  3. Voxl-logger error with 4k High-resolution, Low-light Sensor for VOXL® (Starvis IMX412 w/ M12-style Lens)
3 Posts 2 Posters 737 Views 1 Watching
  • Tamas Pal 0T Offline
    Tamas Pal 0
    I trying to run voxl-logger command with 4k High-resolution, Low-light Sensor for VOXL® (Starvis IMX412 w/ M12-style Lens) but some error is coming. This is the terminal output
    voxl2:~$ voxl-logger --cam hires --samples 50
    connected to ch 0 cam server: /run/mpa/hires/
    ERROR: invalid metadata, magic number=1549557085, expected 1448040524
    ERROR: invalid metadata, magic number=774977080, expected 1448040524
    ERROR: invalid metadata, magic number=673126168, expected 1448040524
    ERROR: invalid metadata, magic number=858796336, expected 1448040524
    channel 0 reached sample limit, stopping itself
    ERROR: invalid metadata, magic number=657208125, expected 1448040524
    summary of data logged:
    ch 0, type: cam, samples:      50, path: /run/mpa/hires/
    created new log here:
    /data/voxl-logger/log0004/
    Why this error is there? How to fix this ?
      this looks like a version mismatch between services. Are all of the packages on the same repo (ie stable) and up to date?
      • Chad SweetC Chad Sweet
        Tamas Pal 0
        @Chad-Sweet I have used both dev as well stable packages
                                "name":	"hires",
        			"enabled":	true,
        			"frame_rate":	30,
        			"type":	"imx214",
        			"camera_id":	2,
        			"preview_width":	640,
        			"preview_height":	480,
        			"record_width":	1920,
        			"record_height":	1080,
        			"snapshot_width":	3840,
        			"snapshot_height":	2160,
        			"ae_mode":	"isp"
        In the camera configuration file type of camera is "imx214". Is it correct?
