  3. VOXL 2 IMU Server not running
1 Posts 1 Posters 278 Views
  • Harshill DaggupatiH Offline
    Harshill Daggupati
    wrote on last edited by Harshill Daggupati
    I have re-flashed voxl 2 multiple times, ran all the configuration commands from voxl-inspect-sku, voxl-configure-sku, voxl-check-calibration to voxl-configure-mpa and nothing works. I have re-flashed multiple older and newer versions and also reset the /data folder, so as to not persist between re-flashes, but that did not help too. The IMUs were working and all of a sudden they stopped.
    I ran the voxl-inspect-imu imu0 command, and it gives a blank output:
    waiting for server at /run/mpa/imu0/
    in the /run/mpa folder, there does not exist any imu0 or imu1 folder, only imu_px4 exists, which upon running voxl-inspect-imu imu_px4 --all gives a blank output
    Acc in m/s^2, gyro in rad/s, temp in C, time in ms
    gravity| accl_x accl_y accl_z| gyro_x  gyro_y  gyro_z |  Temp | timestamp |  dt  |
    The IMU server is enabled but not running, here is the output of the command voxl-imu-server :
    voxl2:/$ voxl-imu-server
    loading calibration file
    voxl-imu-server currently has no calibration file
    calibration for IMU0:
    Gyro Offsets (rad/s): X:   0.000 Y:   0.000 Z:   0.000
    Accl Offsets (m/s^2): X:   0.000 Y:   0.000 Z:   0.000
    Accl Scale          : X:   1.000 Y:   1.000 Z:   1.000
    has_baseline_temp:      0
    gyro_baseline_temp (C):  30.000
    accl_baseline_temp (C):  30.000
    has_temp_cal:          0
    gyro_drift_coeff: X:   0.000000   0.000000   0.000000
    gyro_drift_coeff: Y:   0.000000   0.000000   0.000000
    gyro_drift_coeff: Z:   0.000000   0.000000   0.000000
    accl_drift_coeff: X:   0.000000   0.000000   0.000000
    accl_drift_coeff: Y:   0.000000   0.000000   0.000000
    accl_drift_coeff: Z:   0.000000   0.000000   0.000000
    calibration for IMU1:
    has_temp_cal:          0
    calibration for IMU2:
    has_temp_cal:          0
    calibration for IMU3:
    has_temp_cal:          0
    loading config file
    imu_apps_enable:                 1
    imu_apps_bus:                    3
    imu_apps_sample_rate_hz:         1000.0
    imu_apps_lp_cutoff_freq_hz:      92.0
    imu_apps_rotate_common_frame:    1
    imu_apps_fifo_poll_rate_hz:      100.0
    aux_imu1_enable:                 0
    aux_imu1_bus:                    1
    aux_imu1_sample_rate_hz:         1000.0
    aux_imu1_lp_cutoff_freq_hz:      92.0
    aux_imu1_fifo_poll_rate_hz:      100.0
    aux_imu2_enable:                 0
    aux_imu2_spi_bus:                14
    aux_imu2_sample_rate_hz:         1000.0
    aux_imu2_lp_cutoff_freq_hz:      92.0
    aux_imu2_fifo_poll_rate_hz:      100.0
    aux_imu3_enable:                 0
    aux_imu3_spi_bus:                5
    aux_imu3_sample_rate_hz:         1000.0
    aux_imu3_lp_cutoff_freq_hz:      92.0
    aux_imu3_fifo_poll_rate_hz:      100.0
    detected ICM42688 on spi bus[id] 3
    Detected board M0054
    Initializing IMU0
    using ODR=1000.00hz which is the nearest the icm42688 can get to 1000.0
    ERROR: in icm42688_basic_read read all 0's
    ERROR: failed to read data from IMU0
    ERROR: failed to init at least one IMU
    Here are the journalctl logs after running the command systemctl start voxl-imu-server:
    Aug 16 10:02:14 m0054 systemd[1]: Starting voxl-imu-server...
    Aug 16 10:02:15 m0054 systemd[1]: Started voxl-imu-server.
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: ERROR: in icm42688_basic_read read all 0's
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: ERROR: failed to read data from IMU0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: ERROR: failed to init at least one IMU
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: loading calibration file
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: voxl-imu-server currently has no calibration file
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: ==================================================
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: calibration for IMU0:
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: Gyro Offsets (rad/s): X:   0.000 Y:   0.000 Z:   0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: Accl Offsets (m/s^2): X:   0.000 Y:   0.000 Z:   0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: Accl Scale          : X:   1.000 Y:   1.000 Z:   1
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: has_baseline_temp:      0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: gyro_baseline_temp (C):  30.000
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: accl_baseline_temp (C):  30.000
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: has_temp_cal:          0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: gyro_drift_coeff: X:   0.000000   0.000000   0.000
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: gyro_drift_coeff: Y:   0.000000   0.000000   0.000
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: gyro_drift_coeff: Z:   0.000000   0.000000   0.000
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: accl_drift_coeff: X:   0.000000   0.000000   0.000
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: accl_drift_coeff: Y:   0.000000   0.000000   0.000
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: accl_drift_coeff: Z:   0.000000   0.000000   0.000
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: calibration for IMU1:
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: calibration for IMU2:
    Aug 16 10:02:15 m0054 systemd[1]: voxl-imu-server.service: Main process exited, code=exited, st
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: calibration for IMU3:
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: [66B blob data]
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: loading config file
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: imu_apps_enable:                 1
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: imu_apps_bus:                    3
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: imu_apps_sample_rate_hz:         1000.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: imu_apps_lp_cutoff_freq_hz:      92.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: imu_apps_rotate_common_frame:    1
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: imu_apps_fifo_poll_rate_hz:      100.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu1_enable:                 0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu1_bus:                    1
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu1_sample_rate_hz:         1000.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu1_lp_cutoff_freq_hz:      92.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu1_fifo_poll_rate_hz:      100.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu2_enable:                 0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu2_spi_bus:                14
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu2_sample_rate_hz:         1000.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu2_lp_cutoff_freq_hz:      92.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu2_fifo_poll_rate_hz:      100.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu3_enable:                 0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu3_spi_bus:                5
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu3_sample_rate_hz:         1000.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu3_lp_cutoff_freq_hz:      92.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: aux_imu3_fifo_poll_rate_hz:      100.0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: detected ICM42688 on spi bus[id] 3
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: Detected board M0054
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: Initializing IMU0
    Aug 16 10:02:15 m0054 voxl-imu-server[5347]: using ODR=1000.00hz which is the nearest the icm42
    Aug 16 10:02:15 m0054 systemd[1]: voxl-imu-server.service: Failed with result 'exit-code'.
