  2. VOXL SDK and Software
  3. voxl_mpa_to_ros2 error with libtinyxml2.so.6
ros
2 Posts 1 Posters 1.2k Views
  • Kyuhyong YouK Offline
    Kyuhyong You
    With sdk 1.1.0 up and running.
    apt installed ros-foxy and voxl_mpa_to_ros2 as well.
    as described in this document https://docs.modalai.com/ros2-installation-voxl2/
    When trying to start voxl_mpa_to_ros2_node I get following error.
    $ ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node
    /opt/ros/foxy/mpa_to_ros2/install/voxl_mpa_to_ros2/lib/voxl_mpa_to_ros2/voxl_mpa_to_ros2_node: error while loading shared libraries: libtinyxml2.so.6: cannot open shared object file: No such file or directory
    How to fix this error?
    Kyuhyong YouK 1 Reply Last reply
    • Kyuhyong YouK Kyuhyong You
      Kyuhyong You
      @Kyuhyong-You
      I found solution.
      This error was resolved by apt installing libtinyxml2 by
      sudo apt install libtinyxml2-dev
