  3. Strange Turbulent Flight Behavior when transitioning into Offboard Mode (Please Help!!)
3 Posts 2 Posters 802 Views
  • ggiacaloneG Offline
    ggiacaloneG Offline
    ggiacalone
    I am attempting to use my Sentinel drone with offboard control and I am running into some undesirable behaviors.
    Here is a video that shows the behavior: https://www.youtube.com/watch?v=NoKqImDZU4A
    This is the code I am running from my laptop while running the Mavros node on the Voxl 2.
    #! /usr/bin/env python
    import rospy
    from geometry_msgs.msg import PoseStamped
    from mavros_msgs.msg import State
    from mavros_msgs.srv import CommandBool, CommandBoolRequest, SetMode, SetModeRequest
    current_state = State()
    def state_cb(msg):
        global current_state
        current_state = msg
    if __name__ == "__main__":
        rospy.init_node("offb_node_py")
        state_sub = rospy.Subscriber("mavros/state", State, callback = state_cb)
        local_pos_pub = rospy.Publisher("mavros/setpoint_position/local", PoseStamped, queue_size=10)
        rospy.wait_for_service("/mavros/cmd/arming")
        arming_client = rospy.ServiceProxy("mavros/cmd/arming", CommandBool)
        rospy.wait_for_service("/mavros/set_mode")
        set_mode_client = rospy.ServiceProxy("mavros/set_mode", SetMode)
        # Setpoint publishing MUST be faster than 2Hz
        rate = rospy.Rate(20)
        # Wait for Flight Controller connection
        while(not rospy.is_shutdown() and not current_state.connected):
            rate.sleep()
        initial_pose = PoseStamped()
        initial_pose.pose.position.x = 0
        initial_pose.pose.position.y = 0
        initial_pose.pose.position.z = 1.3
        initial_pose.pose.orientation.x = 0.0
        initial_pose.pose.orientation.y = 0.0
        initial_pose.pose.orientation.z = -0.7071
        initial_pose.pose.orientation.w = -0.7071
        land_pose = PoseStamped()
        land_pose.pose.position.x = 0
        land_pose.pose.position.y = 0
        land_pose.pose.position.z = 0
        land_pose.pose.orientation.x = 0.0
        land_pose.pose.orientation.y = 0.0
        land_pose.pose.orientation.z = -0.7071
        land_pose.pose.orientation.w = -0.7071
        flight_over = False
        # Variable to hold control timing for simple hop test
        # TODO replace with better controll later
        control_time_start = None
        # Send a few setpoints before starting
        for i in range(100):
            if(rospy.is_shutdown()):
                break
            local_pos_pub.publish(initial_pose)
            rate.sleep()
        offb_set_mode = SetModeRequest()
        offb_set_mode.custom_mode = 'OFFBOARD'
        arm_cmd = CommandBoolRequest()
        arm_cmd.value = True
        disarm_cmd = CommandBoolRequest()
        disarm_cmd.value = False
        last_req = rospy.Time.now()
        while(not rospy.is_shutdown()):
            if control_time_start is None:
                control_time_start = rospy.Time.now()
            if(current_state.mode != "OFFBOARD" and (rospy.Time.now() - last_req) > rospy.Duration(5.0)):
                if(set_mode_client.call(offb_set_mode).mode_sent == True):
                    rospy.loginfo("OFFBOARD enabled")
            else:
                if(not current_state.armed and (rospy.Time.now() - last_req) > rospy.Duration(5.0) and not flight_over):
                    if(arming_client.call(arm_cmd).success == True):
                        rospy.loginfo("Vehicle armed")
            # Time Based Control for Hop Routine
            # TODO Make better later
            if (rospy.Time.now() - control_time_start) < rospy.Duration(15.0):
            elif (rospy.Time.now() - control_time_start) < rospy.Duration(15.5):
                local_pos_pub.publish(land_pose)
            else:
                # Disarm the drone
                if(current_state.armed and (rospy.Time.now() - last_req) > rospy.Duration(5.0)):
                    if(arming_client.call(disarm_cmd).success == True):
                        rospy.loginfo("Vehicle Disarmed")
                    flight_over = True
            rate.sleep()
    I am using this mavros code to control it to go to a predefined setpoint. Unfortunately, on the first flight of every power cycle, it has a little bit of turbulence and it bounces up and down and shakes in the air a little bit before quickly and accurately moving to the desired setpoint I commanded it to go to. If the flight finishes and I run the code on my computer again to rerun the flight, it executes perfectly with no oscillations or other issues. It almost looks like the drone is fighting with itself until it makes it's mind up about where it needs to go.
    I also noticed that every time the drone powercycles, it thinks that its initial /mavros/local_position_pose has an orientation of approximately
    hence why I ensure to include this point in my setpoint pose. Although, QVIO shows the correct "zeroed" pose.
    Again, everytime I re run the code without turning the drone off and powering on again, it goes straight to the setpoint without any turbulence or shaking (except for the first flight) which makes me believe it's not an issue with the code.
    Why might it be having this unexpected and unwelcomed behavior?
    system-image: 1.7.4-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Fri Feb 9 21:59:24 UTC 2024 4.19.125
    hw platform: M0054
    mach.var: 1.0
    voxl-suite: 1.1.3-1
    Service Name | Enabled | Running | CPU Usage
    docker-autorun | Disabled | Not Running |
    modallink-relink | Disabled | Not Running |
    voxl-camera-server | Enabled | Running | 78.6%
    voxl-cpu-monitor | Enabled | Running | 0.6%
    voxl-dfs-server | Enabled | Running | 23.5%
    voxl-feature-tracker | Disabled | Not Running |
    voxl-flow-server | Disabled | Not Running |
    voxl-imu-server | Enabled | Running | 5.7%
    voxl-lepton-server | Disabled | Not Running |
    voxl-mapper | Enabled | Running | 0.7%
    voxl-mavcam-manager | Enabled | Running | 0.0%
    voxl-mavlink-server | Enabled | Running | 3.4%
    voxl-modem | Disabled | Not Running |
    voxl-neopixel-manager | Disabled | Not Running |
    voxl-open-vins-server | Disabled | Not Running |
    voxl-portal | Enabled | Running | 0.2%
    voxl-px4-imu-server | Disabled | Not Running |
    voxl-px4 | Enabled | Running | 38.7%
    voxl-qvio-server | Enabled | Running | 15.4%
    voxl-rangefinder-server | Disabled | Not Running |
    voxl-remote-id | Disabled | Not Running |
    voxl-softap | Disabled | Not Running |
    voxl-static-ip | Disabled | Not Running |
    voxl-streamer | Enabled | Running | 0.0%
    voxl-tag-detector | Disabled | Not Running |
    voxl-tflite-server | Disabled | Not Running |
    voxl-time-sync | Disabled | Not Running |
    voxl-uvc-server | Disabled | Not Running |
    voxl-vision-hub | Enabled | Running | 11.3%
    voxl-wait-for-fs | Enabled | Completed |
    • Dawid MościckiD Offline
      Dawid Mościcki
      In my case similar behavior was fixed by :
      "The thing that is most likely the issue I believe is voxl-vision-hub. There is a program in vision-hub that will automatically do a figure 8 in offboard when it gets kicked off programatically and this is most likely conflicting with your takeoff. The parameters you needs to disable in /etc/modalai/voxl-vision-hub.conf are:
      offboard_mode: off"
      ggiacaloneG 1 Reply Last reply
      • Dawid MościckiD Dawid Mościcki
        offboard_mode: off"
        ggiacaloneG Offline
        ggiacaloneG Offline
        ggiacalone
        @Dawid-Mościcki Wow amazing I will give this a try very soon. Thank you so much!
