  3. Sentinel PX4 ( NO GPs Lock and firmware problem )
sentinel
21 Posts 3 Posters 6.5k Views 2 Watching
  • Samer JaradatS Offline
    Samer Jaradat
    I've got some Sentinels that have been sitting on a shelf since last fall that I'm trying to get up and running for indoor flight tests. I've been running into some errors when trying to arm them via qgroundcontrol. For reference these are running with the microhard carrier add-on and two pMDDL2450 radios to communicate back and forth.
    I'm unable to enable GPS even after updating the EKF2_AID_MASK parameter, I get frequent MAG#0 Timeout warnings and I have a pretty high loss rate over MAVLink. Also when the vehicles are ready to arm and I can get the motors to spin for a second and then some failsafe is enable that shuts everything down and forces the vehicle to reboot. When that happens I get the following logs in the QGC console:
    ""_handleCommandAck command(MAV_CMD_COMPONENT_ARM_DISARM)result(MAV_RESULT_ACCEPTED)""
    "_handleCommandAck Ack not in list "MAV_CMD_COMPONENT_ARM_DISARM"
    I also get the following error when navigating around the vehicle settings in QGC:
    "Parameters are missing from firmware. You may be running a version of firmware which is not fully supported or your firmware has a bug in it. Missing paramsL 1:SDLOG_MODE"
    I'm wondering if any of this has to do with the voxl-px4 firmware and whether updating it would help. These are running voxl-px4 version1.12.31beta 352462912_803653048098626_8696777585441101018_n.jpg 356112415_1288905648711495_7985451779473636071_n.jpg 356264180_1207399063268837_8454904516466682716_n.jpg
    Who I flashed release of the sentinels with the SDK 0.9.5 and to solve at least a few of the issues Are there specific steps ?
    Please tell me the details that help to solve these problems and how we can get rid of them as soon as possible
    • Samer JaradatS Samer Jaradat
      @Samer-Jaradat The missing params warning can be safely ignored
        @Samer-Jaradat Can you log into your drone with adb or ssh and enter the command px4-qshell gps status?
          Samer Jaradat
          voxl2:/$ px4-qshell gps status
          INFO [qshell] Send cmd: 'gps status'
          INFO [qshell] qshell return value timestamp: 2376085469, local time: 2376088441
          this is the result
            this is the result
            @Samer-Jaradat Okay, that's not very exciting. How about px4-listener sensor_gps?
              Samer Jaradat
              voxl2:/$ px4-listener sensor_gps
              never published
                never published
                @Samer-Jaradat Okay, so that confirms that GPS driver has not been able to communicate with the GPS unit. Can you try journalctl --no-pager -b -u voxl-px4 > /tmp/test.txt and then attach the test.txt file so I can see all of the PX4 status and debug messages?
                Samer JaradatS 1 Reply Last reply
                  Samer Jaradat
                  voxl2:/$ journalctl --no-pager -b -u voxl-px4 > /tmp/test.txt
                  -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2023-06-23 18:06:16 UTC. --
                  Jun 23 16:24:45 m0054 systemd[1]: Starting px4...
                  Jun 23 16:24:50 m0054 systemd[1]: Started px4.
                  Jun 23 16:24:50 m0054 bash[1691]: Found DSP signature file
                  Jun 23 16:24:50 m0054 bash[1691]: Running on M0054
                  Jun 23 16:24:52 m0054 bash[1691]: INFO [qshell] Send cmd: 'icm42688p start -s'
                  Jun 23 16:24:52 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 11522033, local time: 11523559
                  Jun 23 16:24:54 m0054 bash[1691]: Starting Holybro magnetometer
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14344064, local time: 14345444
                  Jun 23 16:24:54 m0054 bash[1691]: Starting Holybro LED driver
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14401400, local time: 14402064
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [px4] assuming working directory is rootfs, no symlinks needed.
                  Jun 23 16:24:54 m0054 bash[1691]: ______ __ __ ___
                  Jun 23 16:24:54 m0054 bash[1691]: | ___ \ \ \ / / / |
                  Jun 23 16:24:54 m0054 bash[1691]: | |/ / \ V / / /| |
                  Jun 23 16:24:54 m0054 bash[1691]: | __/ / \ / /
                  Jun 23 16:24:54 m0054 bash[1691]: | | / /^\ \ ___ |
                  Jun 23 16:24:54 m0054 bash[1691]: _| / / |_/
                  Jun 23 16:24:54 m0054 bash[1691]: px4 starting.
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread hpwork
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 83
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread lpwork
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 82
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wkr_hrt
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 81
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread client_sync_thread
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 80
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_manager
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 79
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread qshell
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 78
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: icm42688p start -s
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_SPI1
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 76
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_accel
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_topic
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_gyro
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic imu_server
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: on SPI bus 1
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: icm42688p start -s
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 11522033, current timestamp 11522034
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic qshell_retval
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                  Jun 23 16:24:54 m0054 bash[1691]: ERROR [muorb] SLPI: Cannot reset all parameters on client side
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic parameter_update
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_topic
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [logger] logger started (mode=all)
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_I2C1
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 75
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: ist8310 #0 on I2C bus 1 (external)
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14344064, current timestamp 14344065
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1 (external)
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14401400, current timestamp 14401401
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: icp10100 start -I -b 5
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_I2C5
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 74
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x9c6329 1024INFO [qshell] Send cmd: 'icp10100 start -I -b 5'
                  Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14434955, local time: 14435823
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'modalai_esc start'
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14487155, local time: 14487822
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix'
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14542181, local time: 14543199
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14585276, local time: 14586089
                  Jun 23 16:24:55 m0054 bash[1691]: Starting Holybro GPS
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'gps start -d 7 -b 115200'
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14617107, local time: 14618038
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'px4io detect'
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] cmd returned with: -17
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14668509, local time: 14669837
                  Jun 23 16:24:55 m0054 bash[1691]: ERROR [qshell] Command failed
                  Jun 23 16:24:55 m0054 bash[1691]: M0065 not detected, starting Spektrum RC driver
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'spektrum_rc start -d 8'
                  Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14706420, local time: 14708458
                  Jun 23 16:24:56 m0054 bash[1691]: 9001
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: probe probe succeeded. data = 0x1 0x48
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: icp10100 #0 on I2C bus 5
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: icp10100 start -I -b 5
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14434955, current timestamp 14434956
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_mag
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: modalai_esc start
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_hp_default
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 73
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic test_motor
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_baro
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: modalai_esc start
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14487155, current timestamp 14487156
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Opened UART ESC device
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_rate_ctrl
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 71
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14542181, current timestamp 14542182
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic actuator_outputs
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic multirotor_motor_limits
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_I2C2
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4169
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x784411 7881745
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic battery_status
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: voxlpm #0 on I2C bus 2 (external)
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14585276, current timestamp 14585277
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic power_monitor
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: gps start -d 7 -b 115200
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread gps
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 70
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: gps start -d 7 -b 115200
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14617107, current timestamp 14617107
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: px4io detect
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: serial port fd 2
                  Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: px4io read failed
                  Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: px4io io_reg_get(0,0,1): data error -5
                  Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: IO not installed
                  Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Detection attempt 2 failed
                  Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Detection attempt 1 failed
                  Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Detection attempt 0 failed
                  Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Failed to execute command: px4io detect
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14668509, current timestamp 14668510
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: spektrum_rc start -d 8
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread spektrum_rc_main
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 67
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: spektrum_rc start -d 8
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14706420, current timestamp 14706421
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: sensors start
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 66
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: sensors start
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 15763186, current timestamp 15763187
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_angINFO [qshell] Send cmd: 'sensors start'
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 15763186, local time: 15766524
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'ekf2 start'
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 15924808, local time: 15926148
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_pos_control start'
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 15977526, local time: 15978641
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_att_control start'
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16020779, local time: 16021799
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_rate_control start'
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16076014, local time: 16077458
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16115582, local time: 16117055
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'land_detector start multicopter'
                  Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16150880, local time: 16151957
                  Jun 23 16:24:57 m0054 bash[1691]: ular_acceleration
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_angular_velocity
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_INS0
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 65
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_imu
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_imu_status
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensors_status_imu
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_acceleration
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_air_data
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_selection
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_combined
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: ekf2 start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: ekf2 start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 15924808, current timestamp 15924809
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic ekf2_timestamps
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_pos_control start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_pos_control start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 15977526, current timestamp 15977527
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_att_control start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_att_control start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16020779, current timestamp 16020780
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_rate_control start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_rate_control start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16076014, current timestamp 16076015
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16115582, current timestamp 16115583
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: land_detector start multicopter
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: land_detector start multicopter
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16150880, current timestamp 16150881
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_land_detected
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: 16481861: reset position to last known position
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: 16481861: reset velocity to zero
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_local_position
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_odometry
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_states
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_status
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_status_flags
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_innovations
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_innovation_test_ratios
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_innovation_variances
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic position_setpoint_triplet
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [commander] LED: open /dev/led0 failed (22)
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic led_control
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic tune_control
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_control_mode
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_status
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic actuator_armed
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic commander_state
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic rate_ctrl_status
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic actuator_controls_0
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_status_flags
                  Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_command
                  voxl2:/$ /tmp/test.txt
                  bash: /tmp/test.txt: Permission denied
                    Samer Jaradat
                    @Eric-Katzfey
                    no text file created
                      @Eric-Katzfey
                      @Samer-Jaradat do cat /tmp/test.txt, it probably was created
                      tomT Samer JaradatS 2 Replies Last reply
                        wrote on last edited by tom
                        #11
                        @tom Or outside of the adb shell do adb pull /tmp/test.txt . to pull it off and upload that file here
                          @Samer-Jaradat said in Sentinel PX4 ( NO GPs Lock and firmware problem ):
                          Please change the line qshell gps start -d 7 -b 115200 in /etc/modalai/voxl-px4.config to qshell gps start and see if that solves the GPS issue,
                            Samer Jaradat
                            @tom
                            no txt file created after do this command on my computer / tmp
                              @tom
                              @Samer-Jaradat Don't worry about the text file. You pasted the output directly into the forum so that's just as good.
                                Samer Jaradat
                                @Eric-Katzfey
                                adb shell creat this result after do this command.
                                voxl2:/$ /etc/modalai/voxl-px4.config
                                bash: /etc/modalai/voxl-px4.config: Permission denied
                                  @Eric-Katzfey
                                  @Samer-Jaradat Don't try to execute that file directly. It is used by px4. Just edit it, save it, and then reboot your drone.
                                    Samer Jaradat
                                    @Eric-Katzfey
                                    OK, but i don't know how we can edit it,
                                    please tell me how i can edit it and save it.
                                      @Eric-Katzfey
                                      @Samer-Jaradat Please find a tutorial online about using the program vi to edit files in Linux.
                                        Samer Jaradat
                                        @Eric-Katzfey
                                        when i open vi program this is the result as shown on my pc i cant show the command that need to editing
                                        GNU nano 2.9.3 /etc/modalai/voxl-px4.config
                                        #!/bin/sh
                                        PX4 commands need the 'px4-' prefix in bash.
                                        . px4-alias.sh
                                        Figure out what platform we are running on.
                                        Eventually there will be a utility called voxl-platform that will
                                        return the platform tag or an error code. This utility is not yet
                                        ubiquitous so it may be that it isn't available. Trying to call a
                                        non existent program will generate an error code by the OS. If the
                                        program exists and doesn't return an error code then use the results.
                                        PLATFORM=/usr/bin/voxl-platform 2> /dev/null
                                        RETURNCODE=$?
                                        if [ $RETURNCODE -ne 0 ]; then
                                        # If we couldn't get the platform from the voxl-platform utility then check
                                        # /etc/version to see if there is an M0052 substring in the version string.$
                                        # then we assume that we are on M0052. Otherwise assume M0054.
                                        VERSIONSTRING=$(</etc/version)
                                        [ Read 271 lines ]
                                        ^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos
                                        ^X Exit ^R Read File ^\ Replace ^U Uncut Text^T To Linter ^_ Go To Line
                                          Samer Jaradat
                                          @Eric-Katzfey
                                          this is file open when i use vi program ( no command qshell gps start -d 7 -b 115200 in script file )
                                          this is all file command :
                                          #!/bin/sh
                                          (px4-alias.sh is expected to be in the PATH)
                                          . px4-alias.sh
                                          RETURNCODE=$?
                                          M0052SUBSTRING="M0052"
                                          if [[ "$VERSIONSTRING" == "$M0052SUBSTRING" ]]; then
                                          PLATFORM="M0052"
                                          else
                                          PLATFORM="M0054"
                                          fi
                                          fi
                                          We can only run on M0052 or M0054 so exit with error if that is not the case
                                          if [ $PLATFORM = "M0052" ]; then
                                          /bin/echo "Running on M0052"
                                          if [ "$RC" == "CRSF" ]; then
                                          /bin/echo "Error, crossfire not supported on M0052!"
                                          exit 0
                                          fi
                                          elif [ $PLATFORM = "M0054" ]; then
                                          /bin/echo "Running on M0054"
                                          else
                                          /bin/echo "Error, cannot determine platform!"
                                          exit 0
                                          fi
                                          uorb start
                                          muorb start
                                          In order to just exit after starting the uorb / muorb modules define
                                          the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
                                          This is useful for testing / debug where you may want to start drivers
                                          and modules manually from the px4 command shell
                                          if [ ! -z $MINIMAL_PX4 ]; then
                                          /bin/echo "Running minimal script"
                                          exit 0
                                          fi
                                          #!/bin/sh
                                          . px4-alias.sh
                                          RETURNCODE=$?
                                          PLATFORM="M0052"
                                          else
                                          PLATFORM="M0054"
                                          fi
                                          fi
                                          exit 0
                                          fi
                                          else
                                          exit 0
                                          fi
                                          uorb start
                                          muorb start
                                          exit 0
                                          fi
                                          Sleep a little here. A lot happens when the uorb and muorb start
                                          and we need to make sure that it all completes successfully to avoid
                                          any possible race conditions.
                                          /bin/sleep 1
                                          IMU (accelerometer / gyroscope)
                                          Start this first because it gets the high rate interrupts coming in to the
                                          DSP. Without this the DSP will oversleep and miss critical timeouts.
                                          TODO: Why is that the case?
                                          if [ "$IMU" == "ROTATE_IMU_YAW_180" ]; then
                                          /bin/echo "Starting IMU driver with yaw 180 rotation"
                                          qshell icm42688p start -s -R 4
                                          else
                                          fi
                                          /bin/sleep 1
                                          Load in all of the parameters that have been saved in the file
                                          param load
                                          Start logging and use timestamps for log files when possible.
                                          Add the "-e" option to start logging immediately. Default is
                                          to log only when armed
                                          logger start -t
                                          We do not change the value of SYS_AUTOCONFIG but if it does not
                                          show up as used then it is not reported to QGC and we get a
                                          #!/bin/sh
                                          . px4-alias.sh
                                          RETURNCODE=$?
                                          PLATFORM="M0052"
                                          else
                                          PLATFORM="M0054"
                                          fi
                                          fi
                                          exit 0
                                          fi
                                          else
                                          exit 0
                                          fi
                                          uorb start
                                          muorb start
                                          exit 0
                                          fi
                                          /bin/sleep 1
                                          else
                                          fi
                                          /bin/sleep 1
                                          param load
                                          logger start -t
                                          missing parameter error.
                                          param touch SYS_AUTOCONFIG
                                          Start all of the device drivers on DSP
                                          Magnetometer
                                          if [ "$GPS" == "MATEK" ]; then
                                          # Use this line for the magnetometer in the Matek Systems M8Q-5883 module
                                          /bin/echo "Starting Mateksys M8Q-5883 magnetometer"
                                          qshell qmc5883l start -R 10 -X -b 1
                                          elif [ "$GPS" == "HERE3" ]; then
                                          # Use this line for the magnetometer in the Here3 GPS module
                                          /bin/echo "Starting Here3 ak09916 magnetometer"
                                          qshell ak09916 start -R 2 -X
                                          else
                                          # Use this line for the magnetometer in the Holybro GPS module
                                          /bin/echo "Starting Holybro magnetometer"
                                          qshell ist8311 start -R 10 -X -b 1
                                          fi
                                          LED driver for the Pixhawk 4 GPS module
                                          Older units have i2c address 0x39 (57) and newer ones 0x38 (56)
                                          M0054 only supports the newer one. M0052 can support either.
                                          qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 57
                                          fi
                                          102,18 33%
                                          else
                                          qshell ist8310 start -R 10 -X -b 1
                                          fi
                                          fi
                                          if [ "$GPS" == "HOLYBRO" ]; then
                                          /bin/echo "Starting Holybro LED driver"
                                          qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                                          # Use this line for the Here3 GPS module LED controller
                                          /bin/echo "Starting Here3 LED"
                                          qshell rgbled start -X -f 400
                                          fi
                                          Barometer
                                          qshell icp10100 start -I -b 5
                                          ESC driver
                                          We start this even if there is a PX4IO module. If there is
                                          a PX4IO (M0065) module it will be plugged into the RC port
        117,1         39%
