  3. Are SELECT_TF_OPS supported on VOXL2?
tflitetflite-servervoxl2
2 Posts 2 Posters 1.5k Views 1 Watching
  • E Offline
    E Offline
    eric
    I'm converting a custom keras model to tflite. Unfortunately, this model requires GatherND, which is not included in the built-in TF lite OPS.
    If I add SELECT_TF_OPS to the supported ops list, then my custom TFlite model builds locally:
    converter.target_spec.supported_ops = [
        tf.lite.OpsSet.TFLITE_BUILTINS,
        tf.lite.OpsSet.SELECT_TF_OPS
    Will this model (with the SELECT_TF_OPS flag) work with tflite server for VOXL2, or can I only use the built-in tflite ops?
    ? 1 Reply Last reply
    • E eric
      @eric
      Sorry for the late response on this!!
      Your best bet would be to just try it out, I can't say without trying it myself. It's possible it works, it's possible something fails. I've never had to deal with this so I can't say for certain.
      It's also worth pointing out that voxl-tflite-server is more meant to be an example of how TFLite models can be run on VOXL and not an in-depth ML framework for deploying custom models. If voxl-tflite-server doesn't support it, by all means fork the repository and build out the functionality to be able to. Even better, make a pull request with that functionality and I'll test and approve it!
      Hope this helps,
      Thomas Patton
