    No Odometry in QGC through MAVLink
    • S
      SMRazaRizvi
      Problem: My Sentinel drone with VOXL SDK 1.0, drifts when I take off. It drifts a lot when I take off in Manual mode, and when I take off in Position mode, it drifts with a blow of wind.
      One of the problems I noticed is that I cannot see Odometry messages inside the MAVLink Inspector, and the frequency of LOCAL_POSITION_NED is also 1.0 Hz.
      How can I enable Odometry and also increase the frequency of LOCAL_POSITION_NED ?
      • S
        SMRazaRizvi @SMRazaRizvi
        @SMRazaRizvi @Moderator ?
        Jetson NanoJ 1 Reply Last reply Reply Quote 0
        • Jetson NanoJ
          Jetson Nano @SMRazaRizvi
          @SMRazaRizvi Make sure your vio is running, and there are certain parameters that needs to be enabled in QGC for it to hold position, check whether you have done it
          • S
            SMRazaRizvi @Jetson Nano
            @Jetson-Nano Can you please mention those parameters here, and their correct values?
            • Jetson NanoJ
              @SMRazaRizvi Sorry for the delayed response
              for PX4 version 1.14 the paramters are https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/EKF2_helpers/indoor_vio.params
              for PX4 version 1.12 the paramters are https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.12/ekf2_indoor_vio.params
              • S
                @Jetson-Nano
                Thank you for your response.
                But these are the parameters for indoor, I am testing outdoors.
                I tried
                https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/EKF2_helpers/outdoor_gps_baro.params
                https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/Sentinel_V1.params
                But still same issue.
                • Jetson NanoJ
                  @SMRazaRizvi You have to setup GPS and make EKF Aid mask use GPS, and I don't think using GPS will give you odometry data, you might get some sort of global position which helps you hold position and navigate
