  3. VOXL mpa_to_ros1 cmake prefix path
3 Posts 2 Posters 692 Views 1 Watching
  • Darshit DesaiD Offline
    Darshit Desai
    What paths should be there in CMAKE_PREFIX_PATH variable to make sure it points to voxl_mpa_to_ros1, Right now it is pointing to the ROS2 version of mpatoros.
    voxl2:~/catkin_ws$ catkin_make
    Base path: /home/root/catkin_ws
    Source space: /home/root/catkin_ws/src
    Build space: /home/root/catkin_ws/build
    Devel space: /home/root/catkin_ws/devel
    Install space: /home/root/catkin_ws/install
    #### Running command: "cmake /home/root/catkin_ws/src -DCATKIN_DEVEL_PREFIX=/home/root/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/root/catkin_ws/install -G Unix Makefiles" in "/home/root/catkin_ws/build"
    -- Using CATKIN_DEVEL_PREFIX: /home/root/catkin_ws/devel
    -- Using CMAKE_PREFIX_PATH: /opt/ros/melodic;/opt/ros/foxy/mpa_to_ros2/install/voxl_mpa_to_ros2;/opt/ros/foxy/mpa_to_ros2/install/voxl_msgs;/opt/ros/foxy/mpa_to_ros2/install/px4_ros_com;/opt/ros/foxy/mpa_to_ros2/install/px4_msgs;/opt/ros/foxy/mpa_to_ros2/install/image_common;/opt/ros/foxy/mpa_to_ros2/install/image_transport;/opt/ros/foxy/mpa_to_ros2/install/camera_info_manager;/opt/ros/foxy/mpa_to_ros2/install/camera_calibration_parsers;/opt/ros/foxy
    -- This workspace overlays: /opt/ros/melodic
    -- Using PYTHON_EXECUTABLE: /usr/bin/python2
    -- Using Debian Python package layout
    -- Using empy: /usr/bin/empy
    -- Using CATKIN_ENABLE_TESTING: ON
    -- Call enable_testing()
    -- Using CATKIN_TEST_RESULTS_DIR: /home/root/catkin_ws/build/test_results
    -- Forcing gtest/gmock from source, though one was otherwise available.
    -- Found gtest sources under '/usr/src/googletest': gtests will be built
    -- Found gmock sources under '/usr/src/googletest': gmock will be built
    -- Found PythonInterp: /usr/bin/python2 (found version "2.7.17")
    -- Using Python nosetests: /usr/bin/nosetests-2.7
    -- catkin 0.7.29
    -- BUILD_SHARED_LIBS is on
    -- ~~  traversing 4 packages in topological order:
    -- ~~  - kalman_filter_ros
    -- ~~  - tflite_prop_detection
    -- ~~  - your_pointcloud_package
    -- ~~  - your_tf_package
    -- +++ processing catkin package: 'kalman_filter_ros'
    -- ==> add_subdirectory(kalman_filter_ros)
    -- +++ processing catkin package: 'tflite_prop_detection'
    -- ==> add_subdirectory(tflite_prop_detection)
    -- Found camera_info_manager: 2.4.0 (/opt/ros/foxy/mpa_to_ros2/install/camera_info_manager/share/camera_info_manager/cmake)
    -- Found PythonInterp: /usr/bin/python2 (found suitable version "2.7.17", minimum required is "2")
      File "/opt/ros/foxy/share/ament_cmake_core/cmake/package_templates/templates_2_cmake.py", line 21, in <module>
        from ament_package.templates import get_environment_hook_template_path
      File "/opt/ros/foxy/lib/python3.6/site-packages/ament_package/templates.py", line 43
        def get_prefix_level_template_names(*, all_platforms=False):
    SyntaxError: invalid syntax
    CMake Error at /opt/ros/foxy/share/ament_cmake_core/cmake/ament_cmake_package_templates-extras.cmake:41 (message):
      execute_process(/usr/bin/python2
      /home/root/catkin_ws/build/tflite_prop_detection/ament_cmake_package_templates/templates.cmake)
      returned error code 1
      /opt/ros/foxy/share/ament_cmake_core/cmake/ament_cmake_coreConfig.cmake:41 (include)
      /opt/ros/foxy/mpa_to_ros2/install/camera_info_manager/share/camera_info_manager/cmake/ament_cmake_export_include_directories-extras.cmake:8 (find_package)
      /opt/ros/foxy/mpa_to_ros2/install/camera_info_manager/share/camera_info_manager/cmake/camera_info_managerConfig.cmake:41 (include)
      /opt/ros/melodic/share/voxl_mpa_to_ros/cmake/voxl_mpa_to_rosConfig.cmake:197 (find_package)
      /opt/ros/melodic/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
      tflite_prop_detection/CMakeLists.txt:8 (find_package)
    -- Configuring incomplete, errors occurred!
    See also "/home/root/catkin_ws/build/CMakeFiles/CMakeOutput.log".
    See also "/home/root/catkin_ws/build/CMakeFiles/CMakeError.log".
    Invoking "cmake" failed
    ModeratorM 1 Reply Last reply
      -- catkin 0.7.29
      @Darshit-Desai The CI runs nightly and is passing. Can you use the build scripts from the CI?
      Darshit DesaiD 1 Reply Last reply
      • ModeratorM Moderator
        Darshit Desai
        @Moderator I had to explicitly change the system variable CMAKE_PREFIX_PATH every time to /opt/ros/melodic only to build the nodes. Building a new voxl package might break things and I don't want to do that.
