    Intergrating VL53L1x Range Finder with VOXL2
    6760
    • Jetson NanoJ
      Jetson Nano
      I'm using a VL53L1x rangefinder for reducing drift accumulated during VIO on a Starling system. I'm using the sensor VL53L1X, which I'm connecting to VOXL2 through J19 port where I2C communication lanes (Pins 7,8) are available.
      When I enable range finder parameters in QGC, I'm not getting any data from the rangefinder in mavlink inspector or mavlink console. As mentioned in ModalAI documentation, this sensor is directly compatable with VOXL2. Is there any specific functional parameter which is to be enabled in PX4 config seperately?
      James StrawsonJ 1 Reply Last reply Reply Quote 0
      • modaltbM
        modaltb ModalAI Team
        Hi @Jetson-Nano our implementation is used on the applications processor (not the DSP) so you would want to use this reference:
        https://gitlab.com/voxl-public/voxl-sdk/services/qrb5165-rangefinder-server/-/tree/master
        • James StrawsonJ
          James Strawson ModalAI Team @Jetson Nano
          Hi @Jetson-Nano
          The I2C port on J19 is connected to the Sensors DSP and therefore can't be accessed from the main applications processor.
          Here is a new documentation page describing how to hook up and use these sensors.
          https://docs.modalai.com/rangefinders/
          • Jetson NanoJ
            Jetson Nano
            Thank you @modaltb @James-Strawson,
            Will check and get back. Apart from VL53L1x what are the other Rangefinder sensors which are compatible with VOXL2?
            Jetson NanoJ 1 Reply Last reply Reply Quote 0
            • Jetson NanoJ
              Jetson Nano @Jetson Nano
              @James-Strawson @modaltb , I checked with reference to the documentation you shared, but still it was not working.
              I used the M0141 USB2 Breakout Board with the VL53L1X Rangefinder, and ran the commands that was there in the documentation.
              voxl-configure-rangefinders 1_downward_on_m0141
              And I got the similar output for the following commands
              voxl2:/$ voxl-configure-rangefinders 1_downward_on_m0141
              creating new config file for 1 downward TOF without multiplexer
              DONE
              enabling  voxl-rangefinder-server systemd service
              Done configuring voxl-rangefinder-server
              voxl2:/$ cat /etc/modalai/voxl-rangefinder-server.conf
               * Rangefinder Configuration File
               * This file is used by voxl-rangefinder-server
               * please use voxl-rangefinder-server --config {arrangement}
               * to set up this file.
               * FOV for VL53l1X TOF rangefinder is a diagonal FOV in degrees and
               * can be set between 15 and 27 degrees.
               * vl53l1x_timing_budget_ms MUST be one of 20, 33, 50, 100, 200, 500
               * 100 is default
               * vl53l1x FOV options are 15, 20, and 27 degrees
               * default is 27
               * set id_for_mavlink to a valid id (0+) to publish that sensor reading to
               * mavlink as a DOWNWARD sensor for the autopilot to use
               * set to -1 to disable this feature.
              	"i2c_bus":	1,
              	"vl53l1x_timing_budget_ms":	50,
              	"id_for_mavlink":	0,
              	"sensors":	[{
              			"enabled":	true,
              			"sensor_id":	0,
              			"type":	"TOF_VL53L1X",
              			"fov_deg":	15,
              			"range_max_m":	3,
              			"location_wrt_body":	[-0.02500000037252903, 0.019999999552965164, 0.00800000037997961],
              			"direction_wrt_body":	[0, 0, 1],
              			"is_on_mux":	false,
              			"i2c_mux_address":	112,
              			"i2c_mux_port":	0
              But the rangefinder server in not running, even after starting the server. It is enabled but not running.
              Screenshot from 2024-07-05 11-38-52.png Screenshot from 2024-07-05 11-39-05.png
              • modaltbM
                Can you detect the sensor on the I2C bus, e.g https://docs.modalai.com/voxl2-linux-user-guide/#i2cdetect-usage ?
                • Jetson NanoJ
                  Jetson Nano @modaltb
                  @modaltb It is not detecting any sensors, I check the sensor with another FC with PX4 which support VL53L1X and it was detected there.
                  • modaltbM
                    what about with
                    i2cdetect -r -y 1
                    • Jetson NanoJ
                      @modaltb I tried detecting in all i2c bus, 0 to 5, it wasn't detected, I got three devices in 4, but it was UU and I think it is the cameras.
                      • Jetson NanoJ
                        @modaltb
                        • modaltbM
                          Hi @Jetson-Nano
                          OK we'd expect something on the bus like this:
                          Can you describe your wiring setup?
                          • Jetson NanoJ
                            Jetson Nano
                            This is the wiring diagram of the sensor with the USB Expansion Board.
                            • Jetson NanoJ
                              @modaltb Is there any specific SDK we could check for the working of Range-Finder with?
                              modaltbM 1 Reply Last reply Reply Quote 0
                              • modaltbM
                                modaltb ModalAI Team @Jetson Nano
                                @Jetson-Nano are you using our M0070 board like this? https://docs.modalai.com/rangefinders/#single-rangefinder-using-m0141-expansion-board
                                Or custom? If custom check pin 5, which on our M0070 board is pulled up to 3.3VDC.
                                • Jetson NanoJ
                                  @modaltb I'm using M0141 expansion board.
                                  • modaltbM
                                    @Jetson-Nano what is the VL53L1X on?
                                    • Jetson NanoJ
                                      @modaltb is connected on J5 port of M0141.
                                      • modaltbM
                                        @Jetson-Nano can you take a picture? for example, we make a M0070 board that has this sensor on it. Are you making your own carrier board for the sensor?
                                        • Jetson NanoJ
                                          @modaltb This is our setup,
                                          • VinnyV
                                            Vinny ModalAI Team @Jetson Nano
                                            HI @Jetson-Nano
                                            We have not seen that module before.
                                            Is there a product link you can share so we can investigate for voltage and signal compatibility?
