  2. VOXL Compute & Autopilot
  3. Flight Core
  4. Issue with Bootloader
Scheduled Pinned Locked Moved Flight Core
2 Posts 2 Posters 566 Views
  • Jerry FullerJ Offline
    Jerry Fuller
    Hi I have a Flight Core that I am trying to update the firmware on (changing to Ardupilot) I have no issues through the USB port normally but when in bootloader mode it's as if the USB communication is just cut off. The green light is flashing as it should to indicate bootloader mode but when it does change to bootloader mode the USB connection just drops and I can't find anything in Device Manager. Are there any known issues or something obvious I'm missing?
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      Hi @Jerry-Fuller - you need to update the most recent iteration of QGC where the changes have been made to actually upload/get the system out of bootloader mode. I would recommend downloading the most recent daily build of QGC and seeing if that helps flash the device.
