  3. Voxl 2 and Herelink Slow Video stream
5 Posts 3 Posters 1.6k Views 1 Watching
  • Nicholas HansenN Offline
    Nicholas Hansen
    I have been working on getting a voxl 2 and a herelink 1.1 integrated using Sbus with the IO shield and using a usb to eth connection, so far I have gotten them to communicate and send video and telemetry to each other. My two primary issues are that I need to set the IP of the ethernet on the voxl 2 everytime its starts as it will not stay on 192.168.144.5 and the second issue is that my stream of the hires camera is about 1 frame every 4 seconds, any help on this issue would be greatly appreciated, thanks
    • Nicholas HansenN Nicholas Hansen
      @Nicholas-Hansen In order to set an IP address at boot you could create a systemd service that runs a script similar to this portion of the voxl-modem startup script:
      Link Preview Image
      scripts/voxl-modem-start · master · voxl / VOXL SDK / Utilities / voxl-modem · GitLab
      Modem utilities for the VOXL platform.
      favicon
      GitLab (gitlab.com)
      You could probably highjack the doodle workflow if you really want to. It's pretty basic, it just waits for the network interface to enumerate and sets the IP address if it is different from what is set in the config file. It then monitors that interface and sets the IP again if it ever changes
      echo -e "\nWaiting for eth0..."
              rc=1
              while [ $rc -ne 0 ]; do
                  ifconfig -s | grep eth0
                  rc=$?
                  sleep 1
              done
              echo -e "\neth0 initialized"
              # loop and re-set IP if network interface goes down and back up
              while true
              do
                  # grab ip address from eth0
                  eth0_ip=$(ip -4 addr show eth0 | grep -oP '(?<=inet\s)\d+(\.\d+){3}' | head -1)
                  # if it's not what we expect, fix it
                  if [[ "$eth0_ip" != *"$DOODLE_IP"* ]]; then
                      echo "setting IP address to: $DOODLE_IP"
                      ifconfig eth0 $DOODLE_IP netmask 255.0.0.0 up
                  fi
                  sleep 1
              done
      Nicholas HansenN 1 Reply Last reply
        Link Preview Image
        favicon
        GitLab (gitlab.com)
                rc=1
                    rc=$?
                    sleep 1
                done
                while true
                do
                    fi
                    sleep 1
                done
        Nicholas Hansen
        @tom That worked great for setting a fixed ip, thank you for the info. The video stream is still 1 frame every 5 seconds, and ideas on how to start working on that issue?
          @Nicholas-Hansen Are you just using voxl-streamer? What SDK are you using on this voxl2?
          Jeremy FrederickJ 1 Reply Last reply
            Jeremy FrederickJ Offline
            Jeremy Frederick
            @tom We're running v1.0.1 SDK. However, we were actually just able to get the RTSP stream working over Herelink with virtually no latency. Using the SiYiQgroundControl application on the Herelink, the RTSP works completely fine. I believe the issue is in the QGC firmware that ships stock with the Herelink controller. For now you can consider this thread solved. Thanks again!
