    Dual tracking camera configuration in SDK 1.0
    • A
      Anubhav
      Hello Team,
      I am trying to configure dual tracking camera, hires and TOF in vox2 ( new SDK 1.0 ).
      I have connected both ov7251 tracking cameras on J7 port with the help of M-0084 y-connector. Hires Imx214 in J8 and tof on j6 port. (image is also inserted to show the hardware setup)
      Below is the output while running the camera server. Can you tell me where I am going wrong and how can I resolve the problem.
      voxl-camera-server -d 0
      configuration for 4 cameras:
      cam #0
          sensor type:         pmd-tof
          isEnabled:           1
          camId:               0
          camId2:              -1
          fps:                 5
          en_preview:          1
          pre_width:           224
          pre_height:          1557
          pre_format:          tof
          en_small_video:      0
          small_video_width:   -1
          small_video_height:  -1
          en_large_video:      0
          large_video_width:   -1
          large_video_height:  -1
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             off
          standby_enabled:     0
          decimator:           5
          independent_exposure:0
      cam #1
          sensor type:         ov7251
          isEnabled:           1
          camId:               2
          camId2:              -1
          fps:                 30
          en_preview:          1
          pre_width:           640
          pre_height:          480
          pre_format:          raw8
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
      cam #2
          sensor type:         ov7251
          isEnabled:           1
          camId:               3
          camId2:              -1
          fps:                 30
          en_preview:          1
          pre_width:           640
          pre_height:          480
          pre_format:          raw8
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
      cam #3
          sensor type:         imx214
          isEnabled:           1
          camId:               4
          camId2:              -1
          fps:                 30
          en_preview:          0
          pre_width:           640
          pre_height:          480
          pre_format:          nv21
          en_small_video:      1
          small_video_width:   1024
          small_video_height:  768
          en_large_video:      1
          large_video_width:   4096
          large_video_height:  2160
          en_snapshot:         1
          snap_width:          4160
          snap_height:         3120
          ae_mode:             isp
          standby_enabled:     0
          decimator:           1
      DEBUG:   ------ voxl-camera-server: Starting 4 cameras
      Starting Camera: tof
      DEBUG:   ----------- Number of cameras: 1
      DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x007A, Sensor Id: 0x003D
      VERBOSE: Successfully found configuration match for camera 0: 224x1557
      VERBOSE: Adding preview stream for camera: 0
      DEBUG:   ALIGNING HEIGHT FOR LARGE IMAGE
      DEBUG:   Allocating img Buffer: width:  224 stride:  224 height: 1557 slice: 2048 size:  688128
      DEBUG:   Successfully set up pipeline for stream: PREVIEW
      DEBUG:   Started Camera: tof
      Starting Camera: tracking
      VERBOSE: Entered thread: cam0-request(tid: 2469)
      VERBOSE: Entered thread: cam0-result(tid: 2470)
      Segmentation fault:
      Fault thread: voxl-camera-ser(tid: 2448)
      Fault address: 0x564fc726cc
      Address not mapped.
      VERBOSE: Found Royale module config: imagerType 2, illuminationConfig.dutyCycle: 4 temp_sensor_type: 5
      VERBOSE: Found Royale module config: maxImgW 224 maxImgH 172 frameTxMode 1 camName X1.1_850nm_2W
      VERBOSE: Found Royale module config: tempLimitSoft 60.000000 tempLimitHard 65.000000 autoExpoSupported yes
      VERBOSE: Found Royale usecase: MODE_9_5FPS - phases: 9 fps: 5
      VERBOSE: Found Royale usecase: MODE_9_5FPS - exposure group[0] = gray
      VERBOSE: Found Royale usecase: MODE_9_5FPS - exposure group[1] = mod1
      Anubhav
      • ModeratorM
        Moderator ModalAI Team @Anubhav
        @Anubhav you need to be working with one of the supported configurations found here: https://docs.modalai.com/voxl2-camera-configs/#image-sensor-configurations---sdk-10
        It is not plug and play
        • A
          Anubhav @Moderator
          @Moderator
          I have followed the link given by you, but it is very hard to understand the document you have mentioned. Under topic 1.6.2 SUPPORTED SENSOR HARDWARE IDS
          1. There is no where mentioned that a tracking camera is supported in JU of M0084 attached to J7 port, however the picture shows in c-16 configuration that tracking is attached to JU of M0084.
          2. Also it's mentioned that hardware id 4 and 5 (port J8) doesn't support tracking. but the picture shows tracking is attached to J8 port with M0076 flex cable.
          I have tried c-16 configuration by following the configuration setup given in the image in the document. My setup is shown below in the table and image attached:
          Output from the camera-server is as follows: Tof, hires, and tracking didn't gave any problem but the camera server crashed due to tracking2.
          voxl2:/$ voxl-camera-server
          existing instance of voxl-camera-server found, attempting to stop it
          cam #0
              isEnabled:           1
              camId:               0
              camId2:              -1
              fps:                 5
              en_preview:          1
              pre_width:           224
              pre_height:          1557
              pre_format:          tof
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             off
              standby_enabled:     0
              decimator:           5
          cam #1
              sensor type:         imx214
              isEnabled:           1
              camId:               1
              camId2:              -1
              fps:                 30
              en_preview:          0
              pre_width:           640
              pre_height:          480
              pre_format:          nv21
              en_small_video:      1
              en_large_video:      1
              en_snapshot:         1
              snap_width:          4160
              snap_height:         3120
              ae_mode:             isp
              standby_enabled:     0
              decimator:           1
          cam #2
              sensor type:         ov7251
              isEnabled:           1
              camId:               2
              camId2:              -1
              fps:                 30
              en_preview:          1
              pre_width:           640
              pre_height:          480
              pre_format:          raw8
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              standby_enabled:     0
              decimator:           1
          cam #3
              sensor type:         ov7251
              isEnabled:           1
              camId:               3
              camId2:              -1
              fps:                 30
              en_preview:          1
              pre_width:           640
              pre_height:          480
              pre_format:          raw8
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              standby_enabled:     0
              decimator:           1
          Starting Camera: hires
          WARNING: Port Def 0:
          	Count Min: 8
          	Count Actual: 16
          	Buffers Contiguous: Yes
          	Buffer Alignment: 0
          WARNING: Port Def 1:
          	Count Min: 4
          	Count Actual: 16
          	Buffers Contiguous: No
          	Buffer Alignment: 0
          	Count Min: 8
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 4
          	Count Actual: 16
          	Buffer Alignment: 0
          Starting Camera: tracking2
          Segmentation fault:
          Fault thread: voxl-camera-ser(tid: 2411)
          Segmentation fault
          Viswanadh CheguV 1 Reply Last reply Reply Quote 0
          • Viswanadh CheguV
            Viswanadh Chegu @Anubhav
            Hi @Moderator, @modaltb
            Any update on the configuration of tracking camera in HW Sensor ID- 3. Camera Server crashes whenever i connect tracking camera in HW sensor ID-3 (J7U) but in the camera server configuration, SDK 1.0 (C-06, C-14 , C-16, C-17 ) configurations shows that the tracking camera is connected to J7U.
            Can you please give me update on this?
