  2. VOXL Dev Kits
  3. VOXL-CAM
  4. Low stability in qvio due to low number of features
Scheduled Pinned Locked Moved VOXL-CAM
7 Posts 4 Posters 2.1k Views 3 Watching
  • Erez NehamaE Offline
    Erez Nehama
    Currently, I'm using the voxl-cam for vio only. It's mounted on my self-made drone without px-4 (I only want to receive the qvio data).
    During flight, the vio resets due to a low number of features (and then it takes time to initialize again). I'm adding some images of the qvio overlay, with cases where the image seems fine and the drone is stable (by the way it can happen on the ground as well), but not enough features were found
    Is there a way to increase the number of valid "good" features? Or maybe another way to increase the stability of the algorithm?
      White walls are very tough for any computer vision algorithm, so those may not ever work well
      The images look darker than I would expect. Have you tweaked the exposure settings at all? you could try increasing the ae_desired_msv which is configured in voxl-camera-server and see if that helps add contrast
        Erez Nehama
        Thank you very much! it seems to work a lot better. I've increased ae_desired_msv from 60 to 80.
        Joshua ErmiasJ 1 Reply Last reply
        • Erez NehamaE Erez Nehama
          Joshua ErmiasJ Offline
          Joshua Ermias
          @Erez-Nehama What command did you type in to increase the "ae_desired_msv"? I've tried using voxel-camer-server and voxel-send-command but neither let me change that value directly @Chad-Sweet
          • Joshua ErmiasJ Joshua Ermias
            tomT Online
            tomT Online
            @Joshua-Ermias It can be set in /etc/modalai/voxl-camera-server.conf
              Joshua Ermias
              @tom would you recommend using a text editor like Vim and restarting the service or is there a better way to do it?
                tomT Online
                tomT Online
                @Joshua-Ermias yes that would be the easiest way. You can either restart the service with systemctl restart voxl-camera-server or just power cycle your VOXL
