  3. How to write data to vvhub_fixed_pose_input pipe
1 Posts 1 Posters 531 Views
  • madswampM Offline
    madswampM Offline
    madswamp
    Hello devs,
    I have developed a new algorithm that is able to give me the XYZ and Yaw of the Sentinel drone.
    I intend to use this 4dof pose as relocalization for the VIO algorithm.
    The 4dof is being published as a ROS topic and the last step is to be able to publish this 4dof data to the vvhub_fixed_pose_input pipe.
    I did not find any example on how to do it in the voxl-mpa-ros, can you point me in the right direction.
    Also, I noticed that in the SDK 1.0, the parameter en_fixed_frame_pipe is missing from the voxl-vision-hub.conf file, do I need to add it in order to be able to use the pipe?
    Thank you
