RC (I put it on "manual" mode, and then use the QGC bar to arb the drone! Check the attached photo!Screenshot from 2024-09-17 19-44-43.jpg
            @brahim
            header:
              seq: 72
              stamp:
                secs: 1726594638
                nsecs: 117869663
              frame_id: ''
            connected: True
            armed: False
            guided: False
            manual_input: False
            mode: "OFFBOARD"
            system_status: 3
            header:
              seq: 73
              stamp:
                secs: 1726594639
                nsecs: 117602864
              frame_id: ''
            connected: True
            armed: False
            guided: False
            manual_input: True
            mode: "MANUAL"
            system_status: 3
            SUMMARY
            CLEAR PARAMETERS
             * /mavros/
            PARAMETERS
             * /mavros/gcs_url:
            NODES
            B Offline
            B Offline
            brahim
            @Captain-7th Are you able to arm and fly in position mode? According to the mavros state you are connected and the printout shows that the arming command is sent to the vehicle while in offboard, but it is possible there is a preflight check that is failing?
            • B brahim
              Captain 7th
              @brahim
              Yes, while I am in manual mode, I can arm and disarm the drone with using ROS command using mavros services. But, when I switch back to offboard mode, I get a message that arming/disarming failed!
              The process for arming/disarming is like this:
              1. With the transmitter, I change the mode to the manual.
              2. launch the roscore
              3. launch px4 and mavros: roslaunch mavros px4.launch fcu_url:=udp://127.0.0.1:14551@127.0.0.1:14551
              4. run this script :
              #!/usr/bin/env python
              import rospy
              from geometry_msgs.msg import TwistStamped
              from mavros_msgs.srv import CommandBool, SetMode
              def move_drone():
                  rospy.init_node('move_drone', anonymous=True)
                  # Service proxies for arming and setting the mode
                  rospy.wait_for_service('/mavros/cmd/arming')
                  rospy.wait_for_service('/mavros/set_mode')
                  try:
                      arm_service = rospy.ServiceProxy('/mavros/cmd/arming', CommandBool)
                      set_mode_service = rospy.ServiceProxy('/mavros/set_mode', SetMode)
                  except rospy.ServiceException as e:
                      rospy.logerr("Service proxy failed: %s" % e)
                      return
                  # Arm the drone
                  arm_request = arm_service(True)
                  if arm_request.success:
                      rospy.loginfo("Drone armed successfully")
                  else:
                      rospy.logerr("Failed to arm the drone")
                      return
                  # Set to OFFBOARD mode
                  set_mode_request = set_mode_service(custom_mode='OFFBOARD')
                  if set_mode_request.mode_sent:
                      rospy.loginfo("OFFBOARD mode set")
                  else:
                      rospy.logerr("Failed to set OFFBOARD mode")
                      return
                  # Publisher for velocity commands
                  vel_pub = rospy.Publisher('/mavros/setpoint_velocity/cmd_vel', TwistStamped, queue_size=10)
                  rate = rospy.Rate(10)  # 10 Hz
                  # Prepare the velocity message
                  vel_msg = TwistStamped()
                  vel_msg.twist.linear.x = 0
                  vel_msg.twist.linear.y = 0
                  # Move up for 5 seconds
                  rospy.loginfo("Moving up")
                  vel_msg.twist.linear.z = 1.0  # Positive Z is upwards
                  for i in range(100):
                      vel_msg.header.stamp = rospy.Time.now()
                      vel_pub.publish(vel_msg)
                      rate.sleep()
                  # Hover for 2 seconds
                  rospy.loginfo("Hovering")
                  vel_msg.twist.linear.z = 0.0
                      rate.sleep()
                  # Move down for 5 seconds
                  rospy.loginfo("Moving down")
                  vel_msg.twist.linear.z = -1.0  # Negative Z is downwards
                      rate.sleep()
                  # Land the drone
                  rospy.loginfo("Landing")
                  set_mode_service(custom_mode='AUTO.LAND')
              if __name__ == '__main__':
                  try:
                      move_drone()
                  except rospy.ROSInterruptException:
                      pass
              The drone start arming and motors are working, but the drone does not goes up! I am installed the propellers properly and have been already double checked!
              • B Offline
                B Offline
                brahim
                Manual mode is not really representative of the ability to switch into offboard mode and send setpoints. You will need to be able to arm in position or hold mode first. If you do not have an rc controller then try to arm in hold mode. If you are not able to arm in either mode, then there is a preflight check fail somewhere that needs to be addressed first.
