  2. VOXL SDK and Software
  3. Using MPA within voxl-docker-mavsdk-cpp
mpa
5 Posts 5 Posters 4.0k Views 1 Watching
  • Evan HertafeldE Offline
    Evan Hertafeld
    I see the supported method for using MAVSDK with Voxl is a preconfigured Docker container, which I have successfully set up with voxl-docker to run MAVSDK and control my vehicle from within the container.
    I see that by default /run/mpa/ is shared into this container, which is great. However, when I try the libmodal_pipe hello_world example, I get an error:
    fatal error: modal_start_stop.h: No such file or directory
    Clearly this container isn't set up with the libmodal_pipe libraries. What's the proper way to use the MPA pipes from within the voxl-docker-mavsdk-cpp container?
    • Evan HertafeldE Evan Hertafeld
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      @Evan-Hertafeld Hey I wanted to know whether you were able to connect to mpa server and access the data inside mavsdk
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        @Evan-Hertafeld said in Using MPA within voxl-docker-mavsdk-cpp:
        libmodal_pipe
        @Evan-Hertafeld @Jetson-Nano
        You need to share all those files via a volume mount alongside with the /run/mpa directory to allow docker to probe the data and grab from an MPA pipe.
        so in your docker run something like -v /usr/include/modal_start_stop.h:/usr/include/modal_start_stop.h needs to be done - the other option is you just download the actual MPA debian inside your docker image and call it a day - then you will have all the necessary headers, libs, binaries, and you just need to share /run/mpa as a volume to access the data.
        Zach
        Ege YüceelE 1 Reply Last reply
          libmodal_pipe
          Zach
          Ege YüceelE Offline
          Ege YüceelE Offline
          Ege Yüceel
          @Zachary-Lowell-0 Hi Zach and team, I have been using the voxl docker mavsdk python container successfully for MAVSDK based drone control, and now I would like to read from VOXL’s Modal Pipe Architecture (MPA) inside the same container. I saw your suggestion about either mounting header files like modal_start_stop.h or installing the full MPA package inside the container. Could you please clarify the best way to do this? Should I install the libmodal_pipe Debian package inside the Docker image using the Dockerfile, or manually copy the headers and libraries from the host? Also, is this setup compatible with the voxl docker mavsdk python container, or is it mainly meant for the C++ MAVSDK version?
          I am trying to listen to a custom voxl tflite server service that gives inference output from my custom neural networks. I want to deploy some motion planning in Python based on the neural net output. I would really appreciate more specific setup instructions or an example Dockerfile that includes MPA support. Thank you.
          T 1 Reply Last reply
          • Ege YüceelE Ege Yüceel
            T Offline
            T Offline
            teddy.zaremba
            wrote on last edited by teddy.zaremba
            Hi @Ege-Yüceel,
            We usually create a volume to those headers when doing something like this but you can install the libmodal pipe package inside the docker container like this if you want.
            wget http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.5/binary-arm64/libmodal-pipe_2.13.1_arm64.deb
            dpkg -i libmodal-pipe_2.13.1_arm64.deb
            **Note change sdk-1.5 to whatever sdk version you're on
