  3. Upgrade to SDK v1.0.0 causes crash of voxl-camera-server
sentinel
3 Posts 2 Posters 714 Views
  • A Offline
    afdrus
    Hi everyone,
    I am trying to upgrade the sentinel drone to SDK 1.0.0, but the camera server crashes, what I noticed is that if I use only the front stereo (voxl-configure-cameras 3), everything works flawlessly but voxl-configure-cameras 11 introduces some weird error...
    voxl-camera-server -d 0
    GPS server Connected
    DEBUG: stereo camera "stereo_front"with cam ids 0 & 1
    DEBUG: Secondary id found for camera: stereo_front, assuming stereo
    DEBUG: stereo camera "stereo_rear"with cam ids 5 & 4
    DEBUG: Secondary id found for camera: stereo_rear, assuming stereo
    configuration for 4 cameras:
    cam #0
    sensor type: ov7251
    isEnabled: 1
    camId: 2
    camId2: -1
    fps: 30
    en_preview:          1
    pre_width:           640
    pre_height:          480
    pre_format:          raw8
    en_small_video:      0
    small_video_width:   -1
    small_video_height:  -1
    en_large_video:      0
    large_video_width:   -1
    large_video_height:  -1
    en_snapshot:         0
    snap_width:          -1
    snap_height:         -1
    ae_mode:             lme_msv
    standby_enabled:     0
    decimator:           1
    independent_exposure:0
    cam #1
    sensor type: imx214
    isEnabled: 1
    camId: 3
    camId2: -1
    fps: 30
    en_preview:          0
    pre_width:           640
    pre_height:          480
    pre_format:          nv21
    en_small_video:      1
    small_video_width:   1024
    small_video_height:  768
    en_large_video:      1
    large_video_width:   4096
    large_video_height:  2160
    en_snapshot:         1
    snap_width:          4160
    snap_height:         3120
    ae_mode:             isp
    standby_enabled:     0
    decimator:           1
    cam #2
    sensor type: ov7251
    isEnabled: 1
    camId: 0
    camId2: 1
    fps: 30
    en_preview:          1
    pre_width:           640
    pre_height:          480
    pre_format:          raw8
    en_small_video:      0
    en_large_video:      0
    en_snapshot:         0
    snap_width:          -1
    snap_height:         -1
    ae_mode:             lme_msv
    standby_enabled:     0
    decimator:           1
    cam #3
    sensor type: ov7251
    isEnabled: 1
    camId: 5
    camId2: 4
    fps: 30
    en_preview:          1
    pre_width:           640
    pre_height:          480
    pre_format:          raw8
    en_small_video:      0
    en_large_video:      0
    en_snapshot:         0
    snap_width:          -1
    snap_height:         -1
    ae_mode:             lme_msv
    standby_enabled:     0
    decimator:           1
    DEBUG: ------ voxl-camera-server: Starting 4 cameras
    Starting Camera: tracking
    DEBUG: Attempting to open the hal module
    DEBUG: SUCCESS: Camera module opened on attempt 0
    DEBUG: ----------- Number of cameras: 5
    DEBUG: Cam idx: 0, Cam slot: 0, Slave Address: 0x00E2, Sensor Id: 0x7750
    DEBUG: Cam idx: 1, Cam slot: 1, Slave Address: 0x00E4, Sensor Id: 0x7750
    DEBUG: Cam idx: 2, Cam slot: 2, Slave Address: 0x00C0, Sensor Id: 0x7750
    DEBUG: Cam idx: 3, Cam slot: 3, Slave Address: 0x0020, Sensor Id: 0x0214
    DEBUG: Cam idx: 4, Cam slot: 5, Slave Address: 0x00E4, Sensor Id: 0x7750
    VERBOSE: Successfully found configuration match for camera 2: 640x480
    VERBOSE: Adding preview stream for camera: 2
    DEBUG: ALIGNING HEIGHT FOR VGA
    DEBUG: Allocating img Buffer: width: 640 stride: 640 height: 480 slice: 512 size: 491520
    DEBUG: Successfully set up pipeline for stream: PREVIEW
    VERBOSE: Entered thread: cam2-request(tid: 2477)
    DEBUG: Started Camera: tracking
    VERBOSE: Entered thread: cam2-result(tid: 2478)
    VERBOSE: added request for preview stream
    Starting Camera: hires
    VERBOSE: Sending request for frame 0 for camera tracking for 1 streams
    VERBOSE: Successfully found configuration match for camera 3: 1024x768
    VERBOSE: Successfully found configuration match for camera 3: 4096x2160
    VERBOSE: Successfully found configuration match for camera 3: 4160x3120
    VERBOSE: Received 0 buffers from camera tracking, partial result:1
    VERBOSE: Adding small video stream for camera: 3
    VERBOSE: Adding large video stream for camera: 3
    VERBOSE: Adding snapshot stream for camera: 3
    VERBOSE: finished sending request for frame 0 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera tracking
    VERBOSE: Sending request for frame 1 for camera tracking for 1 streams
    VERBOSE: finished sending request for frame 1 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera tracking
    VERBOSE: Sending request for frame 2 for camera tracking for 1 streams
    VERBOSE: finished sending request for frame 2 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera tracking
    VERBOSE: Sending request for frame 3 for camera tracking for 1 streams
    VERBOSE: finished sending request for frame 3 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera tracking
    VERBOSE: Sending request for frame 4 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 2
    VERBOSE: finished sending request for frame 4 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera tracking
    VERBOSE: Received result from HAl3 for frame number 3
    VERBOSE: Sending request for frame 5 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 4
    VERBOSE: Received 0 buffers from camera tracking, partial result:2
    VERBOSE: Received metadata for frame 0 from camera tracking
    VERBOSE: Timestamp: 57450525565
    VERBOSE: Gain: 799
    VERBOSE: Exposure: 5259763
    VERBOSE: Received 1 buffers from camera tracking, partial result:0
    VERBOSE: Received output buffer 0 from camera tracking
    VERBOSE: tracking procesing new buffer
    VERBOSE: Camera: tracking processing preview frame
    VERBOSE: Preview format HAL_PIXEL_FORMAT_RAW10
    VERBOSE: finished sending request for frame 5 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 6 for camera tracking
    VERBOSE: Sending request for frame 6 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 5
    VERBOSE: Received metadata for frame 1 from camera tracking
    VERBOSE: Timestamp: 57517186659
    VERBOSE: Gain: 799
    VERBOSE: Received output buffer 1 from camera tracking
    DEBUG: tracking received raw10 frame, checking to see if is actually raw8
    DEBUG: Frame was actually 8 bit, sending as is
    VERBOSE: finished sending request for frame 6 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 7 for camera tracking
    VERBOSE: Sending request for frame 7 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 6
    DEBUG: ALIGNING HEIGHT FOR LARGE IMAGE
    DEBUG: Allocating img Buffer: width: 1024 stride: 1024 height: 768 slice: 1024 size: 1572864
    VERBOSE: Received metadata for frame 2 from camera tracking
    VERBOSE: Timestamp: 57550520773
    VERBOSE: Gain: 799
    DEBUG: Available color formats for OMX:
    DEBUG: Unknown (0x7fa30c06)
    DEBUG: OMX_QCOM_COLOR_FormatYUV420PackedSemiPlanar32m (0x7fa30c04)
    DEBUG: OMX_QCOM_COLOR_FormatYVU420SemiPlanar (0x7fa30c00)
    DEBUG: Unknown (0x7fa30c09)
    DEBUG: Unknown (0x7fa30c0a)
    DEBUG: Unknown (0x7fa30c08)
    DEBUG: Unknown (0x7fa30c07)
    DEBUG: OMX_COLOR_FormatAndroidOpaque (0x7f000789)
    DEBUG: OMX_COLOR_FormatYUV420SemiPlanar (0x15)
    DEBUG: Buffer Count Expected: 16
    DEBUG: Buffer Count Actual: 16
    WARNING: Port Def 0:
    Count Min: 8
    Count Actual: 16
    Buffers Contiguous: Yes
    Buffer Alignment: 0
    WARNING: Port Def 1:
    Count Min: 4
    Count Actual: 16
    Buffers Contiguous: No
    Buffer Alignment: 0
    DEBUG: OMX_EventCmdComplete
    VERBOSE: Received output buffer 2 from camera tracking
    VERBOSE: finished sending request for frame 7 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 8 for camera tracking
    VERBOSE: Sending request for frame 8 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 7
    DEBUG: Successfully set up pipeline for stream: STREAM_SMALL_VID
    DEBUG: Allocating img Buffer: width: 4096 stride: 4096 height: 2160 slice: 2560 size: 15728640
    Count Min: 8
    Count Actual: 16
    Buffer Alignment: 0
    Count Min: 4
    Count Actual: 16
    Buffer Alignment: 0
    VERBOSE: Received metadata for frame 3 from camera tracking
    VERBOSE: Timestamp: 57583841919
    VERBOSE: Gain: 799
    DEBUG: Successfully set up pipeline for stream: STREAM_LARGE_VID
    DEBUG: Allocating jpeg Buffer: size: 38937608
    DEBUG: Successfully set up pipeline for stream: SNAPSHOT
    VERBOSE: Received output buffer 3 from camera tracking
    VERBOSE: finished sending request for frame 8 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 9 for camera tracking
    VERBOSE: Sending request for frame 9 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 8
    DEBUG: Started Camera: hires
    Starting Camera: stereo_front
    VERBOSE: Entered thread: cam3-result(tid: 2529)
    VERBOSE: Entered thread: cam3-request(tid: 2528)
    VERBOSE: Successfully found configuration match for camera 0: 640x480
    VERBOSE: Received metadata for frame 4 from camera tracking
    VERBOSE: Timestamp: 57617170825
    VERBOSE: Gain: 799
    VERBOSE: Received output buffer 4 from camera tracking
    VERBOSE: finished sending request for frame 9 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 10 for camera tracking
    VERBOSE: Sending request for frame 10 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 9
    VERBOSE: Received metadata for frame 5 from camera tracking
    VERBOSE: Timestamp: 57650519628
    VERBOSE: Gain: 799
    VERBOSE: Received output buffer 5 from camera tracking
    VERBOSE: finished sending request for frame 10 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 11 for camera tracking
    VERBOSE: Sending request for frame 11 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 10
    VERBOSE: Successfully found configuration match for camera 1: 640x480
    VERBOSE: Adding preview stream for camera: 1
    VERBOSE: Received metadata for frame 6 from camera tracking
    VERBOSE: Timestamp: 57683977240
    VERBOSE: Gain: 799
    VERBOSE: Exposure: 5250171
    VERBOSE: Received output buffer 6 from camera tracking
    VERBOSE: finished sending request for frame 11 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 12 for camera tracking
    VERBOSE: Sending request for frame 12 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 11
    VERBOSE: Received metadata for frame 7 from camera tracking
    VERBOSE: Timestamp: 57717157570
    VERBOSE: Gain: 189
    VERBOSE: Exposure: 5252133
    VERBOSE: Received output buffer 7 from camera tracking
    VERBOSE: finished sending request for frame 12 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 13 for camera tracking
    VERBOSE: Sending request for frame 13 for camera tracking for 1 streams
    VERBOSE: Received result from HAl3 for frame number 12
    VERBOSE: Entered thread: cam0-request(tid: 2536)
    VERBOSE: Entered thread: cam0-result(tid: 2537)
    DEBUG: Started Camera: stereo_front
    Starting Camera: stereo_rear
    VERBOSE: Entered thread: cam1-result(tid: 2539)
    Segmentation fault:
    VERBOSE: Sending request for frame 0 for camera stereo_front for 1 streams
    Fault thread: voxl-camera-ser(tid: 2459)
    Segmentation fault
    Any idea why the Segmentation fault happens?
    All the following files are in place
    /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_2.bin
    /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_0.bin
    /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_1.bin
    /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_3.bin
    /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_4.bin
    /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_5.bin
    ModeratorM 1 Reply Last reply
    • A afdrus
      Hi everyone,
      cam #0
      sensor type: ov7251
      isEnabled: 1
      camId: 2
      camId2: -1
      fps: 30
      en_preview:          1
      pre_width:           640
      pre_height:          480
      pre_format:          raw8
      en_small_video:      0
      en_large_video:      0
      en_snapshot:         0
      snap_width:          -1
      snap_height:         -1
      ae_mode:             lme_msv
      standby_enabled:     0
      decimator:           1
      cam #1
      sensor type: imx214
      isEnabled: 1
      camId: 3
      camId2: -1
      fps: 30
      en_preview:          0
      pre_width:           640
      pre_height:          480
      pre_format:          nv21
      en_small_video:      1
      en_large_video:      1
      en_snapshot:         1
      snap_width:          4160
      snap_height:         3120
      ae_mode:             isp
      standby_enabled:     0
      decimator:           1
      cam #2
      sensor type: ov7251
      isEnabled: 1
      camId: 0
      camId2: 1
      fps: 30
      en_preview:          1
      pre_width:           640
      pre_height:          480
      pre_format:          raw8
      en_small_video:      0
      en_large_video:      0
      en_snapshot:         0
      snap_width:          -1
      snap_height:         -1
      ae_mode:             lme_msv
      standby_enabled:     0
      decimator:           1
      cam #3
      sensor type: ov7251
      isEnabled: 1
      camId: 5
      camId2: 4
      fps: 30
      en_preview:          1
      pre_width:           640
      pre_height:          480
      pre_format:          raw8
      en_small_video:      0
      en_large_video:      0
      en_snapshot:         0
      snap_width:          -1
      snap_height:         -1
      ae_mode:             lme_msv
      standby_enabled:     0
      decimator:           1
      VERBOSE: Gain: 799
      VERBOSE: Gain: 799
      VERBOSE: Gain: 799
      Count Min: 8
      Count Actual: 16
      Buffer Alignment: 0
      Count Min: 4
      Count Actual: 16
      Buffer Alignment: 0
      Count Min: 8
      Count Actual: 16
      Buffer Alignment: 0
      Count Min: 4
      Count Actual: 16
      Buffer Alignment: 0
      VERBOSE: Gain: 799
      VERBOSE: Gain: 799
      VERBOSE: Gain: 799
      VERBOSE: Gain: 799
      VERBOSE: Gain: 189
      Segmentation fault:
      Segmentation fault
      @afdrus you can't arbitrarily pick camera configurations. Does your hardware setup support the config your trying to achieve?
      A 1 Reply Last reply
      • ModeratorM Moderator
        afdrus
        @Moderator Thank you for your reply. Yes, the hardware setup is fine (is a sentinel drone out of the box)
