    Mpa to ros
    • SAGAR SARKARS
      SAGAR SARKAR
      I wrote a subscriber node to get the ‘data’ field of the ‘sensor_msgs/Img’ for rostopic ‘/tracking’. But not getting any output. I even tried echoing the topic, but still no output. Can someone explain the reason? The required services are already enabled and running.
      • SAGAR SARKARS
        SAGAR SARKAR
        • 張為超張
          張為超
          If you rostopic list on your pc does it show any topic ?
          SAGAR SARKARS 1 Reply Last reply Reply Quote 0
          • SAGAR SARKARS
            SAGAR SARKAR @張為超
            @張為超 Yes it does. Voxl2 is the master. I am running the voxl mpa to ros node in voxl2 and then trying to echo the published topics in my PC.
            • 張為超張
              張為超
              I think you can use voxl protal first to check if the camera configure is okay, then use "rqt_image_view" in ros to check ros configure.
              • SAGAR SARKARS
                SAGAR SARKAR @張為超
                @張為超 It worked. I setup my Pc as the master this time, and it worked in that way.
