  3. Sentinel drone voxl qvio server high cpu usage
1 Posts 1 Posters 446 Views
  • Dawid MościckiD Offline
    Dawid Mościcki
    For some reason CPU load on qvio-server is very high.
    Output from voxl-inspect-services
    Service Name | Enabled | Running | CPU Usage
    docker-autorun | Disabled | Not Running |
    modallink-relink | Disabled | Not Running |
    voxl-camera-server | Enabled | Running | 71.0%
    voxl-cpu-monitor | Enabled | Running | 0.6%
    voxl-dfs-server | Disabled | Not Running |
    voxl-feature-tracker | Disabled | Not Running |
    voxl-flow-server | Disabled | Not Running |
    voxl-imu-server | Enabled | Running | 5.4%
    voxl-lepton-server | Disabled | Not Running |
    voxl-mavcam-manager | Enabled | Running | 0.0%
    voxl-mavlink-server | Enabled | Running | 3.5%
    voxl-modem | Disabled | Not Running |
    voxl-neopixel-manager | Disabled | Not Running |
    voxl-open-vins-server | Disabled | Not Running |
    voxl-portal | Enabled | Running | 0.2%
    voxl-px4-imu-server | Disabled | Not Running |for some reason CPU load on qvio-server is very high. We also have problem with Alfa wifi modem - every few minutes it's turning off and restarting ... Led isnt blinking for few seconds then network start working again . While this is happening Qgroundcontrol is crashing (as every time when drone is reconnected)
    voxl-px4 | Enabled | Running | 57.1%
    voxl-qvio-server | Enabled | Not Running |
    voxl-rangefinder-server | Disabled | Not Running |
    voxl-remote-id | Disabled | Not Running |
    voxl-softap | Enabled | Completed |
    voxl-static-ip | Disabled | Not Running |
    voxl-streamer | Enabled | Running | 0.0%
    voxl-tag-detector | Disabled | Not Running |
    voxl-tflite-server | Disabled | Not Running |
    voxl-time-sync | Disabled | Not Running |
    voxl-uvc-server | Disabled | Not Running |
    voxl-vision-hub | Enabled | Running | 1.9%
    voxl-wait-for-fs | Enabled | Completed |
    What can I do in order to debug this issue further ? This wasn't an issue until last week (normally it ran at much lower cpu % usage).
