  3. voxl-camer-server's hires snapshot produce huge files
3 Posts 1 Posters 840 Views
  • Dong LiuD Offline
    Dong LiuD Offline
    Dong Liu
    I tried to use hires' snapshot to capture 4K images. But because the size of the image produced is huge, the disk filled up very quickly.
    The size of jpeg file is around 48M. If I use imagemagic to convert it to png, the size reduced to 3.7M. I then use imagemagic again to convert it to jpeg, the size is only 740K.
    Browsing through the code of hal3_camera_mgr.cpp, in WriteSnapshot() just writes the whole allocated buffer to file. Is there any variable indicates the real size of data produced by the camera module?
    • Dong LiuD Offline
      Dong LiuD Offline
      Dong Liu
      I found out this https://android.googlesource.com/platform/frameworks/av/+/master/services/camera/libcameraservice/device3/Camera3OutputStream.cpp#1337
      Is function android::camera2::JpegProcessor::findJpegSize() available on voxl?
      • Dong LiuD Offline
        Dong LiuD Offline
        Dong Liu
        I extract the findJpegSize function, add to voxl-camera-server. Now it will produce the correct size snapshot.
