  3. Avoidance Question
Avoidance Question
4 Posts 2 Posters 987 Views 3 Watching
  • K Offline
    K Offline
    kiprock
    Hello! Just reading through your documentation on Obstacle Avoidance .. it seems to imply that you just need to run a calibration and turn it on in /etc/modalai/voxl-vision-px4.conf
    When I do all this, I don't seem to be getting any meaningful obstacle data from the debug mode or in QGC. I assume that I also need to compile and run the avoidance ros node on my own apart from these instructions?
    Can you please clarify?
      Hi Kip, right now that feature is only implemented in voxl-suite 0.2.0 and earlier. We're working right now on implementing for voxl-suite 0.3.5
      • K Offline
        K Offline
        kiprock
        I'm not so sure which one I'm on:
        system-image:    ModalAI 3.1.0 BUILDER: ekatzfey BUILD_TIME: 2020-12-23_19:41
        kernel:          #1 SMP PREEMPT Wed Dec 23 19:50:23 UTC 2020 3.18.71-perf
        architecture:    aarch64
        processor:       apq8096
        os:              GNU/Linux
        voxl-suite:
        Package: voxl-suite
        Version: 0.3.4
        Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
        Status: unknown ok not-installed
        Section: base
        Architecture: all
        Maintainer: james@modalai.com
        MD5Sum: e1e5bf1a125affe5036099f6ce895bed
        Filename: voxl-suite_0.3.4.ipk
        Description: meta-package for voxl-suite stable release
        Package: voxl-suite
        Version: 0.2.0
        Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
        Section: base
        Architecture: armv7a
        MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
        Filename: voxl-suite_0.2.0.ipk
        Description: meta-package to install all of the voxl-suite
        Installed-Time: 1062
        • K Offline
          K Offline
          kiprock
          Hi @Chad-Sweet it appears that I am on voxl-suite 0.2.0 as indicated above. However, if QGC reports that avoidance system is unavailable and the vehicle will not arm. If I run
          voxl-vision -s
          I can see the obstacle debug info on the terminal, also I set
          "en_voa":    true,
          Any suggestions as to what I am doing wrong?
