  3. 5G Add-on board - Accessing the Quectel module Linux Shell
3 Posts 3 Posters 688 Views 1 Watching
  • Mark LeeM Offline
    Mark LeeM Offline
    Mark Lee
    I have a 5G Add on board (MSA-M0090-3-01-01) with a Quectel M.2 (RM502Q-AE) module connected to the VOXL 2 board. I can access the VOXL Linux shell with ADB to the VOXL2 USB-C connector. Is there a way to connect to the Linux LE shell on the RM502Q-AE module?
    @Vinny - any suggestions?
      Not that we know about, sorry about that.
      • VinnyV Offline
        VinnyV Offline
        Vinny
        Hi @Mark-Lee ,
        Chad is correct in that we have not tried it, but my idea is that if you wanted to access the Linux shell on the modem card, you would need a modem development platform from Quectel.
        Here is an example I found online (please do your research to ensure this will work for you, but I do see they mention serial port access):
        https://www.aliexpress.us/item/3256803611119964.html?gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US
        In our architectures, we do have a mechanism to talk to the serial port over software using one of the QUPs, but there has been no need to do so, and would be a costly SW expense to develop it.
        If you are willing to void your warranty (not recommended), I can show you which resistors have it and you could try to solder on to them, but you are better off with the Dev Kit IMHO.
