  3. Camera server keep crashing everytime it is launched
px4-dev-kit
25 Posts 4 Posters 9.0k Views 2 Watching
    @Judoor-0 , the tof sensor takes multiple exposures and returns stacked IR image (kind of like HDR). That image is processed by the TOF library on the cpu to output the final image at the proper resolution.
    I will check about RMA, you probably need to fill out the form: https://www.modalai.com/pages/rma
    Judoor 0
    @Alex-Kushleyev Ok, I filled up the RMA form in cas it's needed.
    My S/N is M23000001E9.
    Julien
    • J Judoor 0
      Julien
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      @Judoor-0 I'm facing a similar problem with ToF configuration on a Starling setup. Through RMA was anything wrt. to hardware found? If not how did RMA help you?
      • Jetson NanoJ Jetson Nano
        @Jetson-Nano , if you run the camera server in foreground (and with -d 0 option to enable debugging), it could help localize the issue. Also try disabling cameras one by one in voxl-camera-server.conf to find which camera is causing an issue.
        Is the issue you are seeing specific to TOF? Was it previously working?
          Jetson Nano
          Veteran
          #24
          @Alex-Kushleyev I tried that and have posted the output here (https://forum.modalai.com/topic/3688/vision-sensors-not-detected-in-voxl2). Initially the issue was with all the cameras, now it is only ToF.
            @Jetson-Nano , OK it seems we have two parallel threads going. please see my reply to the other thread https://forum.modalai.com/topic/3688/vision-sensors-not-detected-in-voxl2 and test it step by step as I suggested (reducing fps of imx214 camera first, then disabling sensors one by one)
