  3. flashing VOXL2 errors
3 Posts 2 Posters 881 Views
  • W Offline
    W Offline
    Wei Cui
    Has anyone seen the following errors. I tried both sudo ./install.sh and sudo su then ./install.sh . Any advice would be greatly appreciated.
      File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory)
    Reading package lists... Done
    N: Download is performed unsandboxed as root as file '/data/voxl-suite-offline-packages/./InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
    E: Failed to fetch file:/data/voxl-suite-offline-packages/./Packages  File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory)
    E: Some index files failed to download. They have been ignored, or old ones used instead.
    [INFO] Installing packages on target
    Building dependency tree
    E: Unable to locate package voxl-suite
    [INFO] Pointing to correct repo
    /bin/bash: voxl-configure-pkg-manager: command not found
    [INFO] Done installing voxl-suite```
    W 1 Reply Last reply
    • W Wei Cui
      W Offline
      W Offline
      Wei Cui
      @Wei-Cui wiping the /data partition fixed the error.
      Hyunsoo Kim 0H 1 Reply Last reply
      • W Wei Cui
        Hyunsoo Kim 0H Offline
        Hyunsoo Kim 0
        @Wei-Cui
        How did you wipe the /data?
