  3. voxl-mapper setting
voxl-mapper setting
starling
1 Posts 1 Posters 480 Views
  • Stefano AccollaS Offline
    Stefano Accolla
    Good morning,
    I'm trying to use voxl-mapper with a starling 2. When I use it with waypoints in larger rooms it works correctly, while if I use it in hallways or to go through doorways the drone doesn't follow the correct path and slams into walls.
    In some situations the drone goes to the opposite side from the placed waypoint.
    This is the result of "cat etc/modalai/extrinsics.conf"
    This is the result of "voxl-inspect-extrinsics"
    #0:
    parent: imu_apps
    child: tracking_front
    T_child_wrt_parent: 0.037 0.000 0.001
    RPY_parent_to_child: 0.0 90.0 90.0
    R_child_to_parent: 0.000 -0.000 1.000
    1.000 0.000 -0.000
    -0.000 1.000 0.000
    #1:
    parent: imu_apps
    child: tracking_down
    T_child_wrt_parent: -0.088 -0.004 0.003
    RPY_parent_to_child: 0.0 0.0 180.0
    R_child_to_parent: -1.000 -0.000 0.000
    0.000 -1.000 -0.000
    0.000 0.000 1.000
    #2:
    parent: imu_apps
    child: tracking_rear
    T_child_wrt_parent: -0.092 0.016 0.004
    RPY_parent_to_child: 0.0 -90.0 -90.0
    R_child_to_parent: 0.000 0.000 -1.000
    -1.000 0.000 -0.000
    0.000 1.000 0.000
    #3:
    parent: body
    child: imu_apps
    T_child_wrt_parent: 0.029 -0.006 -0.016
    RPY_parent_to_child: 0.0 0.0 0.0
    R_child_to_parent: 1.000 -0.000 0.000
    0.000 1.000 -0.000
    0.000 0.000 1.000
    #4:
    parent: body
    child: imu_px4
    T_child_wrt_parent: 0.004 0.007 -0.016
    0.000 1.000 -0.000
    0.000 0.000 1.000
    #5:
    parent: imu_apps
    child: lepton0_raw
    T_child_wrt_parent: -0.085 0.013 0.024
    RPY_parent_to_child: 0.0 0.0 90.0
    R_child_to_parent: 0.000 -1.000 0.000
    1.000 0.000 -0.000
    0.000 0.000 1.000
    #6:
    parent: body
    child: tof
    T_child_wrt_parent: 0.068 -0.012 -0.017
    RPY_parent_to_child: 0.0 90.0 180.0
    R_child_to_parent: -0.000 -0.000 1.000
    0.000 -1.000 -0.000
    1.000 0.000 0.000
    #7:
    parent: body
    child: ground
    T_child_wrt_parent: 0.000 0.000 0.033
    0.000 1.000 -0.000
    0.000 0.000 1.000
    This is the result of "cat /etc/modalai/voxl-mapper.conf"
    While this is the result of "ls /run/mpa/"
    Maybe there is an error in the sensors used in the mapper configuration? Maybe I need to enter the tracking cams?
    Could you help me solve the problem?
    Thank you!
