What is for "Avoidance / Collision prevention error"
Hi guys,
I'm on testing Collision prevention as like below link
https://docs.modalai.com/voxl-vision-px4-collision-prevention/
Also, I already verified VIO data and position mode but, as you can see below picture, I got a message Avoidance / collision prevention error.
because of this error, I cannot arm my flight in pre-check.
Could you please let me know why collision prevention error is occured in pre-check and how to revolve it?
Hi @shlee853 ,
Can you check your settings compared to these?
Please advise if they are the same and you're having issues.
Hi @shlee853 ,
We calibrate the stereo sensors before shipping on the Flight Decks and m500s. Not sure if you have that or the VOXL + image sensors.
Without stereo calibration, yes there's likely to be issues.
How about trying this and seeing how things look?
https://docs.modalai.com/voxl-vision-px4-collision-prevention/#debug-tools -
https://docs.modalai.com/voxl-vision-px4-collision-prevention/#debug-tools@modaltb I calibrated stereo camera and tracking camera. and I found calibrated file here
yocto:/# ls /home/root/.ros/camera_info/
left.yaml right.yaml tracking.yamlI also verified depth information using stereo camera and tracking information using tracking camera.
But, I'm not resolve Avoidance/Collision prevention Error so far.
Also, I cannot perform object avoidance function.
Could you please let me know some advice? why Avoidance/collision prevention error message appeared on QGC?
my flight s/w version is like this.
yocto:~# voxl-version
system-image: ModalAI 3.2.0 BUILDER: ekatzfey BUILD_TIME: 2021-02-05_19:54
kernel: #1 SMP PREEMPT Fri Feb 5 20:03:22 UTC 2021 3.18.71-perf
factory-bundle: 1.0.1 (Yocto installation)architecture: aarch64
processor: apq8096
os: GNU/Linuxvoxl-suite:
Package: voxl-suite
Version: 0.2.0
Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
Section: base
Architecture: armv7a
Maintainer: james@modalai.com
MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
Filename: voxl-suite_0.2.0.ipk
Description: meta-package to install all of the voxl-suite
Installed-Time: 245
I ran into the same issue where QGC displays:
Avoidance/collision prevention ErrorI think i know what is causing this issue in case there isnt any resolution yet.
It seems that QGC is interpreting what is sent from the AP the onboard_control_sensors_health bitfield in the MAV_SYS_STATUS_SENSOR message. And the bit responsible for this is MAV_SYS_STATUS_OBSTACLE_AVOIDANCE.
Looking at the PX4's Commander module, it also seems that the MAV_SYS_STATUS_OBSTACLE_AVOIDANCE bit is used for both obstacle avoidance AND collision prevention. While the VOXL-CAM is communicating with the AP for Collision Prevention, this health bit will always be false because the Avoidance system is not setup.
https://github.com/PX4/PX4-Autopilot/blob/ae0bb8371df1d2d2816e5ec2db67ca3936d0221c/src/modules/commander/Commander.cppBut i have yet to confirm if in spite of this, the Collision Prevention function still works. FYI i have a brand new Seeker which i have not tested in flight yet. Will anyone be able to advise before i go for my first flight?
Yes, PX4's obstacle avoidance and Collision Prevention are separate features. We only support the Collision Prevention functionality which is governed by the PX4 CP_DIST and similar parameters. Make sure the COM_OBS_AVOID parameter is OFF (0) in PX4
James
