  3. VOXL2 Mini with Flight Core V2 Configuration
1 Posts 1 Posters 245 Views
  • D Offline
    D Offline
    Duncangemcmillan
    I need to source the correct GPS module for the flight core v2 unit and an adapter board to connect the flight core to the VOXL2 Mini.
    Can you specify the part numbers that I need to order for this build?
    Also can the mini ESC provide enough power to motors if using a larger drone frame. I have a weight limit of 4.4lbs and every gram counts!
