Upgrade to SDK v1.0.0 causes crash of voxl-camera-server
Hi everyone,
I am trying to upgrade the sentinel drone to SDK 1.0.0, but the camera server crashes, what I noticed is that if I use only the front stereo (voxl-configure-cameras 3), everything works flawlessly but voxl-configure-cameras 11 introduces some weird error...
voxl-camera-server -d 0
GPS server Connected
DEBUG: stereo camera "stereo_front"with cam ids 0 & 1
DEBUG: Secondary id found for camera: stereo_front, assuming stereo
DEBUG: stereo camera "stereo_rear"with cam ids 5 & 4
DEBUG: Secondary id found for camera: stereo_rear, assuming stereoconfiguration for 4 cameras:
cam #0
sensor type: ov7251
isEnabled: 1
camId: 2
camId2: -1
fps: 30en_preview: 1 pre_width: 640 pre_height: 480 pre_format: raw8 en_small_video: 0 small_video_width: -1 small_video_height: -1 en_large_video: 0 large_video_width: -1 large_video_height: -1 en_snapshot: 0 snap_width: -1 snap_height: -1 ae_mode: lme_msv standby_enabled: 0 decimator: 1 independent_exposure:0cam #1
sensor type: imx214
isEnabled: 1
camId: 3
camId2: -1
fps: 30en_preview: 0 pre_width: 640 pre_height: 480 pre_format: nv21 en_small_video: 1 small_video_width: 1024 small_video_height: 768 en_large_video: 1 large_video_width: 4096 large_video_height: 2160 en_snapshot: 1 snap_width: 4160 snap_height: 3120 ae_mode: isp standby_enabled: 0 decimator: 1 independent_exposure:0cam #2
sensor type: ov7251
isEnabled: 1
camId: 0
camId2: 1
fps: 30en_preview: 1 pre_width: 640 pre_height: 480 pre_format: raw8 en_small_video: 0 small_video_width: -1 small_video_height: -1 en_large_video: 0 large_video_width: -1 large_video_height: -1 en_snapshot: 0 snap_width: -1 snap_height: -1 ae_mode: lme_msv standby_enabled: 0 decimator: 1 independent_exposure:0cam #3
sensor type: ov7251
isEnabled: 1
camId: 5
camId2: 4
fps: 30en_preview: 1 pre_width: 640 pre_height: 480 pre_format: raw8 en_small_video: 0 small_video_width: -1 small_video_height: -1 en_large_video: 0 large_video_width: -1 large_video_height: -1 en_snapshot: 0 snap_width: -1 snap_height: -1 ae_mode: lme_msv standby_enabled: 0 decimator: 1 independent_exposure:0=================================================================
DEBUG: ------ voxl-camera-server: Starting 4 cameras
Starting Camera: tracking
DEBUG: Attempting to open the hal module
DEBUG: SUCCESS: Camera module opened on attempt 0
DEBUG: ----------- Number of cameras: 5DEBUG: Cam idx: 0, Cam slot: 0, Slave Address: 0x00E2, Sensor Id: 0x7750
DEBUG: Cam idx: 1, Cam slot: 1, Slave Address: 0x00E4, Sensor Id: 0x7750
DEBUG: Cam idx: 2, Cam slot: 2, Slave Address: 0x00C0, Sensor Id: 0x7750
DEBUG: Cam idx: 3, Cam slot: 3, Slave Address: 0x0020, Sensor Id: 0x0214
DEBUG: Cam idx: 4, Cam slot: 5, Slave Address: 0x00E4, Sensor Id: 0x7750
VERBOSE: Successfully found configuration match for camera 2: 640x480
VERBOSE: Adding preview stream for camera: 2
DEBUG: ALIGNING HEIGHT FOR VGA
DEBUG: Allocating img Buffer: width: 640 stride: 640 height: 480 slice: 512 size: 491520
DEBUG: Successfully set up pipeline for stream: PREVIEW
VERBOSE: Entered thread: cam2-request(tid: 2477)
DEBUG: Started Camera: tracking
VERBOSE: Entered thread: cam2-result(tid: 2478)
VERBOSE: added request for preview stream
Starting Camera: hires
VERBOSE: Sending request for frame 0 for camera tracking for 1 streams
VERBOSE: Successfully found configuration match for camera 3: 1024x768
VERBOSE: Successfully found configuration match for camera 3: 4096x2160
VERBOSE: Successfully found configuration match for camera 3: 4160x3120
VERBOSE: Received result from HAl3 for frame number 0
VERBOSE: Received 0 buffers from camera tracking, partial result:1
VERBOSE: Adding small video stream for camera: 3
VERBOSE: Adding large video stream for camera: 3
VERBOSE: Adding snapshot stream for camera: 3
VERBOSE: finished sending request for frame 0 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera tracking
VERBOSE: Sending request for frame 1 for camera tracking for 1 streams
VERBOSE: finished sending request for frame 1 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera tracking
VERBOSE: Sending request for frame 2 for camera tracking for 1 streams
VERBOSE: finished sending request for frame 2 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera tracking
VERBOSE: Sending request for frame 3 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 1
VERBOSE: finished sending request for frame 3 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera tracking
VERBOSE: Sending request for frame 4 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 2
VERBOSE: finished sending request for frame 4 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera tracking
VERBOSE: Received result from HAl3 for frame number 3
VERBOSE: Sending request for frame 5 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 4
VERBOSE: Received 0 buffers from camera tracking, partial result:2
VERBOSE: Received metadata for frame 0 from camera tracking
VERBOSE: Timestamp: 57450525565
VERBOSE: Gain: 799
VERBOSE: Exposure: 5259763
VERBOSE: Received 1 buffers from camera tracking, partial result:0
VERBOSE: Received output buffer 0 from camera tracking
VERBOSE: tracking procesing new buffer
VERBOSE: Camera: tracking processing preview frame
VERBOSE: Preview format HAL_PIXEL_FORMAT_RAW10
VERBOSE: finished sending request for frame 5 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 6 for camera tracking
VERBOSE: Sending request for frame 6 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 5
VERBOSE: Received metadata for frame 1 from camera tracking
VERBOSE: Timestamp: 57517186659
VERBOSE: Gain: 799
VERBOSE: Received output buffer 1 from camera tracking
DEBUG: tracking received raw10 frame, checking to see if is actually raw8
DEBUG: Frame was actually 8 bit, sending as is
VERBOSE: finished sending request for frame 6 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 7 for camera tracking
VERBOSE: Sending request for frame 7 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 6
DEBUG: ALIGNING HEIGHT FOR LARGE IMAGE
DEBUG: Allocating img Buffer: width: 1024 stride: 1024 height: 768 slice: 1024 size: 1572864
VERBOSE: Received metadata for frame 2 from camera tracking
VERBOSE: Timestamp: 57550520773
VERBOSE: Gain: 799
DEBUG: Available color formats for OMX:
DEBUG: Unknown (0x7fa30c06)
DEBUG: OMX_QCOM_COLOR_FormatYUV420PackedSemiPlanar32m (0x7fa30c04)
DEBUG: OMX_QCOM_COLOR_FormatYVU420SemiPlanar (0x7fa30c00)
DEBUG: Unknown (0x7fa30c09)
DEBUG: Unknown (0x7fa30c0a)
DEBUG: Unknown (0x7fa30c08)
DEBUG: Unknown (0x7fa30c07)
DEBUG: OMX_COLOR_FormatAndroidOpaque (0x7f000789)
DEBUG: OMX_COLOR_FormatYUV420SemiPlanar (0x15)
DEBUG: Buffer Count Expected: 16
DEBUG: Buffer Count Actual: 16
WARNING: Port Def 0:
Count Min: 8
Count Actual: 16
Buffers Contiguous: Yes
Buffer Alignment: 0
WARNING: Port Def 1:
Count Min: 4
Count Actual: 16
Buffers Contiguous: No
Buffer Alignment: 0
DEBUG: OMX_EventCmdComplete
VERBOSE: Received output buffer 2 from camera tracking
VERBOSE: finished sending request for frame 7 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 8 for camera tracking
VERBOSE: Sending request for frame 8 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 7
DEBUG: Successfully set up pipeline for stream: STREAM_SMALL_VID
DEBUG: Allocating img Buffer: width: 4096 stride: 4096 height: 2160 slice: 2560 size: 15728640
Count Min: 8
Count Actual: 16
Buffer Alignment: 0
Count Min: 4
Count Actual: 16
Buffer Alignment: 0
VERBOSE: Received metadata for frame 3 from camera tracking
VERBOSE: Timestamp: 57583841919
VERBOSE: Gain: 799
DEBUG: Successfully set up pipeline for stream: STREAM_LARGE_VID
DEBUG: Allocating jpeg Buffer: size: 38937608
DEBUG: Successfully set up pipeline for stream: SNAPSHOT
VERBOSE: Received output buffer 3 from camera tracking
VERBOSE: finished sending request for frame 8 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 9 for camera tracking
VERBOSE: Sending request for frame 9 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 8
DEBUG: Started Camera: hires
Starting Camera: stereo_front
VERBOSE: Entered thread: cam3-result(tid: 2529)
VERBOSE: Entered thread: cam3-request(tid: 2528)
VERBOSE: Successfully found configuration match for camera 0: 640x480
VERBOSE: Adding preview stream for camera: 0
VERBOSE: Received metadata for frame 4 from camera tracking
VERBOSE: Timestamp: 57617170825
VERBOSE: Gain: 799
VERBOSE: Received output buffer 4 from camera tracking
VERBOSE: finished sending request for frame 9 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 10 for camera tracking
VERBOSE: Sending request for frame 10 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 9
VERBOSE: Received metadata for frame 5 from camera tracking
VERBOSE: Timestamp: 57650519628
VERBOSE: Gain: 799
VERBOSE: Received output buffer 5 from camera tracking
VERBOSE: finished sending request for frame 10 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 11 for camera tracking
VERBOSE: Sending request for frame 11 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 10
VERBOSE: Successfully found configuration match for camera 1: 640x480
VERBOSE: Adding preview stream for camera: 1
VERBOSE: Received metadata for frame 6 from camera tracking
VERBOSE: Timestamp: 57683977240
VERBOSE: Gain: 799
VERBOSE: Exposure: 5250171
VERBOSE: Received output buffer 6 from camera tracking
VERBOSE: finished sending request for frame 11 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 12 for camera tracking
VERBOSE: Sending request for frame 12 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 11
VERBOSE: Received metadata for frame 7 from camera tracking
VERBOSE: Timestamp: 57717157570
VERBOSE: Gain: 189
VERBOSE: Exposure: 5252133
VERBOSE: Received output buffer 7 from camera tracking
VERBOSE: finished sending request for frame 12 for camera tracking
VERBOSE: returning from SendOneCaptureRequest for frame 13 for camera tracking
VERBOSE: Sending request for frame 13 for camera tracking for 1 streams
VERBOSE: Received result from HAl3 for frame number 12
VERBOSE: Entered thread: cam0-request(tid: 2536)
VERBOSE: Entered thread: cam0-result(tid: 2537)
DEBUG: Started Camera: stereo_front
Starting Camera: stereo_rear
VERBOSE: Entered thread: cam1-result(tid: 2539)
VERBOSE: added request for preview streamSegmentation fault:
VERBOSE: Sending request for frame 0 for camera stereo_front for 1 streams
Fault thread: voxl-camera-ser(tid: 2459)
Segmentation faultAny idea why the Segmentation fault happens?
All the following files are in place
/usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_2.bin
/usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_0.bin
/usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_1.bin
/usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_3.bin
/usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_4.bin
/usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_5.bin -
Hi everyone,
cam #0
sensor type: ov7251
isEnabled: 1
camId: 2
camId2: -1
sensor type: imx214
isEnabled: 1
camId: 3
camId2: -1
sensor type: ov7251
isEnabled: 1
camId: 0
camId2: 1
sensor type: ov7251
isEnabled: 1
camId: 5
camId2: 4
VERBOSE: Gain: 799
VERBOSE: Gain: 799
VERBOSE: Gain: 799
Count Min: 8
Count Actual: 16
Buffer Alignment: 0
Count Min: 4
Count Actual: 16
Buffer Alignment: 0
Count Min: 8
Count Actual: 16
Buffer Alignment: 0
Count Min: 4
Count Actual: 16
Buffer Alignment: 0
VERBOSE: Gain: 799
VERBOSE: Gain: 799
VERBOSE: Gain: 799
VERBOSE: Gain: 799
VERBOSE: Gain: 189
@afdrus you can't arbitrarily pick camera configurations. Does your hardware setup support the config your trying to achieve?
