  2. Software Development
  3. Restoring Catkin Workspace
3 Posts 2 Posters 515 Views 2 Watching
    Hi Modal AI team,
    I recently flashed the system image successfully and reload the docker image from /data I saved with:
    docker save kinetic | gzip > /data/roskinetic-xenial_v1_0.tgz
    I knew that flashing wipes the file system but didn't know the file system in docker also goes away.
    Is my Catkin ws stored somewhere else ?
    if not, it is going to be a important tragic lesson for me to backup my code and ws.
    Would the voxl-backup command save the catkin_ws?
    Thank you,
    Ayberk
      Hi @Voxlady ,
      In the beginning of the flashing process, the 'installation wizard' prompts you with the following:
      This process will completely wipe your VOXL
      Would you like to preserve the /data/ parition which contains
      things like calibration, wifi config, and docker images?
      To preserve files in /data/ answer Y
      To wipe /data/ for a full factory flash answer N
      Enter Y or N: [choose]
      Sorry about your data loss!
        Hi @modaltb ,
        Thank you for your message. I did actually choose "Yes" but it didn't store the ROS folders and files. It stored the Python packages I installed and the docker images.
        So, I would like to confirm if the voxl-backup command will save the folders in data.
        However, it is okay. I took me some time to recover but now all good.
        thank you again
