  3. Uable to install mavros with staging package manager
1 Posts 1 Posters 543 Views
  • Tamas Pal 0T Offline
    Tamas Pal 0
    Hi, I am trying to install voxl-vision-hub with staging pkg manager. I have done that. now I am trying to install mavros packages. It is showing error. Please fix this
    voxl2:~$ voxl-configure-pkg-manager
    Which repository do you want to use?
    stable  - recommended for most users
    staging - packages under testing for next sdk release
    sdk-X.Y - Specific SDK release
    dev     - recommended for ModalAI development team only
    1) dev      3) sdk-0.7  5) sdk-0.9  7) staging
    2) sdk-0.6  4) sdk-0.8  6) stable
    #? 7
    Using repo: staging
    Done configuring apt sources
    run apt update to pull new repository manifest
    voxl2:~$ apt update
    Get:1 file:/data/voxl-suite-offline-packages ./ InRelease
    Ign:1 file:/data/voxl-suite-offline-packages ./ InRelease
    Get:2 file:/data/voxl-suite-offline-packages ./ Release
    Ign:2 file:/data/voxl-suite-offline-packages ./ Release
    Get:3 file:/data/voxl-suite-offline-packages ./ Packages
    Ign:3 file:/data/voxl-suite-offline-packages ./ Packages
    Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en
    Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en
    Get:3 file:/data/voxl-suite-offline-packages ./ Packages [8065 B]
    Hit:5 https://download.docker.com/linux/ubuntu bionic InRelease
    Ign:6 http://voxl-packages.modalai.com qrb5165 InRelease
    Hit:7 http://voxl-packages.modalai.com qrb5165 Release
    Hit:8 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
    Hit:9 http://packages.ros.org/ros/ubuntu bionic InRelease
    Ign:10 http://voxl-packages.modalai.com qrb5165 Release.gpg
    Hit:11 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
    Hit:12 http://packages.ros.org/ros2/ubuntu bionic InRelease
    Get:13 http://voxl-packages.modalai.com qrb5165/staging arm64 Packages [20.3 kB]
    Hit:14 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
    Hit:15 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
    Fetched 20.3 kB in 3s (7675 B/s)
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    voxl2:~$ apt-get install ros-melodic-mavros ros-melodic-mavros-extras ros-melodic-control-toolbox
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
     ros-melodic-mavros : Depends: libeigen3-dev but it is not going to be installed
                          Depends: ros-melodic-eigen-conversions but it is not going to be installed
                          Depends: ros-melodic-tf2-eigen but it is not going to be installed
     ros-melodic-mavros-extras : Depends: ros-melodic-tf2-eigen but it is not going to be installed
    E: Unable to correct problems, you have held broken packages.
