  3. Motor issues when running ESC calibration
esc
108 Posts 3 Posters 70.4k Views 1 Watching
  • rdjarvisR rdjarvis
    @Alex-Kushleyev
    From the GCS, executed "take-off" command in "Position Mode" with props off. Motors smoothly increase. I "hand-flew" it up to 1m and UAV was adjusting for small movements correctly.
    Executed "Land" and "hand-flew" it to the deck, landing detected and disarmed.
    @rdjarvis , interesting. Can you please share a px4 log from that position mode test?
    rdjarvisR 1 Reply Last reply
      rdjarvisR Offline
      rdjarvisR Offline
      rdjarvis
      @Alex-Kushleyev
      https://review.px4.io/plot_app?log=f154b563-aa6e-4ff8-b603-67b9b6e2e64c
        @Alex-Kushleyev
        @rdjarvis , yes in this mode, the vehicle seems to be responding to thrust commands and motors are tracking rpm well (even though without props)
          rdjarvisR Offline
          rdjarvisR Offline
          rdjarvis
          @Alex-Kushleyev I agree, what do you think the next troubleshooting step is for this issue?
            #105
            @rdjarvis ,
            Also another observation.. remember in manual flight, it seemed like instead of responding to the throttle stick, the actuator outputs were going up slowly in a ramp -- i just double check that seems to be a response to small rill/pitch deviations that happened, so it seems that the thrust stick is COMPLETELY ignored, which is what you have suggested.
            Now, the position mode goes through the same control pipeline except the hight is controlled using a high controller, as opposed to your radio. However, the commands are still going through the mixer that converts and thrust, roll, pitch, yaw commands to motor outputs , so that seems to be working correctly.
            Based on that, it seems the issue is somewhere between the Actuator controls and motor outputs, which is the mixer, right? Actuator controls data shows the desired thrust (up) goes up, but motor output does not reflect this. Maybe we can look at the px4 source code for the mixer which maps the actuator controls to motor outputs.
            I just noticed that you have parameters CA_ROTORx_AZ (for x =0,1,2,3) set to 1, but default is -1, which would mean that you are saying that thrust from this motor goes up, not down?
              @rdjarvis ,
              rdjarvisR Offline
              rdjarvisR Offline
              rdjarvis
              @Alex-Kushleyev Thanks Alex, We will test it out. In the meantime my team will be sending the first FPV 4n1 ESC back, so you can investigate onsite.
              Thank you,
              RDJ
                Thank you,
                RDJ
                @rdjarvis , please let me know the RMA number once you send back the M0138 ESC. Thanks!
                  @rdjarvis , I received the M0138 ESC that you sent back (reported that you were unable to communicate with the ESC).
                  The issue was that the baud rate in ESC params was set to 2.5Mbit instead of 250K by accident, so our auto-scan in ESC tools could not detect the ESC (and VOXL2 DSP does not support 2.5Mbit).
                  We will fix this in future ESC firmware to prevent accidental setting of unsupported baud rates. Sorry about that.
